Old 11-18-2008, 12:30 PM   #3346
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
For that matter I would just stand the shocks up more.
John St.Amant is offline   Reply With Quote
Old 11-18-2008, 12:48 PM   #3347
AWK
AWK's Avatar
Originally Posted by John St.Amant View Post
Does anyone know if there will be a update for the 416 to the wc spec.?
Or more likely I would have to purchase the parts individually to convert it myself... New lower susp mounts upper and lower deck arms and all.. I still can't quite tell whats so different about the motor mount.
To convert a box stock 416 to a 416 WE you would need to purchase:
  • Lower Deck
  • Upper Deck
  • Teflon Bearings
  • HL Dampers
  • Short Suspension Arms
  • Spool
I have not seen the new motor mount in person, but am told it's pretty different. Also, there will not be a conversion kit at this time. I am going to buy the parts myself to convert mine, but if you're like me you have the spool and suspension arms already, the dampers aren't a big deal, and you have already spent time building your bearings right. Really its upper deck, lower deck, and motor mount.
AWK is offline   Reply With Quote
Old 11-18-2008, 12:53 PM   #3348
KEWL! ty .... I would still like to see the dampers, But not for $60. If you end up getting the motor mount, would you be so kind as to post a few pics of it please ?
Old 11-18-2008, 01:00 PM   #3349
Jimmy Jacobson's Avatar
somehow everyone seems to think rebound is a tuning thing.. its just for making shocks equal and not overfilled. use it as a vernier.
You are 100% incorrect Rebound is a big tuning option We change the amount of rebound within the shock with different orings/foam on top of the bladder. When you see the Tamiya drivers put Shock Orings outside on the shock shaft this is to limit the up travel of the shock shaft.
Jimmy Jacobson is offline   Reply With Quote
Old 11-18-2008, 01:15 PM   #3350
TryHard's Avatar
  • Lower Deck
  • Upper Deck
  • Teflon Bearings
  • HL Dampers
  • Spool
New Motor mount
Tamiya TRF416 / TRF416WE / TRF416X-hupo-reedy-416-mount.jpg   Tamiya TRF416 / TRF416WE / TRF416X-motor-mount.jpg
Old 11-18-2008, 01:22 PM   #3351
Nice pics of the mount .. big difference indeed!
As for the rebound, well, go figure. I've only seen the foam or urithane above the bladder. Wouldn't that effect pack more than rebound? the oring thing was a suggestion for bleeding the shock durring assembly. But hey .... why would you limit up travel.... do your tires rub the body otherwise?
Old 11-18-2008, 01:48 PM   #3352
sohlman's Avatar
Trader Rating: 88 (100%+)
Originally Posted by TryHard View Post
New Motor mount
And:
New front and rear drive belts
New urethane bumper (larger)
Albeit minor items. Plus the expected date for the US is January 2009. Can someone confirm that date. Jimmy?
Steve Sohl
sohlman is offline   Reply With Quote
Old 11-18-2008, 01:49 PM   #3353
AWK
AWK's Avatar
Here are pictures of the damper cylinders themselves as you would buy them, and what they would look like with the buggy dampers.
Tryhard: thanks for the pics!
Tamiya TRF416 / TRF416WE / TRF416X-img_02631.jpg   Tamiya TRF416 / TRF416WE / TRF416X-header_42131.jpg
Old 11-18-2008, 02:01 PM   #3354
CraigM's Avatar
Trader Rating: 34 (100%+)
Does the new motor mount "do" anything? I was thinking they might have moved the motor like they have with the cells, but they'd need to change the spur location for it to go fore and aft, there's not much room for it to move lower, so maybe it's thinner moving the motor more towards the centre line of the chassis? or maybe it's just stiffer/lighter/whatever?
Nice pics Low-E, thats such a simple solution. I can never seem to cut fuel line that straight for my noisy cars, but I'll give it another go - the aussie nationals are on a bumpy track so I'll need to go up a bit. Great info everyone
Rainbow ten quoted me;
TAMIYA 42138 TRF416 WORLD EDITION 75800YEN(Pre-order 20% Off 60640yen) DEC 5th
Ed I think you should try RC Champ
42,980.00 JPY = 296.174 GBP
FYI that's around 1 million aussie paso's at the moment
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 11-18-2008, 02:39 PM   #3355
sakaguchinet's Avatar
Send a message via ICQ to sakaguchinet Send a message via AIM to sakaguchinet Send a message via Skype™ to sakaguchinet
@CarKing:
You forgot to mention the Suspension Blocks. Didn't see the specs, but I guess it would be 1C-1C and 1XA-1E (with the 42106 Kit supplied susblocks you will not be able to run Short LWT Sus Arms).
Due to the heavy Euro/Yen conversion at the moment here in Germany you can have the "old" 416 for 399 Euros. Put in another 200 Euros in and you will have the WE without lower and upper deck.
Best Regards,
Dai
http://www.rc-square.de (German and English manufacturers site)
http://www.sakaguchinetshop.com (Tamiya TRF related stuff)
sakaguchinet is offline   Reply With Quote
Old 11-18-2008, 02:56 PM   #3356
Not sure of any ETA dates Sorry What's up Sohlman?
Old 11-18-2008, 03:16 PM   #3357
STLNLST's Avatar
Trader Rating: 19 (100%+)
What up Sucka?
STLNLST is offline   Reply With Quote
Old 11-18-2008, 03:22 PM   #3358
SammyZ's Avatar
Trader Rating: 138 (100%+)
Originally Posted by sohlman View Post
And:
why did they change the belts?
SammyZ is offline   Reply With Quote
Old 11-18-2008, 03:24 PM   #3359
Trader Rating: 17 (100%+)
OhmyGOSH!!! Its Johnny Jacobson "Professional Playa"!!
Art
Team Powers, SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
www.TeamPowersUSA.com
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 11-18-2008, 04:16 PM   #3360
sohlman's Avatar
I believe it's a material change, not a size or teeth change. Less friction probably.
JJ - YGPM.
Steve Sohl
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
