Old 11-05-2008, 10:24 PM   #3166
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
I thought it was 2q 1.2mm holes and 3q 1.1mm holes...
John St.Amant is offline   Reply With Quote
Old 11-06-2008, 01:47 AM   #3167
veecee's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Besercoe View Post
How are the square ones different to the Tamiya 2 hole?
Did you guys try the extra ackerman on tuesday night?
Besercoe the extra ackerman felt good. The car definitely turned tighter especially mid-corner. Still had a tiny bit of push on exit which I want to dial out. Then I switched from White/Blue to HPI Blues all round and the car gained a bit of steering again. The HPI springs feel a little softer initially and I felt it gave the car a touch more grip. I stood the shocks up by one hole all round for the final to dial out some of the extra roll but the car just wasn't as fast. Next meet, I will lean the shocks back down. I will also try the split "rear upper deck" which I hope will soften the rear a tad.
SMOKEM --- HIRO SEIKO --- YOKOMO
veecee is offline   Reply With Quote
Old 11-06-2008, 02:01 AM   #3168
the blue might just have been too soft, try silver or even gold.
it seems to be out of fad but i ran some anti squat at the mm and it helped with rotation.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 11-06-2008, 03:31 AM   #3169
veecee's Avatar
Yes that did cross my mind as well - it worked well on the 415 too. Did you run 0.5mm/0mm or 1mm/0.5mm?
Old 11-06-2008, 02:07 PM   #3170
CraigM's Avatar
nah silvers are too stiff for Tempe (at night at least), I tried them and the car just skated around the track
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 11-06-2008, 04:22 PM   #3171
I had 1.0/0.0mm
Old 11-07-2008, 02:44 AM   #3172
Low_E's Avatar
Send a message via MSN to Low_E
Ed, I must be missing something.
I saw a setup from you somewhere, for medium grip track, using a one-way. It was a pdf-file, as usual filled in in red text ... but i can't find it now and I wanted to give it a go this evening.
COuld you pass a new link?
thou shall think twice or trice before hitting thee SEND-button
Low_E is offline   Reply With Quote
Old 11-07-2008, 10:58 AM   #3173
TryHard's Avatar
What about Pinks? they are between the blues and silvers... worth a punt if you want slightly stiffer
Low_E, the only ones I can think of are this http://www.thard.co.uk/download/file.php?id=4&mode=view and thishttp://www.thard.co.uk/download/file.php?id=5&mode=view
HiH
Ed
Old 11-07-2008, 03:34 PM   #3174
Low_E's Avatar
Hi Ed, thx for the reply, but no it wasn't one of those. I must have clicked on one of the 100 earlier pages by mistake within this thread and must have seen an older setup ...
ANyway, I tried the Jilles Groskamp-setup, and it went BEAUTIFLY! (with tyre-product on fulle R tyre and half F tyre.
I'l try to adapt this setup to a drive it with a One-way dough, as I prefer to drive One-way and will be competing in a 27T-class, where you can use all the speed you can get out of your chassis
Also, since it was not mentioned in Jilles's set-up, I guessed and used only 2mm as Front Upper Arm spacer. I'll test some more with this setting as I see most drivers around here using a 5mm-spacer in the front.
Old 11-07-2008, 03:56 PM   #3175
Trader Rating: 22 (100%+)
HiH
Ed
Pinks are harder than silver if you want inbetween blue and silver you need to get the Hara purple matched hard .290g/cm
pink .320
silver .302
blue .273
bjspinner is offline   Reply With Quote
Old 11-07-2008, 04:45 PM   #3176
hi guys, racing tonight and i think i reverse polarity the battery..i thought the speedo was dead but it turns out to be the battery, the last few weeks ive had problems with the car shutting down but i cant help wonder if it was battery related...has anyone blown a orion lipo coz of a short or could it be my battery developed and internal fault...do you rekon the orion importer would do anything to help me out??? ive put a volt meter over the pack and the neg side is dead pos side is 4 volt...
also i cant keep the car planted on the carpet, primafelt, i was expecting good things but i just cant get it to work, when i apply thottle the rear just kicks out a little so im always trying to catch it and also when i come into a fast corner off power it starts to do the same, i was told to run weight up front ie in the bumper as this is meant to help with the car wanting to throw the rear round, but it still want to kick it out...i might to back to the victor dhi setup and start again...does anyone have any good tip on that setup or anyothers that might help me out...
mark williams is offline   Reply With Quote
Old 11-08-2008, 05:20 PM   #3177
TryHard's Avatar
pink .320
silver .302
blue .273
Whoops, yup thats my bad... should have checked first :s Pink's are between the Golds and Silvers.
Old 11-08-2008, 05:35 PM   #3178
HI_808's Avatar
I've heard that Orion had trouble with 3800 lipos which is supposedly why the price has been dropping on those packs.
HI_808 is offline   Reply With Quote
Old 11-10-2008, 05:11 AM   #3179
RC MARKET's Avatar
new low friction damper
Tamiya TRF416 / TRF416WE / TRF416X-ta-42131.jpg   Tamiya TRF416 / TRF416WE / TRF416X-ta-42134.jpg
RC MARKET is offline   Reply With Quote
Old 11-10-2008, 05:55 PM   #3180
thekthai's Avatar
Default any new picture from 416 wce
TRF416WE (#42138) will include the following changes:
New Carbon Lower Deck
New Carbon Upper Deck
High Liubrication (HL) Dampers
New Motor Mount
Short Suspension Arms
New Front and Rear Belts
Front Spool
Teflon Sealed Bearings
anybody no about picture 416 wce .....pls come on....
thekthai is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
