Old 11-02-2008, 12:44 AM   #3136
Super Moderator
Grizzbob's Avatar
Originally Posted by mark williams View Post
hi mate, im using my lrp sphere tc spec with the lrp vector x11 10.5 motor so i would hope its not drawing too much current...orion 3800 lipo in use also..
No, you're right, that shouldn't be that bad a draw on your system, so I'd say go ahead & try the capacitor idea as we mentioned earlier, & if it still acts up badly, then maybe there's something going on with your ESC....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 11-02-2008, 03:34 PM   #3137
guinnes.s's Avatar
hi,i was looking at Jilles Groskamp setup using D,D,XA,E as suspension mounts.
is my impression or the use of this mounts will make the car wider then the stock one???
thanx
guinnes.s is offline   Reply With Quote
Old 11-02-2008, 03:46 PM   #3138
JamesArluck's Avatar
Trader Rating: 52 (100%+)
Send a message via AIM to JamesArluck
thanx
He's probably using the short suspension arms.
JamesArluck is offline   Reply With Quote
Old 11-02-2008, 03:53 PM   #3139
guinnes.s's Avatar
WHAT difference would make with short or long arms???
Old 11-02-2008, 04:18 PM   #3140
CraigM's Avatar
Trader Rating: 34 (100%+)
short arms = more grip
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 11-02-2008, 05:12 PM   #3141
Low_E's Avatar
Send a message via MSN to Low_E
thanx
should have looked a bit more intense:
Jilles clearly stated he used other A-arms: the evo-arms which are shorter.
but then ... his setup-page is such a mess I had difficulties reading it also
So I made a new one with his setup:
Jilles Groskamp HPI-setup (PDF-document)
thou shall think twice or trice before hitting thee SEND-button
Low_E is offline   Reply With Quote
Old 11-02-2008, 05:20 PM   #3142
guinnes.s's Avatar
SO IF I KEEP THE LONG ARMS I WOULD LOOSE GRIP.
I WILL TRY FIRST WITH THE LONG AND SEE HOW IT FEEL.
Old 11-02-2008, 10:12 PM   #3143
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
check this out fellas!
chedda bob made some steel plates for lipo users to fill a need for my 416 and 3800 orion packs. It fits like a glove and weighs almost 4 oz. putting it all down low where u want it instead of up on the pack. pm him or me if u want more info on them. .apparently he makes them for several aplications. I hope these attached pic work and are of assistance . notice that its totally stealthed out from the top. the pach locks into place and is totally flush with the bottom of the chassis.. nice work chedda!
give chedda bob a p.m. and he will be happy to help you find the right one for your car.
only 2 posts down from here,
Tamiya TRF416 / TRF416WE / TRF416X-10012.jpg   Tamiya TRF416 / TRF416WE / TRF416X-10013.jpg   Tamiya TRF416 / TRF416WE / TRF416X-10014.jpg   Tamiya TRF416 / TRF416WE / TRF416X-10015.jpg
John St.Amant is offline   Reply With Quote
Old 11-03-2008, 02:16 AM   #3144
CraigM's Avatar
It's a nice idea to have the bumps that fit the bottom of the pack. I assume it's lead if it weighs that much?
I still prefer my ppd, it's beautifully machined. Since I took these pics I've ditched the lipo lead because I went back to using a full weight body
http://www.rctech.net/forum/4698843-post8250.html
Old 11-03-2008, 03:08 AM   #3145
chedda bob's Avatar
Location: Where the ego's are so big, people's heads can't fit in the door
Trader Rating: 144 (100%+)
thanks again for the pics john, glad you like it bud
anyone thats interested shoot me a pm. ideally i would like $40 shipped for them as they are kinda a pita to machine, and thats including paypal fees, shipping, etc
Mike Legue~ Aka Chedda Bob, Chedda, Curly, Fester, the list goes on...
Losi 8B 3.0~ O.S. Speed Spec 2/ Nova 9901/ Savox HV servos/ Speed blend
Losi 8T 3.0~ O.S. Speed Spec 2 / Losi re-10/ Savox Hv servos/ Speed blend
Nankinhobby.com/ Punch RC/ Darkside Designs/ Murfdogg Motor Works
chedda bob is offline   Reply With Quote
Old 11-03-2008, 10:52 AM   #3146
Short arms do not equal more grip.
If you would think of it as changing the fulcrum point and how it effects the roll center you would see that its all about the ratio and angle of the upper arm to the lower arm and the position (triangulation) of the pivot points .
If a shorter arm could give you more grip the losi car would be world champ.
but if you also notice the upper arm is very short as well on the losi. Its all about the ratio of the 2 arms and their angle that they are mounted on. Usually a shoryet arm mean the lower inner mount is wider and thats what you need to look at. Not just the length of the arm. If I could see what lower hinge pin mounts he used .. probably 1E or even F if they exist... thats what you need to look at....
Old 11-03-2008, 01:05 PM   #3147
guinnes.s's Avatar
HE USE D,D,XA,E
Old 11-03-2008, 02:58 PM   #3148
CraigM's Avatar
thats what I said, short arms with the proper suspension blocks = more grip
fyi F blocks exist, but most setups use XA/E at the rear. Note that if you use D/D and XA/E your front track will be wider than the front by 1mm i.e. most setups using that combo use spacers in the rear. I prefer C/C XA/E and 1/2mm spacer in the rear
Old 11-03-2008, 03:49 PM   #3149
SammyZ's Avatar
Trader Rating: 138 (100%+)
what are the changes on the World Champion Edition?
SammyZ is offline   Reply With Quote
Old 11-03-2008, 03:54 PM   #3150
Hebiki's Avatar
Trader Rating: 26 (100%+)
two obvious ones i know of are the one piece top deck. and it comes with a spool. might have the new TRF shocks too. the other guys will chime in on what else is new.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 12:08 PM
TRF416 speedart Electric On-Road 26 06-27-2007 05:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 03:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 10:11 AM
SEO by vBSEO 3.5.0
