Old 10-29-2008, 05:16 AM   #3106
habis's Avatar
what you have done is general mistake and a easy mistake to make as the k-part is build both for the 416 and the 501x
the k-part is oval with the top having a arrow marking and bottom a dot marking.
on the 416 the dot marking should be pointing downward and arrow pointing upwards - oppersit on the 501x.
putting the k-part in the right mode would lower the position of your spool/oneway not to rub aganist the bulkhead.
if you have it wrong - just "flip" it
this is the best way of describing it....there is more info in this forum
habis is offline   Reply With Quote
Old 10-29-2008, 05:22 AM   #3107
Low_E's Avatar
Send a message via MSN to Low_E
but, correct me if I'm wrong, ... but the dot is actually pointing downwards!
As you can see on my picture.
Guess it must be the other way around then.
thx for the tip (which was obvious offcourse).
thou shall think twice or trice before hitting thee SEND-button
Low_E is offline   Reply With Quote
Old 10-29-2008, 07:40 AM   #3108
yeah, the round mark sould be up and the arrow mark sould be down!
RFrancis is offline   Reply With Quote
Old 10-29-2008, 08:20 AM   #3109
AWK
AWK's Avatar
Has anyone gotten any testing doen with the new 2.5mm chassis on asphalt? Any results or feedback you care to share?
AWK is offline   Reply With Quote
Old 10-29-2008, 10:32 AM   #3110
Adam?'s Avatar
Yeah, rotate the cam, dot up, arrow down. I did the exact same thing, and melted an outdrive, scratched my spool to hell, etc.
Are the plastic inserts for the spool available separately yet? Anybody know the part number?
Adam? is offline   Reply With Quote
Old 10-29-2008, 10:34 AM   #3111
Adam?'s Avatar
Also, the ball connectors on my steering linkage... the ones with 5mm of spacers underneath? Yeah, those are stupidly easy to bend, aluminum, or setscrew method. Is there some trick (aside from not hitting things) to making them last longer? They seem to do better with only 3mm of spacers, but that's a pretty significant ackerman change, isn't it?
Old 10-29-2008, 10:44 AM   #3112
Hebiki's Avatar
Trader Rating: 26 (100%+)
ran the 2.5mm at BCR using the same set up as my 2.25mm chassis. i liked it better compared to the old one. it freed up my car more.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 10-29-2008, 03:12 PM   #3113
I cut the head off a long 3mm screw and use it like a long set screw, use a shock top style ball stud.
Just note the the new ball is 1mm taller than the std stud, so you will need 1mm less spacing.
This method also allows you to go even more ackerman, which makes the car feel much better for me on low grip tracks.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 10-29-2008, 05:33 PM   #3114
CraigM's Avatar
Trader Rating: 34 (100%+)
how did you screw it in without a head on it another option is to use a long 3mm set screw (nitro cars have them, check parts from mugen/kyosho) and a hex headed pillow ball
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 10-29-2008, 06:57 PM   #3115
Just turn it into the alloy part with your fingers, and put your finger on the back of it in order to hold the threaded part still while you put the pillow ball in, once its finger tight, just nip it up with the 5.5mm driver.
I would prefer to get some long set screws but i have not found any, tobee craft do make long ones, RCModel have them, but my last order for parts was from RCMarket. Market only had short ones.
Old 10-29-2008, 10:25 PM   #3116
CraigM's Avatar
mushroom have them too, they have take off 3x10s if the 3x12s are too long. I think I've got a bunch anyway, will stick some in my kit for you if I do.
How many spacers were you running anyway? I tried 6mm as there was an MS setup that used that but the steering rods bump the suspension block, maybe 5.5 might be alright tho
Old 10-29-2008, 10:35 PM   #3117
Kool Thanks
I had the original shock ball, and i think 2, 3mm spacers. It brings the ball cups to within around 1mm of the toe block. I found that it gave the car a lot more mid to exit steering that it was really lacking before.
This is with the ackerman on the rear holes in the upright of course.
Old 10-30-2008, 03:05 AM   #3118
Low_E's Avatar
About Ackermann, what are the advantages of putting more ackermann (like 5mm shims in stead of the manual-3mm)
I've heard people tell me you needed little ackermann, others tell me 5mm is the way to go on the 416. Confusing.
[edit]
Did some research on the net.
found some articles ...
amongst those:
source: http://www.smithees-racetech.com.au/ackerman.html
Originally Posted by racetech.com.au
When Would You Use Ackerman (or Anti-Ackerman)?
* When you set the negative camber, based on the tyre temperature readings for instance, you are maximising outside tyre grip, at the expense of inside tyre grip. Toe out helps to compensate for negative camber on the inside tyre. This indicates pro-Ackerman might be usefull for cars carrying a lot of negative camber.
* In using Ackerman steering we hope to be able to influence the slip angle on the inside tyre to our advantage. There will be a range of slip angles where the inside tyre will be producing near maximum grip (Figure 3). So we have a degree of flexibility in how much Ackerman we use.
* To rotate the car on corner entry we are talking about creating increasing drag at the inside tyre. As the cornering force builds the inside tyre must at some point reach it's optimum lateral grip. We then use Ackerman to toe the tyre out further - say increase the slip angle a couple of degrees. The tyre grip doesn't change that much but the longitudinal component of tyre grip, the tyre drag, does increase in line with the increased slip angle. For this to work we would need to know that we have sufficient steering angle to generate the Ackerman needed.
* If in the process above, we started to loose outside tyre grip, and the driver wound on some more lock, we would have increased drag at the outside tyre. We would then loose the effect. The oversteer torque we were looking for would be overcome by the larger understeer torque.
* The above indicates that pro-Ackerman would probably not work with low powered cars in fast corners. It might also be a problem generally with heavy cars with spool or locker diffs that might want to push a bit, such as V8 Supercars.
* With pro-Ackerman, the higher slip angle on the inside tyre will put more heat into the tyre. This will help bring the tyre up to temperature, but could overheat the tyre on a longer run.
* If our race car is faster with toe in, we will use anti-Ackerman. This implies a tyre curve where the lightly loaded inside tyre has maximum grip at a lesser slip angle (Figure 6a)
* Sprint cars and similar speedway, dirt short circuits, can make a lot of use of varying degrees of pro-Ackerman. With dirt tyres we expect very large slip angles. Nascars and similar will use anti-Ackerman (Figure 6a).
* With low profile tyres the slip angles will be a lot less. The tyre drag will be less. The slip angle on the inside tyre will have a smaller drag component (Figure 8). So it may be
* more difficult to use pro-Ackerman to create the oversteer torque. The toe out from the slip angles will be less. The slip angle variation from outside to inside tyre will be a smaller number, requiring different Ackerman to achieve what we want. We will probably use initial toe out to help turn in. The idea is to get the inside tyre working as discussed earlier. Other settings you would use to help initial turn in are stiffer front shocks, and higher front roll centre height. By delaying the roll we help to keep the weight on the inside, to again keep the inside tyre working.
* We make the assumption that the outside wheel will always have the ideal trajectory, with all the toe out being seen at the inside wheel. This may not always be the case. For instance, if the car has a lot of caster and/or caster trail this might have the effect of splitting some of the toe to the outside wheel. If the outside wheel does take on some of the toe out, this will decrease slip angle and the outside wheel will loose grip.
now reading these and trying to understand them
Old 10-30-2008, 03:32 AM   #3119
Low_E's Avatar
anyone knows a link to an editable PDF-setupsheet for the 416?
Or one you can fill in and then print?
*** edit **
found one:
http://www.petitrc.com/reglages/tami...nkEditable.pdf
Old 10-30-2008, 04:32 AM   #3120
veecee's Avatar
Kool Thanks
Just tried 6mm ackerman and it seems to clear on the bench. I used a long set screw with teflon coated balls so only 5mm of spacers were needed. More mid to exit steering sounds very promising - can't wait to try.
SMOKEM --- HIRO SEIKO --- YOKOMO
veecee is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
