Old 10-21-2008, 12:35 AM   #3046
HI_808's Avatar
Originally Posted by Adam? View Post
Are the aluminum rear uprights for the TA05-IFS compatible?
http://www.tamiyausa.com/product/ite...oduct-id=84005
I think that those are for the 950 bearings. The TB03 uses 1050 bearings like the 416 and would use the same rear upright.
HI_808 is offline   Reply With Quote
Old 10-21-2008, 01:00 AM   #3047
Drifting101's Avatar
Originally Posted by Barry White View Post
416 Jatabe Arena:
That motor looks cool
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
Old 10-21-2008, 10:33 AM   #3048
sakaguchinet's Avatar
Send a message via ICQ to sakaguchinet Send a message via AIM to sakaguchinet Send a message via Skype™ to sakaguchinet
Hi,
the new Transpeed BL Motors should be the new X12 Generation (on the pic the X11 is showed).
About the Volac Speedo i didn't find any infos (SPX Stock or TC Software).
The WE Changes:
- new Lower Deck
- new Upper Deck
- Black Bumper
- Evo5 Sus Arms
- Spool Inside
- new HL Special Dampers (not sure)
- Sus Blocks fitted (think 1C-1C and 1XA-1F) - because of the blade compatiblity
- new Sawteeth Design Wheel Nuts (Square SGE-14STB)
- new Motor Mount Plate (reinforced)
Best Regards,
Dai
http://www.rc-square.de (German and English manufacturers site)
http://www.sakaguchinetshop.com (Tamiya TRF related stuff)
sakaguchinet is offline   Reply With Quote
Old 10-21-2008, 10:43 AM   #3049
AWK
AWK's Avatar
TRF416WE will include the following changes:
  • New Carbon Lower Deck
  • New Carbon Upper Deck
  • High Liubrication (HL) Dampers
  • New Motor Mount
  • Short Suspension Arms
  • New Front and Rear Belts
  • Front Spool
  • Teflon Sealed Bearings
AWK is offline   Reply With Quote
Old 10-21-2008, 10:58 AM   #3050
TeamB&B's Avatar
  • New Motor Mount
  • Front Spool
Will the shocks be the shorter version? Therefore lowering the body mounts so the NSX body will fit properly.
RCAmerica / Sweep
TeamB&B is offline   Reply With Quote
Old 10-21-2008, 11:20 AM   #3051
AWK
AWK's Avatar
Even if the shocks were shorter, the IFS bodies will never work in the 416. We have the M Chassis TRF dampers (54000), but that is not what prevents the IFS bodies from working. It is the damper mount itself. The HL dampers will be like the regular sedan TRF dampers, but with a new coating.
Old 10-21-2008, 04:09 PM   #3052
CraigM's Avatar
Trader Rating: 34 (100%+)
I tried out the v-dezign 1pc deck last night. I had originally intended to try it back-to-back with the 2pc without making any other set up changes but my car was not great in the first heat so I ended up changing a few things on the front suspension at the same time as putting it on. What I noticed straight away was how responsive the car was at the front while being glued at the rear. I figure the responsiveness was a result of the slightly increased stiffness and the rear grip was from the removal of the crossmember. I only ran it for the one heat and a few laps in the final (DNF ) so will post more once I've tested it further, but I'm pretty happy so far
Originally Posted by Hebiki View Post
if square makes a set, a link would be awesome so i can purchase a set.
I got mine from rcchamp, rc-market.com.hk have them too
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 10-21-2008, 04:10 PM   #3053
Low_E's Avatar
Send a message via MSN to Low_E
one thing, Tamiya might consider in producing is a nice metal Lipo-tray in Tamiya-blue-color
Just to add some weight under the Lipo where it is best.
I'm certain, a lot of people would be interested in Blue metal Lipo-weight-tray.
thou shall think twice or trice before hitting thee SEND-button
Low_E is offline   Reply With Quote
Old 10-21-2008, 04:44 PM   #3054
Trader Rating: 26 (100%+)
does anyone know when the 416 we will be on hobby shop shelfs. also where can i find some rubber carpet setups(preferably rheinhards)
eddie10 is offline   Reply With Quote
Old 10-21-2008, 05:15 PM   #3055
Trader Rating: 111 (100%+)
I am looking for the Same for Setups(13.5/Rubber/Lipo)
Dave
dragracer72nova is online now   Reply With Quote
Old 10-21-2008, 05:54 PM   #3056
miccal's Avatar
Trader Rating: 23 (100%+)
It may be too early to ask, but does anyone know if all the new parts for the TRF416WE will be available as an upgrade package for people who already own the TRF416, or will it just be a whole new kit?
miccal is offline   Reply With Quote
Old 10-21-2008, 07:41 PM   #3057
CraigM's Avatar
Dave
well a 13.5 setup probably wont be the same as marcs mod setups, but there are a bunch of good rubber and carpet setups on www.thard.co.uk
Don't think the Euros or Andernach ETS set ups ever saw the light of day but from what I saw they weren't greatly different from the reedy race ones. If you have C/C up front, XA/E on the rear, and 3mm under every camber link then you are pretty close to spot on for rubber
Old 10-21-2008, 10:00 PM   #3058
Hebiki's Avatar
Dave
i have a set up for asphalt/rubber. not sure if you want to "gamble" trying it out. its pretty aggressive. let me know ill send it to you.
this is on a med. bite outdoor asphalt track using RP36 tires and a mazdaspeed6 body and 13.5BL.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 10-21-2008, 11:01 PM   #3059
Adam?'s Avatar
Does Tamiya (or anybody) make the toe blocks in a harder material? I'm tearing through 1D blocks up front lately, and it's starting to suck. Yeah, I've got longer screws through them.
Adam? is offline   Reply With Quote
Old 10-22-2008, 01:56 PM   #3060
TryHard's Avatar
Originally Posted by CraigM View Post
p.s. where you been Ed??
I've been off sailing for a few weeks, only got back on Monday, so been keeping it all a bit quite.
Itching to see the new WC car proper... have finally managed to find a proper picture of the revised motor mount as well (have a look at the ETS series round 1 gallery).
Need to break the car out thise weekend, giving 17.5 a go at the local club... should be a
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
