Old 10-07-2008, 03:48 PM   #2971
JamesArluck's Avatar
Trader Rating: 52 (100%+)
Send a message via AIM to JamesArluck
Make sure the threads of the grub screw and hole are clean and don't have grease in them. Then use a small amount of threadlock on the grub screw.
JamesArluck is offline   Reply With Quote
Old 10-07-2008, 03:50 PM   #2972
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by CraigM View Post
OK so I threw both front CVD pins at racing last night, one in the first heat and one in the final I haven't cleaned or greased them since I built the car, so I'm thinking this is just a result of that. Do you guys have any other tips? I've heard of people filing a flat spot where the grub screw goes, and putting some heat shrink around the outside over the hole to stop them exiting into the steering knuckle, but I'm not sure if there is anything else I should do?
i locktite the grub screw and tighten it down real tight. ive noticed i only have them back out when i hit curbs pretty hard/crashes.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 10-07-2008, 04:39 PM   #2973
CraigM's Avatar
Trader Rating: 34 (100%+)
thanks guys yeah I do all that already. Now you mention it I think it might be the a result of running on a bumpy track over the weekend
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 10-07-2008, 07:42 PM   #2974
Trader Rating: 21 (100%+)
I file a flat spot on the pin. Not sure if shrink will fit inside the knuckle though.
Thanks to pops
TLR, Fantom, Horizon, Spektrum, Trackside
Brian L is offline   Reply With Quote
Old 10-08-2008, 02:13 AM   #2975
Vesa's Avatar
Send a message via ICQ to Vesa Send a message via MSN to Vesa
Here is a photo picked from a CAD-model.
Top decks are available next week!
V @ V-Dezign
Sponsored by: V-Dezign | Nosram | Reedy | Black Art | TQ Wire | Horizon hobby | Xenon Racing | Badger airbrush | RC-Trim.com
Web - www.v-dezign.net | Facebook - www.facebook.com/vdezign
Vesa is offline   Reply With Quote
Old 10-08-2008, 11:52 AM   #2976
Hebiki's Avatar
curious, whats the idea behind the "solid" upper deck? anyone care to explain?
Hebiki Design Works
Old 10-08-2008, 06:32 PM   #2977
subaru73's Avatar
Trader Rating: 41 (100%+)
Default 416
I would be willing to guess less flex good for carpet or high bite surface.
Tamiya Ta07 Tamiya evo5 ms,Tamiya Ta05r Tamiya FF04 rm01 Tamiya Ff03R
Futaba 4Px radio lrp speed control
Cfx paint works Fantom Racing apex Rc tq hobbies acer racing Hebki design works
subaru73 is offline   Reply With Quote
Old 10-08-2008, 06:54 PM   #2978
More flex, allows you to leave out some extra screws.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 10-08-2008, 07:18 PM   #2979
94eg!'s Avatar
Trader Rating: 17 (100%+)
Definitely more flex. The one-piece top deck removes the cross-brace behind the spur...
94eg! is offline   Reply With Quote
Old 10-09-2008, 12:50 AM   #2980
HI_808's Avatar
Looks like it could give more rear end lateral flex and less longitudinal flex.
HI_808 is offline   Reply With Quote
Old 10-09-2008, 01:31 AM   #2981
great stuff..
miza is offline   Reply With Quote
Old 10-09-2008, 02:53 AM   #2982
Vesa's Avatar
Hi guys,
the new deck has more flex in rear of as there is no cross brace on rear bulk.
The deck itself is a bit stiffer than the standard deck but and has been tested to be used without the steering screw on it.
Taking off the screw from stering deck/bridge gives more flex which improves steering, especially more on-power steering going out of the steering.
Decks are available, contact me for pricing and more information with pm or email vesa@v-dezign.net
-Vesa-
V @ V-Dezign
Old 10-10-2008, 08:46 AM   #2983
Trader Rating: 28 (100%+)
Default spare belt
I am looking for the replacement belts for the 416 and I found 2 part numbers for both front and rear. Which one do I need? The front belt part numbers are TA51343 or 6244016 and the rear part numbers are TA51344 or 6244017.
Thanks.
joech is offline   Reply With Quote
Old 10-10-2008, 09:02 AM   #2984
sakaguchinet's Avatar
Send a message via ICQ to sakaguchinet Send a message via AIM to sakaguchinet Send a message via Skype™ to sakaguchinet
Thanks.
Hi,
if you are looking for spare parts just look here:
http://sakaguchinet.dyndns.org/sites...spareparts.htm
So you can see there are two regular SP numbers for the TRF416 belts.
Best Regards,
Dai
http://www.rc-square.de (German and English manufacturers site)
http://www.sakaguchinetshop.com (Tamiya TRF related stuff)
sakaguchinet is offline   Reply With Quote
Old 10-10-2008, 12:12 PM   #2985
RC MARKET's Avatar
Thanks.
F 51343
R 51344
2 items instock
RC MARKET is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
