Old 10-03-2008, 09:52 PM   #2941
mac853's Avatar
Originally Posted by mild seven View Post
I'm guessing the new 416 will come with a locked front diff and center pulleys.
What is locked front diff?
Not same as spool?
Do you mean that kind of TC5's slipper spool?
mac853 is offline   Reply With Quote
Old 10-03-2008, 10:32 PM   #2942
mild seven's Avatar
Trader Rating: 62 (100%+)
Send a message via MSN to mild seven
sorry, yeah i mean like a spool (solid axle).
mild seven is offline   Reply With Quote
Old 10-04-2008, 12:21 AM   #2943
mac853's Avatar
OK well, just misunderstanding.
How about titanium turnbuckles and new belt drives(i saw M. Rheinard used some prototype belt in europe). Longer topdecks are also good and i wish steel swing shafts, rather those "bad" aluminium ones, which i saw someguy broke in the 1st race, but, if they will include aluminium rear axle will not be bad, in the case i never broke mines of trf415 in the rear.
Then anybody could tell me why wish using AH spring rather than TRF ones.
As i know the hardness between of different AH springs are closer than TRF ones.
Old 10-04-2008, 06:57 AM   #2944
myan_gsr's Avatar
Hey guys,
Not sure if this has been discussed before.
http://www.tamiyausa.com/product/ite...oduct-id=42138
Perfect timing too, I'm due for an upgrade
---Tamiya 416X---Tamiya TRF416WE---Tamiya TA05R---Tamiya F104 Pro ---Tamiya F103R 15th Anniversary ---Tamiya F103---Tamiya F103GT---Tamiya TL01---
www.brccc.org
myan racing (coming soon)
myan_gsr is offline   Reply With Quote
Old 10-04-2008, 07:21 AM   #2945
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
Isn't that an black top set up?
I race on carpet and would hope that it would include a one way front diff and a one way center shaft. (and billtett rear uprights) lol
John St.Amant is offline   Reply With Quote
Old 10-04-2008, 02:36 PM   #2946
hi guys, i have a setup question...what is the effect of running shorter top camber links on the 416 or any car coming to that..also if i shorten the top rear camber link and move the ball joint in towards the car on the rear upright what will this do for the handling, does the same answer apply to shortening the front camber link and moving the ball joint towards the outside of the car..hope this makes sense..many thanks in advance
mark williams is offline   Reply With Quote
Old 10-04-2008, 07:18 PM   #2947
HI_808's Avatar
Shorter links equals higher roll center and less roll.
HI_808 is offline   Reply With Quote
Old 10-04-2008, 09:03 PM   #2948
t4m1y4niac's Avatar
and..what happen with "less roll"?
SABRE S4 by TOP RACING....
t4m1y4niac is offline   Reply With Quote
Old 10-05-2008, 01:22 AM   #2949
CraigM's Avatar
Trader Rating: 34 (100%+)
less grip
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 10-05-2008, 01:00 PM   #2950
Well... figure that most cars come with anti-roll bars fromt and some times rear as well. Perhaps the manufacutrers are trying to tell you something there. Either they expect you to run on a farily good surface with good traction, or they just want to say that (sway bars) are a good idea. But If theres so much traction that your cars seems to pitch before yaw then perhaps a stiffer spring may help. But the bar combines the springs at a rate of the diameter of the sway bar. But on the other hand some say that the bar affects the responce time (slower) of the car in transition. Either way {stiffer spring / sway bar} u are giving up grip. I believe in running the softest spring possible for mechanical grip... and using anti-roll bars front and rear to adjust the balance front to rear. A thicker bar makes the car stay flatter in the turns but decreases the lateral traction. In front its is refered to slip angle.
Old 10-05-2008, 01:08 PM   #2951
chewiefttc4's Avatar
Trader Rating: 26 (96%+)
Send a message via AIM to chewiefttc4 Send a message via Yahoo to chewiefttc4
who let this cat in the back door ?
great post john
this wouldnt be the john from larrys would it ? if not i apologize for the above statement
chewiefttc4 is offline   Reply With Quote
Old 10-05-2008, 08:49 PM   #2952
moog's Avatar
Hello
I found a few pictures, of the TRF 416 World edition
http://www.anonym.to/?http://www.rc-...75&pg=1&anch=2
There is new absorbers High Lubrication, spool, better engine owner and a whole Topdeck.
Thatīs all.
( Sorry for my Englisch)
greetz moog
moog is offline   Reply With Quote
Old 10-05-2008, 09:27 PM   #2953
t4m1y4niac's Avatar
is the motor position on 416 WE more backward than original 416???
Old 10-05-2008, 11:20 PM   #2954
Drifting101's Avatar
Looks a fair bit different when i saw a pre release shot from tamiya
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
Old 10-06-2008, 03:03 AM   #2955
CraigM's Avatar
Originally Posted by moog View Post
Hello
Thatīs all.
greetz moog
short arms and the rear belt marc rienhard was using at euros, centre belt doesn't look to have the red dots tho - I'm wondering if thats the real deal
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
