Old 08-08-2008, 04:55 PM   #2686
syndr0me's Avatar
Trader Rating: 32 (100%+)
Originally Posted by Hebiki View Post
all the 416s here are doing great on asphalt... whats the bite like at your local asphalt track? and what tires are you using?
premounted RP30s and Sorex 36Rs are the predominant tires at the two asphalt tracks i race at.
It's probably the track. It's dusty, untreated asphalt, with only WD40 as sauce. The car never really turned right. The problem is, other guys have their cars turning incredibly well. I was using Sorex 28/32, and Jaco blues. I actually had the best luck with the Sweep Advantage tires, but they're impossible to find now.
I tried Victor's Reedy setup thinking it would be a good start for low grip, but no luck. :-(
syndr0me is offline   Reply With Quote
Old 08-08-2008, 05:01 PM   #2687
Hebiki's Avatar
Trader Rating: 26 (100%+)
sent you a PM. where is victor's reedy set up located? tryhard's website maybe?
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 08-09-2008, 12:43 AM   #2688
Stein Tumert's Avatar
Yes
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
Old 08-09-2008, 01:14 AM   #2689
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Have you tried softening the suspension? Go softer springs and more droop...
Racing4Evo is offline   Reply With Quote
Old 08-09-2008, 01:18 AM   #2690
TryHard's Avatar
If you want more steering, drop the front roll bar to soft... worked wonders for me on a tight and twisty track. I'm having to dial it out now!
HiH
Ed
Old 08-09-2008, 01:35 AM   #2691
Hoggy's Avatar
i too have the same problem car has alot of push and not enough steering. has anyone tried the car without sway bars?
Hoggy is offline   Reply With Quote
Old 08-09-2008, 02:03 AM   #2692
CraigM's Avatar
Trader Rating: 34 (100%+)
If you guys are having trouble with steernig on tarmac try one of the setups Ed, Vincent (veecee), or I posted a few pages back
edit: they are all here http://www.petitrc.com/reglages/tami...miyaTRF416.htm
If you still have problems your diff is probably too tight, or your tyres are shot
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 08-09-2008, 08:42 AM   #2693
miccal's Avatar
Trader Rating: 23 (100%+)
I have also had a lot of push with the TRF416, but I am finally homing in on a setup that works on outdoor asphalt. However, my setup is absolutely nothing like the setups that are being posted in this thread. The point is don't be afraid to move far from the setups that the factory drivers are using.
miccal is offline   Reply With Quote
Old 08-09-2008, 10:10 AM   #2694
syndr0me's Avatar
I'm not running anymore asphalt for a while (praise be thy name), but when I was having this trouble, it was always with fresh tires. Taking the sway bars off entire did seem to give more steering overall, but introduced other issues. If I get stuck running asphalt again next season, I'm tempted to try a plastic TA05. That thing should generate some grip, huh?
Old 08-09-2008, 11:23 PM   #2695
Hebiki's Avatar
when all else fails... NEW TIRES!
Hebiki Design Works
Old 08-10-2008, 02:09 AM   #2696
There is too much weight to the rear of the car. I moved the entire chassis forward by using the suspension spacers. Also used soft sways in the front and higher roll center for the rear. Rear toe is 2deg. Used the inner hole for the steering knuckle and got pretty good amount of ackerman. Now the car almost turns too much.
redbones is offline   Reply With Quote
Old 08-11-2008, 02:19 PM   #2697
hi,if I change the angle of the shocks what does t happen?if i put more degrees of angle it will be softer or harder??
www.federicoleo.net
fleo is offline   Reply With Quote
Old 08-11-2008, 02:22 PM   #2698
Hebiki's Avatar
it'll be softer.
Hebiki Design Works
Old 08-11-2008, 04:01 PM   #2699
Randy Caster's Avatar
Trader Rating: 45 (100%+)
I don't have my car yet, so I can't help as far as giving a setup to those who are having problems with the car pushing, but after seeing the video from the Euro's and watching Marc's car on the track, there is definately a way to get a ton of steering out of the car.
As soon as I get mine going, I'll post a setup, my cars usually have a ton of steering and very little rear traction, but traction should be easy to dial in to find a happy medium for most everyone.
Old 08-11-2008, 05:01 PM   #2700
RC MARKET's Avatar
good link !
RC MARKET is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 12:08 PM
TRF416 speedart Electric On-Road 26 06-27-2007 05:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 03:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 10:11 AM
SEO by vBSEO 3.5.0
