Old 08-01-2008, 02:19 PM   #2641
TryHard's Avatar
Originally Posted by Hebiki View Post
...not 3.5 like the pros do. so their crashes are more spectacular.
why thank you or should that be "not so-" pro...?
Old 08-02-2008, 09:13 AM   #2642
Randy Caster's Avatar
Trader Rating: 46 (100%+)
What's up guys. I'm really excited to announce that I've signed back up with Tamiya.
I cant wait to get my 416, the car looks awesome. As soon as I get the car built up I'll be on here with support for anyone who needs it.
Steel vs. aluminum up front, the steel just lasts longer. Aluminum is still plenty strong, they just wear extremely fast with low turn motors.
Old 08-02-2008, 10:09 AM   #2643
STLNLST's Avatar
Trader Rating: 19 (100%+)
I also feel that the steel can hold up in a crash a little better.(IMO) but we all can't be great like you... Marcos Caster!!!!
STLNLST is offline   Reply With Quote
Old 08-02-2008, 12:36 PM   #2644
steveonamission's Avatar
Nice one Randy
You should'nt of left in the first place, ohwell you learn from your mistakes
Good luck with it.
steveonamission is offline   Reply With Quote
Old 08-02-2008, 02:19 PM   #2645
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default 416 in stock....
for those looking for a 416... i stopped by SpeedtechRC. he has them in stock.
http://www.speedtechrc.com/store/ebp...il.asp?id=6970
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 08-02-2008, 02:42 PM   #2646
TryHard's Avatar
...don't...need...a...spare...car....
Old 08-02-2008, 05:45 PM   #2647
Need some advice on gearing my TRF 416.
I use Vortex 5.5 brushless. Can someone tell me, what spur and pinion size should i use to avoid overheat my engine and esc and at the same time i can utilize the speed of the engine?
Here we have a track that have straight line about 30-40 meters.
ichigo1661 is offline   Reply With Quote
Old 08-03-2008, 12:10 AM   #2648
Hebiki's Avatar
you dont even know how TEMPTED i am to get another one.
Hebiki Design Works
Old 08-03-2008, 09:57 AM   #2649
Woop
Tamiya 1st/2nd at the EUROS
Congrats
Old 08-03-2008, 12:37 PM   #2650
RC MARKET's Avatar
Originally Posted by steveonamission View Post
Woop
Congrats
RC MARKET is offline   Reply With Quote
Old 08-03-2008, 02:13 PM   #2651
Now I really can't wait to get the 416, lol
Old 08-03-2008, 02:55 PM   #2652
TRF415boy's Avatar
ahh, Mr Smith I assume?
Easy, there's two collars holding the front hub in place. In the standard instructions, you place the collars in first, with the flanges against the steering knuckle. To lower the hub, flip the lower one (so the flange is now facing the ground), and bingo, the knuckle is 0.5mm lower. As I'm using the 3racing alloy c-hubs, I've now got a single 1.5mm shim above the knuckle to take up the difference.
What you doing in here anyway? wrong colour isn't it?
Ed
Ha ha funny i did that on the kyosho too... Trying to get the bitch to steer...
TRF415boy is offline   Reply With Quote
Old 08-03-2008, 04:12 PM   #2653
CraigM's Avatar
Trader Rating: 34 (100%+)
What should I do to stop my car breaking rear traction mid-to-late corner off throttle? I was practicing yesterday and this seemed to happen after the (admittedly quite worn) tyres heated up, e.g. about 2-3mins into the run. It seemed like in longer off throttle corners the car would roll too much at the rear and then try and break rear traction, but if I tried to stiffen the rear it would make things worse. I guess the question is how can I reduce roll while maintaining rear grip? I was thinking of raising both roll centres, but might try new tyres before anything else
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 08-03-2008, 11:46 PM   #2654
Does the car feel good at the beginning of the run and only starts to have the problem when the tires get hot?
Old 08-04-2008, 04:02 AM   #2655
hey guys whats the piston hole diameter on the kit pistons?
cheers
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
