Old 06-23-2008, 01:06 AM   #2386
TryHard's Avatar
Originally Posted by Vicko View Post
hey I have an question on the toe blocks
so there are 3 different types
the A,B the 1A,1B and the 1XA, 1XB
so they are all different, so which types have the lowest suspen pin postion?
(mount the arms are lower to the chassie?
can anyone tell me
Actually there are only two types.
The A, B, C, etc blocks are from the TB Evo4, and are 1mm higher than the 1A, 1B, 1C etc. The 1XA, 1XB (refered to as 'X series') are narrower versions of the 1A, 1B, etc. As Toughbeard has mentioned, theres a chart on my site that details what toe angles all the blocks give, plus a more detailed description of the blocks.
The '1' series of blocks are the ones that are most commonly used, but most people (myself include) tend to write these down without the 1... hence some of the confusion. Generally though, if someone says they are using XB/D, they tend to mean 1XB/1D.
HiH
Ed
Old 06-23-2008, 04:14 AM   #2387
CraigM's Avatar
Trader Rating: 34 (100%+)
http://www.redrc.net/2008/06/tamiya-...c3/#more-10071
anyone know if the battery brace fits the standard chassis? also when it'll be available
I broke a steering knuckle over the weekend. Absolutely spewing because it knocked me out of the meet. I thought it was a c-hub which I have plenty of spares of but no. boo
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 06-23-2008, 08:45 AM   #2388
syndr0me's Avatar
Trader Rating: 32 (100%+)
Aluminum steering blocks + plastic c-hubs (TA05-IFS style) = indestructible. The plastic c-hubs flex a lot, but it actually seems to help in lower traction.
syndr0me is offline   Reply With Quote
Old 06-23-2008, 10:54 AM   #2389
teabag's Avatar
Originally Posted by Toughbeard View Post
I always keep a copy of the toe block chart that Ed made. you can get it from www.thard.co.uk
he also has many stuff there that will be useful as well...
Where is the chart on the website? Can't seem to locate it.
teabag is offline   Reply With Quote
Old 06-23-2008, 01:24 PM   #2390
TryHard's Avatar
http://www.thard.co.uk/viewforum.php...1f4709fe7ed21d
Old 06-23-2008, 01:47 PM   #2391
Eirik's Avatar
Originally Posted by TryHard View Post
Hey Ed,
Did you ever get the e-mail with my setup?
Have not heard from you in a while mate....
Later,
Eirik
Eirik is offline   Reply With Quote
Old 06-24-2008, 12:40 AM   #2392
TryHard's Avatar
Originally Posted by Eirik View Post
Hey Ed,
Later,
Eirik
YGEM(ail)
Old 06-24-2008, 03:25 AM   #2393
does anyone know the part number for the replacement cups for the 416 spool? Will the old 415 cups (the white ones, 9804268) fit?
omoser is offline   Reply With Quote
Old 06-24-2008, 03:26 AM   #2394
RC MARKET's Avatar
2.5mm lower deck
Tamiya TRF416 / TRF416WE / TRF416X-ta-49495.jpg
RC MARKET is offline   Reply With Quote
Old 06-24-2008, 09:49 AM   #2395
Number is 9804268, having problems with them.
Broke 4 in 3 weeks, not indoor not hitting any curbs, they just brake in mid corner using element 19t.
Anyone else have this problem.
Arnold
Arnold B is offline   Reply With Quote
Old 06-24-2008, 10:09 AM   #2396
RC MARKET's Avatar
Arnold
we used MOD BL motor not have this case !
Old 06-24-2008, 10:40 AM   #2397
Juanchoyo's Avatar
Default Couple of questions :D
Hi, this is a photo from the TB V MS
http://www.rceasy.com/wp-content/upl...2107photo5.jpg
But this car uses the same suspension parts as 416 and the question is: Do you change rear toe by chagign the alum. long part that holds suspension shafts?? Or change the rear hubs like in a mini? How's this blue alum part named?
Would this ride be really good (416) to run 10.5 and 6 cells? Or I'm better going with TB 5MS?
Juanchoyo is offline   Reply With Quote
Old 06-24-2008, 01:00 PM   #2398
StickyFingaz's Avatar
Trader Rating: 12 (88%+)
Hey guys,
Has anyone experimented with raising the differential/spool using the cams. What does this achieve?
-Martin
Team Tamiya/TRF - Team KO PROPO - NorCal Hobbies
StickyFingaz is offline   Reply With Quote
Old 06-24-2008, 01:41 PM   #2399
TryHard's Avatar
416 works very well in 10.5/LiPo... it's the class I largely run in.
The part you are refering to is the suspension blocks. You'll see them quoted on here as 1D, 1E etc. They are how you adjust toe-in. The hub are 0 toe-in.
HiH
Ed
Old 06-24-2008, 03:16 PM   #2400
Originally Posted by StickyFingaz View Post
Hey guys,
-Martin
It achieves a locked drivetrain. Unfortunately the way the bulkhead is designed, if you flip the cams, the outdrive rub the bottom of the bulkhead and lock up the drivetrain
DOTMAN is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
