Old 05-28-2008, 03:15 AM   #2251
t4m1y4niac's Avatar
guys, my front spool is touching the upper bulkhead....any tips???
SABRE S4 by TOP RACING....
t4m1y4niac is offline   Reply With Quote
Old 05-28-2008, 03:44 AM   #2252
CraigM's Avatar
Trader Rating: 34 (100%+)
Which part of the spool is touching which part of the bulkhead?
make sure you have the arrows on the bearing carriers pointing down as per the instructions
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 05-28-2008, 04:16 AM   #2253
t4m1y4niac's Avatar
the blue alum that protect the out drives....... okay i'll check it out...thx craig
Old 05-28-2008, 10:05 AM   #2254
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Hey guys, would you please be so kind to help me understand the Tamiya suspension block system? What's 1A, 1B, D, X, etc? Mayb there's a link where all of this is explained better?
yyhayyim is offline   Reply With Quote
Old 05-28-2008, 11:28 AM   #2255
TryHard's Avatar
http://www.thard.co.uk/viewtopic.php?f=24&t=30
Old 05-28-2008, 02:20 PM   #2256
StickyFingaz's Avatar
Trader Rating: 15 (89%+)
Just wanted to say that the car performed well for me @ the recent Reedy Race of Champions in Roseville, CA. A lil more horsepower and I think I could have been an A-main contender (I was in the B). My 13.5 motor was lacking a few ponies, I think.
The car was so free, barely any tire squeal. Super easy on the handout Sorex 36's. I will post the setup if anyone is interested...
On a different note, I asked Satoshi why Tamiya didn't include the "X" blocks and the short suspension arms in the kit. He responded by saying that in Japan, there are many beginners that probably couldnt handle the complexity and tunability of the short arm setup, so they include the stock arms instead.
He also said that they ALWAYS use the short am setup... something that I will be sure to upgrade to in the near future.
Get the $%^& out of my way.
StickyFingaz is offline   Reply With Quote
Old 05-28-2008, 09:02 PM   #2257
CraigM's Avatar
Questions??
did anyone end up getting any of the hemestede (or however you spell it) setups from the round of ETS? I'm racing on a very similar track this weekend and would like a solid starting point
Old 05-29-2008, 04:46 AM   #2258
CraigM's Avatar
yeah this happens when you use less than 4mm of spacers (could be 3mm) on the inner camber link. You can either add more spacers or use a shorter ball headed screw, I think 8mm is the standard so you could try the 5. I think if you need to go that low with the spacers though you should just move one hole further out
Old 05-29-2008, 06:01 PM   #2259
Default RE
Hey guys heres my setup from reedy race. I used tryhards redone setup sheet(kudos, much easier )
Track changed quite a bit but this was basically what i ran for all my timed runs.
Tamiya TRF416 / TRF416WE / TRF416X-reedy-race-setup.jpg
Corey "Whitey" Whiteman
TAMIYA- www.tamiya.ca
LRP- www.lrp-electronic.de
Reedy batteries
Protoform- www.pro-lineracing.com
Parma- www.parmapse.com
APS racing- www.aps-racing.net
www.muchhobby.com
TRFwhitey is offline   Reply With Quote
Old 05-29-2008, 06:16 PM   #2260
TryHard's Avatar
Cheers for the props on the sheet... though not a problem at all to do it
Quick Q, what was your thoughts on running the rear shocks all the way in on the arms? Moving them in effectively softens off the action, right?
Cheers
Ed
Old 05-29-2008, 06:48 PM   #2261
Default re
good catch! i actually circled the wrong set of holes. I ran furthest out on front and second furthest on the rear. I should pay more attention next time lol.
heres the correct setup
Reedy batteries
www.muchhobby.com
Old 05-30-2008, 01:46 AM   #2262
Send a message via MSN to jontang001
Hi guys
I have a question about front spool and one way....is there any theory support that front spool always faster than one way on asphalt and opposite on carpet? Or, just depends on experience?
Thanks for any answer!!!
TAMIYA TRF416, EVO5MS, TB03 FullOP
Schumacher Mi4LP, CAT SXII, Cougar
jontang001 is offline   Reply With Quote
Old 05-30-2008, 04:35 AM   #2263
TryHard's Avatar
Originally Posted by jontang001 View Post
Hi guys
A lot of that depends on class, track type, surface... but some general rules I tend to go on.
A one-way is usually faster over one lap, but is generally restricted to one line, and you loose the use of brakes (unless your really good ). A spool maybe slightly slower over a single lap, but can be more consistent over a run, as it's not restricted to one racing line. It also allows the use of brakes.
Outdoors, I'll use a spool in all classes, unless the track is particularly wide and open, and the I may consider a one-way for steering (this is especially so on big tracks with slower classes).
Indoors, mod and 10.5/19 I'll go spool, whilst stock I'll always tend to use a one-way. (although I did use a spool last time out, but that was beacuse I'm lazy...)
HiH
Ed
Old 05-30-2008, 06:25 AM   #2264
HiH
Ed
Wo!!!Thanks Ed!!!
I always talk to my friend that no one use a one way outdoor....
I need to say sorry to him...he is a one way guy...
But, I hear about to use spool when low traction...is that right?
According to your post...spool allow a driver to miss a little bit but one way need a very stable driving style....is that right?
But, two week ago, in our last carpt race, I was use your 415MSXX stock setting for a 10.5R race...and that was awesome!!! I only changed rear toe in to 3 degree. I got A3 at the final and A3 finished. The car was still under control...my be last time I will change to 416 (if I got some spares...) and spool for carpet this winter.
So thanks Ed...for your fantastic website and awesome settings....WO!!!
Old 05-30-2008, 08:18 AM   #2265
syndr0me's Avatar
Trader Rating: 32 (100%+)
Any ETA on the new blocks and chassis? I'm eager to give the short arms a go on my carpet and asphalt rides.
syndr0me is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
