Old 05-18-2008, 02:38 PM   #2191
TryHard's Avatar
Originally Posted by Jon Kerr View Post
I don't know what they are in the normal kit. I never run Tamiya springs but the setup I'm running now is calling for them. I want to know what would be close until I can get the TRF springs.
Hey Jon,
Have a look here http://www.thard.co.uk/viewtopic.php?f=24&t=33
Tam blue is around 14lb, Tam Yellow 13.3lb. I take it this is for the snake you picked up
HiH
Ed
Old 05-18-2008, 03:04 PM   #2192
Check this table (pdf), it'll tell you all!
Arn0 is offline   Reply With Quote
Old 05-18-2008, 03:33 PM   #2193
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Originally Posted by TryHard View Post
Hey Jon,
HiH
Ed
Jeez does everyone know. Thanks
Jon Kerr is offline   Reply With Quote
Old 05-18-2008, 04:09 PM   #2194
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by veecee View Post
Nice work Craig. Will you be there on Tue night? It would be good to get the cars dialed to the new track!
I'm not too sure at the moment, I rolled my ankle on the way to work this morning so now I'm lying in bed icing it. Provided I can walk I'll come down yeah. Are you doing the muchmore masters this weekend?
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 05-18-2008, 04:36 PM   #2195
Fastforward's Avatar
Default Fans on motor or speede
I have just recently started running my 416 outdoors with at 10.5 brushless. I had 2 thermal shut downs today and I kept gearing down 2 teeth at a time until I finally finished (and won) the 3rd heat. My questions is, I am running no fans, should I be running fans? If so does anyone have suggestions on how to mount them?
Fastforward is offline   Reply With Quote
Old 05-18-2008, 11:23 PM   #2196
t4m1y4niac's Avatar
guys, can help me to get 11.3 FDR (for 3.5R Velocity motor) with 416??? what combination spur / pignion should i use without touching anything in the chassis????
SABRE S4 by TOP RACING....
t4m1y4niac is offline   Reply With Quote
Old 05-18-2008, 11:27 PM   #2197
t4m1y4niac's Avatar
what brand of ESC do you use???
IMO, you should usie fans on your ESC..because with BL system the ESC generate more heat than the motor..and ESC's Fans is a MUST HAVE ITEM on ESC..
Old 05-19-2008, 12:26 AM   #2198
Hi Guys
We have an event on this weekend, running on a dirty shitty low grip track, in temps of only 15 deg celcius, and some moron chose a control tire as a Sweep 36, what sort of setup, tire prep would you suggest to run?
Had a run on Sunday and the car was like a drift car.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 05-19-2008, 12:38 AM   #2199
CraigM's Avatar
you'd be looking at 15/83 in 48dp. That sounds a bit tall though, I run 9.4 with my orion 3.5
Old 05-19-2008, 02:17 AM   #2200
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Originally Posted by Besercoe View Post
Hi Guys
I would use Buggy Grip, put on a wet coat, wipe off with a rag to get all the crap off the tire. After that, put on a normal coat every 5 min. Do at least 4 coats.
Racing4Evo is offline   Reply With Quote
Old 05-19-2008, 05:40 AM   #2201
I have just moved from 17.5 indoor racing to 10.5 outdoor racing and I did not have a fan on the speedo. The speedo is a novak gtb, I will try to get a fan on it for next week.
Old 05-19-2008, 06:13 AM   #2202
veecee's Avatar
Hope you pulled up ok mate. Catch you at the track tomorrow. No, I'm not doing MM.
SMOKEM --- HIRO SEIKO --- YOKOMO
veecee is offline   Reply With Quote
Old 05-19-2008, 08:15 AM   #2203
sakaguchinet's Avatar
Send a message via ICQ to sakaguchinet Send a message via AIM to sakaguchinet Send a message via Skype™ to sakaguchinet
Soon to be released: Tamiya Suspension Mounts (TRF416/TB-03 Style) in all widths (from 1XD till 1F). Insanely great!
Also some spare parts will get a normal SP/OP number. 44mm Steel swing shafts will be also available soon.
http://sakaguchinet.dyndns.org/sites...m/hop_ups2.htm
http://sakaguchinet.dyndns.org/sites...spareparts.htm
Best Regards,
Dai
http://www.rc-square.de (German and English manufacturers site)
http://www.sakaguchinetshop.com (Tamiya TRF related stuff)
sakaguchinet is offline   Reply With Quote
Old 05-19-2008, 08:42 AM   #2204
syndr0me's Avatar
Trader Rating: 32 (100%+)
Wow, that IS good news. I'm glad I waited to buy the suspension mounts, I was hoping they'd release them in the 416 style. Steel 44mm shafts will a welcome change as well.
Do the little "top hat" pieces that go into the c-hubs and support the steering knuckles have their own part number? The one I ordered only came with the short piece, and had a weird ball stud that was a combo of the two pieces. I can't seem to find the longer one anywhere.
syndr0me is offline   Reply With Quote
Old 05-19-2008, 12:25 PM   #2205
RC MARKET's Avatar
Good News !
& June release TRF416 Stick pack battery lower deck kit !
RC MARKET is offline   Reply With Quote
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
