Old 04-30-2008, 09:22 AM   #2026
pug 205 gti's Avatar
Im trying to find a blue tamiya carstand.i can only find the red ones?.
Anybody know where i can source one? thanks
Its quietish on rctech lately?
pug 205 gti is offline   Reply With Quote
Old 04-30-2008, 03:50 PM   #2027
Default re
Tryhard is correct, where it says "full" i was referring to my shock rebound. As for the rear toe i made a little error....should have been a XA block which equals 3 degrees . As for droop, i measure it a different way the some people. The way i do this is by measuring ride height, then i raise the chassis till the tires barely touch and re-measure the ride height. The difference in the measurements is my amount of droop. So if i have 5 mm ride height and my second measurement is 7.5mm then i will have 2.5mm of droop. Hope this clarifys things!
Corey "Whitey" Whiteman
TAMIYA- www.tamiya.ca
LRP- www.lrp-electronic.de
Reedy batteries
Protoform- www.pro-lineracing.com
Parma- www.parmapse.com
APS racing- www.aps-racing.net
www.muchhobby.com
TRFwhitey is offline   Reply With Quote
Old 04-30-2008, 05:31 PM   #2028
VenturaDC's Avatar
Trader Rating: 32 (100%+)
So does the 416 use the same arms as the tb evo iv? was just browsing tamiya usa really thinking about getting a 416 and was looking up the different part numbers to see if i could order spares while waiting for the car to come off back order and under spare parts for 416 is lists evo iv arms.
also is all i need to have a spool the front direct coupler? or is there anything else i need for spool?
any weak links i should change out from the get go?
thanks a bunch in advance, i was reading pages and pages of this thread and started to get a headache lol
oh and last thing any word on when the car will be available again?
VenturaDC is offline   Reply With Quote
Old 04-30-2008, 05:36 PM   #2029
steveonamission's Avatar
VenturaDC
Yes the 416 does use the Evo IV Short Reversable Arms, though there not what you get in the kit, everyone is using the short arms on the 416 though.
Look at Ed Clarks (Try Hards Website) www.thard.co.uk. It has all you need to know on there, for what you need for the spool, to the parts you should keep stock of.
Read this
http://www.thard.co.uk/viewtopic.php?f=24&t=29
steveonamission is offline   Reply With Quote
Old 04-30-2008, 06:14 PM   #2030
VenturaDC's Avatar
Thanks!!!! What a great site
Old 04-30-2008, 09:19 PM   #2031
sakaguchinet's Avatar
Send a message via ICQ to sakaguchinet Send a message via AIM to sakaguchinet Send a message via Skype™ to sakaguchinet
Originally Posted by steveonamission View Post
VenturaDC
Read this
wrong... The 416 uses the Evo IV Reversible Suspension. The SHORT Reversible Suspension comes with the Evo V or TA-05IFS-R. You can see the difference very simply: The LONG Arms has a Y as reinforcement, the SHORT arms has a X (the cross section near to the 3mm suspension pin).
Best Regards,
Dai
http://www.rc-square.de (German and English manufacturers site)
http://www.sakaguchinetshop.com (Tamiya TRF related stuff)
sakaguchinet is offline   Reply With Quote
Old 04-30-2008, 11:52 PM   #2032
CraigM's Avatar
Trader Rating: 34 (100%+)
are the short arms a different width from the kit? when I put them on with 4.5mm of spacers on the shaft my arms bind. This happened with the XA/C and XA/D. I removed the .5mm spacer and they are fine
edit: by width I mean on the kingpin
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 05-01-2008, 12:25 AM   #2033
bigbutstupid's Avatar
yes, they do bind but loosens after a while. i use 0.6mm instead of 1mm initially and slowly added it back to 1mm after a few runs. just shim it to however u like and watch out that there is not too much play after every few runs.
bigbutstupid is offline   Reply With Quote
Old 05-01-2008, 12:36 AM   #2034
fadzli's Avatar
what is min, max and desirable rear toe angle?
Do Not Follow Where The Path May Lead. Go Instead Where There Is No Path And Leave A Trail.
fadzli is offline   Reply With Quote
Old 05-01-2008, 03:39 AM   #2035
CraigM's Avatar
err... I may have... um... been using the .7mm shims by mistake
it's still tight but yeah not as bad
I find between 2 and 3 degrees suits most tracks. If the grip is really high then 1.5 might be ok, but I've usually found that if you need to go that low then you should be concentrating on other areas to find more steering
Old 05-01-2008, 05:39 PM   #2036
t4m1y4niac's Avatar
so what is the meaning with rebound in the Tamiya set up sheet??? Droop??
SABRE S4 by TOP RACING....
t4m1y4niac is offline   Reply With Quote
Old 05-01-2008, 05:43 PM   #2037
VenturaDC's Avatar
i believe its is talking about how far out the shock shaft pushes itself after you push it in all the way, off the car and with no spring obviously, someone correct me if i am wrong.
Old 05-01-2008, 05:54 PM   #2038
t4m1y4niac's Avatar
ok thx..
Old 05-01-2008, 09:21 PM   #2039
syndr0me's Avatar
Nice spool! I can see why it took 6 months to design, if you look closely, you can see the silhouette of Jesus! It's the Jesus spool! Thanks Tamiya!
Anyway, the ends of my ball studs come down too far and hit the spool's outdrives. I believe I can use shorter studs, but it may affect how much adjustment I can make up front? I'll have to experiment with different studs and see where I'm at.
Did anybody notice the bearing holders that come with the spool seem to be a significantly different plastic than those that come with the kit? It's kind of a light grey color.
syndr0me is offline   Reply With Quote
Old 05-01-2008, 11:53 PM   #2040
CraigM's Avatar
yep I noticed that, I was building my car from scratch so I had the two to compare. I went with the spool ones, I figured maybe they were an upgraded compound or something
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
