Old 04-14-2008, 04:29 PM   #1891
POUNDITRACING's Avatar
JUST SUBSCRIBING.
Pound It Paints - http://www.rctech.net/forum/painting-designs-graphics-photography/270707-pound-paints-raymond-ramirez.html
RC Reveled - http://www.teamrcr.net
POUNDITRACING is offline   Reply With Quote
Old 04-15-2008, 12:07 AM   #1892
JimmyMac's Avatar
Try some kick up. It helps my car gain some steering in the fast long corners. Start off with .5mm kick up.
M.J. McIntyre
R1Wurks
Yokomo YRX12
Ho-B Max
JimmyMac is offline   Reply With Quote
Old 04-15-2008, 05:34 AM   #1893
peterchia41's Avatar
Exclamation
Hi,
Was wondering, why is it that Tamiya does not seem to have any stock of the TRF416? It seems like they are not really manufacturing. It is their latest Tamiya racing factory car right?
Is there an underlying reason behind it?
peterchia41 is offline   Reply With Quote
Old 04-15-2008, 06:12 AM   #1894
bigbutstupid's Avatar
definately the latest. and with so many podium finishes too. i think they may have something up their sleeves at the moment. if u can get hold of one, get it anyway, its a good car. parts are easier and easier to source as well
bigbutstupid is offline   Reply With Quote
Old 04-15-2008, 07:42 AM   #1895
Exclamation
TRF 416 MS? lol so fast?
Old 04-15-2008, 10:13 AM   #1896
quantum's Avatar
Default setup accuracy
i was comparing my setup with jilles DHI setup and realized that when specifying the number of spacers used for camber links,etc , it makes sense to specify the type of ball nut. see the pic. its at least 0.5mm difference which is significant enough.
any ideas for standardizing notation for ball nut type?
perhaps:
on left requiring grub screw through it - "415ball nut"
on right - "hex head ball nut"
(oh, and i would never use such a badly damaged 415ball nut! )
Tamiya TRF416 / TRF416WE / TRF416X-ball-nut-002.jpg
quantum is offline   Reply With Quote
Old 04-15-2008, 10:53 AM   #1897
TryHard's Avatar
perhaps:
The difference between the two is actually 1mm. As I always use the hexheaded jobs, I'll always state it the number of shims. To convert over to the standard ones, you need to use 1mm less of shims.
For example, with 5mm of shims under the front inner ball link, is for the hex headed type. With a std nut type, you only need to use 4mm.
HiH
Ed
Old 04-15-2008, 03:11 PM   #1898
Hi people,
Can anybody give me the internal ratio of this car?
And a info about the most fragile and wearable partísÖ and if isnít to much, the hop ups that the car needs to be more competitive.
Thanks in advance
RFrancis is offline   Reply With Quote
Old 04-15-2008, 03:16 PM   #1899
TryHard's Avatar
Originally Posted by RFrancis View Post
Hi people,
Thanks in advance
www.thard.co.uk
Have a look at the tips and tricks section
Old 04-15-2008, 07:37 PM   #1900
quantum's Avatar
HiH
Ed
right, great. what i am suggesting is that the ballnut type be indicated on the setup sheets -would that be a good idea?
Old 04-15-2008, 11:28 PM   #1901
JimmyMac's Avatar
I'm not sure if it'll be a good idea. It's only a good idea if they use a different ball stud than what's in the kit. The only ball stud that is affected is the one you show. There is a short version of that ball stud that matches the hex head ball stud screw thing-a-majaber's height. If you are worried about strength, go for the steel hex heads. Just curious, but why are you using the ball nuts instead of the hex heads?
M.J. McIntyre
R1Wurks
Yokomo YRX12
Ho-B Max
Old 04-16-2008, 01:43 AM   #1902
TryHard's Avatar
I agree with Jimmy here.... If your deviating from the kit, it's worth noting, however otherwise you should assume that it's as kit. Given I still run all my links as kit, no need to note it down, IMO.
And, if you know the difference between the two, it's fairly easy to take that into account when making up setup sheets, just add 1mm to the shim settings if your using the nuts.
Regards
Ed
Old 04-16-2008, 02:18 AM   #1903
veecee's Avatar
Trader Rating: 34 (100%+)
With some many big wins recently, I was hoping to see more setups from the factory drivers. I would especially like the see Jilles' setup in the recent Dutch race - asphalt on rubbers... C'mon Tamiya, let's have 'em!!!
SMOKEM --- HIRO SEIKO --- YOKOMO
veecee is offline   Reply With Quote
Old 04-16-2008, 02:46 AM   #1904
JimmyMac's Avatar
I think they've made soo many changes between all the rounds, it would be hard for them to pin down an exact setup that they used. I think they are just learning the car the best they can before the Worlds. Much like what I'm doing before the Nats. Try this and that. See what does what and how and where. Wish Jilles would come back on here. I'm sure he is busy though. But it would be nice for some to have an asphalt starting setup for a spool. Would like to see what changes they made vs a oneway.
Hey Ed, what is your other hobby that it takes you away from RC for the summer? Just curious.
M.J. McIntyre
R1Wurks
Yokomo YRX12
Ho-B Max
Old 04-16-2008, 03:11 AM   #1905
TryHard's Avatar
I've been trying to get hold of the TITC and LRP setups... so far no joy
As for my other hobby... some pics attached. I'm far left in the first one (Can just see the face with sunnys on), in the red top in the second (yup, showing my arse), and far right in the third (black and white top)... it's a bit more active than RC, but just a tweaky
Ed
Tamiya TRF416 / TRF416WE / TRF416X-abg1024.jpg   Tamiya TRF416 / TRF416WE / TRF416X-n511016916_112284_6901.jpg   Tamiya TRF416 / TRF416WE / TRF416X-n511016916_30315_3622.jpg
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 12:08 PM
TRF416 speedart Electric On-Road 26 06-27-2007 05:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 03:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 10:11 AM
SEO by vBSEO 3.5.0
