Old 03-04-2008, 10:49 AM   #1561
TRF415boy's Avatar
Originally Posted by JimmyMac View Post
Thanks for the input guys.
Yesterday I was alittle scared to try some more toe-out up front because my rear end was loose. But it was loose mid-out. What I did to correct that was camber gain. I had 2mm under the inner link in the rear. I went down to 1mm and it solved that issue. I may try more toe-out up front as I know that is a powerful adjustment for entry. Wish I had more time to test.
I may try higher oil in my car now that you suggested it.. I used to run heavier oil when I ran my Yok years ago. It seemed to like it. So I may try it on this car.
Ed, I'm running D/D up front (I run LWS arms). And no axle shims. Wish I had a C block that I didn't have to mod out. Maybe I'll just wait for Tamiya to come out with one. That or just a C/B setting... OR.... E/D? up front? haha.
Bmmer, are you running the kit 105 spur? If so, you can not use that spur for brushless 17.5~10.5 motors. It's too large. I run a 102 spur and the largest pinion I can use is a 46 before the pinions start to touch the top deck. This combo gives you about a 4.55 final. I use this for 13.5. You could go with a 96 spur if you want to run 13.5 or 10.5. Or get maybe an 88 spur if you want to run 17.5. I have yet to try 17.5. But I will soon.
Travis, MRE spool with 501/416 oneway pulley (or just use the pulley in your kit). Flip the pulley onto the other side of the spool. Pics posted awhile back in this forum.
If you're looking for more initial steering, why not just give a bit more rear droop ?
TRF415boy is offline   Reply With Quote
Old 03-04-2008, 01:28 PM   #1562
TryHard's Avatar
Originally Posted by quantum View Post
how does arm sweep work?
and if you are using the short evo5 arms, then would you use D/C to achieve sweep?
Correct. Basically arm sweep is set in the same way as rear toe-in, in that you angle the front arms back towards the centre of the car.
It seems to help a lot in giving entry and mid corner steering. I'm not entirely sure how it works, but the affect is similar to how inboard rear toe-in adds rear traction. And the affect is the same on all cars.
One thing to bear in mind though, is that when you change that setting you do two things... one is to sweep back the arms, and the other is shorten the wheelbase. So if you want to test just the sweep, you'll need to re shim the wheelbase to the right length. Hence why the kit setup (with 0.5 of sweep) has 2.5mm behind the arm, but all the parrallel armed setups (D/D) only have 2mm.
HiH
Ed
Old 03-04-2008, 03:08 PM   #1563
JimmyMac's Avatar
At times I like to use rear droop. But only to a point. The effect is not always desirable for me. So I like to search for other ways besides dumping all the weight to the front initially.
Hebiki, I will PM you later tonight.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 03-04-2008, 03:53 PM   #1564
wouldn't the wheelbase be the main thing giving the front more traction, cause shifting the front wheels 2mm as you say is quite allot in weight distribution...
when i got my car i can put it on my scales. i bought 4 mini scales from RCM for 40 dollar total so thats allot you can read out on the setup for just 40 dollars... balance, tweak weight distribution front to rear, basically every influence on static wheel load you can play with using 4 scales... one under every wheel...
cheerz
Markiempje is offline   Reply With Quote
Old 03-04-2008, 04:18 PM   #1565
fadzli's Avatar
Default arm sweep
arm sweep. can somebody explain. how to set and what is the effect> i dont understand. TQ.
Do Not Follow Where The Path May Lead. Go Instead Where There Is No Path And Leave A Trail.
fadzli is offline   Reply With Quote
Old 03-04-2008, 08:19 PM   #1566
JimmyMac's Avatar
I'll get ya in the morning Hebiki. I just woke up. And I need to head to work before I'm late....
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
Old 03-04-2008, 09:22 PM   #1567
justin lessard's Avatar
Send a message via AIM to justin lessard
Arm sweep is the angle of the hinge pins when viewed from above.
So,If your front hinge pins are perfectly inline with each other,then you have zero arm sweep
moving the front of the hinge pin out increases arms sweep,so now when your wheels are turned,the inside front tire is bieng moved toward the rear of the car,putting more wieght on it. And the outside wheel is bieng moves toward the rear of the car aswell,putting more wieght on it. So increase sweep (out) will give you more steering.
moving the back of the pin out will have the opposite effect (less steering)
Hope that help explain it better
justin lessard is offline   Reply With Quote
Old 03-04-2008, 10:16 PM   #1568
fadzli's Avatar
Default pin
which is hing pin?
Old 03-04-2008, 10:17 PM   #1569
which is hing pin?
The innermost pin that runs though the suspension arm
Old 03-04-2008, 10:34 PM   #1570
fadzli's Avatar
still cannot get which parts...
''''So,If your front hinge pins are perfectly inline with each other,then you have zero arm sweep'''
inline with what?
'''moving the front of the hinge pin out increases arms sweep'''
is it the pin with three hole
Old 03-04-2008, 11:32 PM   #1571
ammaramira's Avatar
inline with what?
Fadzli ... UGPM
ammaramira is offline   Reply With Quote
Old 03-05-2008, 01:24 AM   #1572
TryHard's Avatar
cheerz
Actually, it's only a 0.5mm change (with 0.5 sweep you put the 0.5mm behind the arm, without it it's in front). Obviously, more of sweep would require more spacers behind the arm to keep the wheelbase the same... might be something I need to sit down and figure out.
HiH
Ed
Old 03-05-2008, 01:25 AM   #1573
TryHard's Avatar
Cheers for that Justin... knew it was something like that
Old 03-05-2008, 01:32 AM   #1574
TryHard's Avatar
inline with what?
Basically, the inner hinge pin, is the inner most pin that runs through the inner most holes on the suspension arm. It's the one that the suspension arms rotate around, and is mounted to the chassis.
Looking down from the above the car, if the pin is parallel to the centerline of the car, you have 0 of arm sweep. If the pin (and hence the suspension arms) are angled back slightly (the front point of the pin is further from the center line than the rear), you have arm sweep.
It's set on the TRF's by changing the suspension blocks (the 1B, 1A blocks etc), which the hinge pins sit in (albeit with the small pin balls on the ends). Running a wider block on the front will give arm sweep, hence why the kit setting of B/A on the 416 gives 0.5 of arm sweep.
HiH
Ed
Old 03-05-2008, 03:56 AM   #1575
fadzli's Avatar
Default ok
tq for the xplanation. i know which one now. now i understand that there are two ways adjusting toe angle. 1st the hinges (arm sweep) and second the turnbuckkle. is toe angle and arm sweep gives different effect on the car?
what toe angle do and what arm sweep do.
TRF416 sim600 Malaysian R/C Racers 15 01-09-2010 11:08 AM
TRF416 speedart Electric On-Road 26 06-27-2007 04:28 AM
new joke cyber3d Chat Lounge 5 08-02-2006 02:52 PM
another joke, OH no! corvettecrazy Chat Lounge 0 01-10-2004 09:11 AM
