Stealth antenna
Stealth antenna
Anybody tried it before?
http://www.abchobby.com/productpage/stealthantenna.html
Could somebody tell me if it fits in spektrum receiver?
And easy to install?
Thanks!
Thanks!
Why would you need one of those when you can already make a spektrum antenna short enough not to protrude the body now? I only have one car where it even sticks out of the body and I could have made it stay under but it is only about an inch or two high anyhow.
Oh my bad I almost forgot it, but could somebody instruct me how do you prefer to hide your antennas to be visually sharper in the car, please?
check this old thread.....http://www.rctech.net/forum/showthread.php?t=143312
But how about 3001, as i saw most of them with shorter wire are 3500.
Could anybody show how to put more convenient antenna tube with my
3001, please.
Registered User
I sell these also ...
http://www.teambrood.com/catalog/pro...roducts_id=883
They are very easy to install, plus they also work great with full length AM/FM antenna wire.
Well, thanks for reply.
I just use the antenna wire full length put it in a regular antenna tube and don't make a hole in the body for it, just run it bent towards the back under the body, works great, I use futaba 2.4 but I did the same when I ran spektrum
