Old 09-05-2007, 06:47 PM   #1
Hey Guys I Just Got This Car Yesterday and if u watch the video then u will under stand what is going on.
Crazn is offline   Reply With Quote
Old 09-05-2007, 06:50 PM   #2
dbmartin's Avatar
look for a throttle rev switch on your radio and flip it. hopefully there is one on there, That looks to be the problem
FSEARA - Top Photon - Jacks Hobbies
dbmartin is offline   Reply With Quote
Old 09-05-2007, 06:55 PM   #3
F N CUDA's Avatar
Trader Rating: 30 (100%+)
Looks like you need to set your speed control to your radio first.
Get the specs from the speed control manual or online.
You can check your throttle position dial and turn it toward brake, looks like it might be turned toward throttle a bit too much.
Good luck
F N CUDA is offline   Reply With Quote
Old 09-05-2007, 06:58 PM   #4
ok i'll do that tomarra cuz i have to do some stuff right now btw thanks i'm going to post what happends tomarrow
Old 09-05-2007, 08:10 PM   #5
Alltapdout's Avatar
Are your batteries fully charged?
Alltapdout is offline   Reply With Quote
Old 09-05-2007, 08:19 PM   #6
ok if you get a chance .. reset your speed control .. if your car has a spektrum system re bind it by holding down the button on your reciever while turning the car on until the light blinks then turn on your radio while holding the button on the module the light will blink .. when finished the car reciever and radio lights will stay green .. if that doesnt work and your running crystals you might have a bad reciever ..also make sure your radio batteries and car batteries are fully charged ... hope this helps .. mb.
Mark Barden .
mb racer is offline   Reply With Quote
NEEDED-RC CRAWLER FORUM-NEEDED countryboy4life R/C Tech Site Forum 9 03-11-2010 07:07 PM
Help Needed! Supa_Mario Nitro On-Road 1 02-19-2008 09:00 AM
pro 4 help needed minnesh Electric On-Road 2 02-27-2007 08:30 PM
Help needed.. xpander77 Singapore R/C Racers 3 12-04-2004 06:57 AM
Help Needed HPIRS4GUY Australian Racing 6 02-22-2003 11:40 PM
SEO by vBSEO 3.5.0
