Tamiya F103 Forum >
Tamiya F103 Forum
Like Tree9Likes
Tamiya F103 Forum
Old 12-11-2009, 12:14 AM
  #856
zpmhinojosa's Avatar
Not sure what body he has but I know it's a 103 & fast!
+ YouTube Video
Gotta love that nose!
zpmhinojosa is offline
Old 12-15-2009, 08:45 AM
  #857
cheehtae's Avatar
Trader Rating: 15 (100%+)
what's the usual gearing for 17.5 2s aand 17.5 1s lipo? tnx
cheehtae is offline
Old 12-15-2009, 01:55 PM
  #858
Trader Rating: 8 (90%+)
I am trying to figure out the way to adjust the roll on my 103. I seem to have the o ring suspension that pivots on the ball with the nut at the top of the screw. It also look like there are tweak screw holes in the battery braces right next to the pivot points on the chassis. It does seem different because I cannot screw the pivot screws in any more and look like there should be plenty of more room to screw them done to make the chassis stiffer.
The car I do beleive I have is the RC HP F103 if that helps at all. I guess I am really asking for help on \understanding the suspension on this chassis? LOL
Tha Skinny is offline
Old 12-15-2009, 02:15 PM
  #859
robk's Avatar
Trader Rating: 22 (100%+)
You have the pivot ball suspension, which does not need o rings. You can use tweak screws with that suspension. I started with that suspension last year, using tweak screws. Unfortunately, I found the o ring setup was just as fast with way less hassles.
The good news is that the proper o ring suspension parts should have come with your kit. You should have some unused parts that look just like what you have on the car now, but just have a recess for a hex nut, instead of the capture for the pivot ball. Those parts will allow you to use the o ring.
robk is offline
Old 12-15-2009, 02:51 PM
  #860
I unfortunately did not buy the kit new, I bought it from a local in pristine condition and did not get any extra parts with it at all. I like the idea of the tweak screws but they do seem difficult to tune on the fly. I will deffinitelly look into the other type of suspension.
Old 12-15-2009, 09:20 PM
  #861
bsmooth's Avatar
Trader Rating: 18 (100%+)
Default battery hold down
..Could any of you share some ideas on how to hold the battery in without using tape? I'm looking for some different options. I've used bumper foam to act like shims and make the battery very snug, but a small impact will still shift the battery.
Thanks for any help.
-Steve
bsmooth is offline
Old 12-16-2009, 10:58 AM
  #862
Foxxrocket's Avatar
Dose anyone know where the instructions for the o ring setup can be found? I know I've seen it around before.
Foxxrocket is offline
Old 12-16-2009, 02:01 PM
  #863
TonyK's Avatar
I thought about using hot glue to glue my Lipo in.
-Steve
TonyK is offline
Old 12-16-2009, 02:40 PM
  #864
robk's Avatar
-Steve
How about some big o rings?
robk is offline
Old 12-16-2009, 03:04 PM
  #865
i use double sided tape , the padded type for sticking speedos down
sidecarphil1 is offline
Old 12-16-2009, 04:53 PM
  #866
bsmooth's Avatar
.....I dont want to glue or use double sided tape, as thats more permanent. I like to rotate between 2 batteries on race day. The o-ring idea might work. I use that on my 1/12 pan car, and it seems pretty solid.
Thanks for the ideas! Please keep 'em coming!
bsmooth is offline
Old 12-17-2009, 10:41 AM
  #867
R/C Tech Elite Member
JayL's Avatar
Just buy 2 cars Steve
CRC uses o-rings in the current 1/12th
JayL is offline
Old 12-18-2009, 07:39 AM
  #868
bsmooth's Avatar
That's what i got! I plan to hit the 'rug' in January!
bsmooth is offline
Old 01-16-2010, 09:01 AM
  #869
414MPH's Avatar
Where is everyone?
The F-103 is not dead, it is just in winter hybernation......
Time to wake up!
414MPH is offline
Old 01-16-2010, 09:58 AM
  #870
lightfoot's Avatar
Originally Posted by 414MPH
Where is everyone?
Time to wake up!
Oh, it's not dead
Big race this Sunday....
http://www.charleslightfoot.com/WCRC_F1.html
lightfoot is offline
