Old 11-30-2010, 07:10 PM   #1441
dzstr's Avatar
Trader Rating: 20 (100%+)
I have Ride soft front and rear. It took several packs for them to not be slippery on carpet. Also seem to have to sauce them a little longer than normal. Tonight was my second race on this set and they are pretty hooked up now.
dzstr is offline   Reply With Quote
Old 12-01-2010, 02:45 PM   #1442
Giorgio's Avatar
Some one knows were I can get the decals to replicate this body?
Ivan maybe?
Giorgio
https://www.facebook.com/FenixRacing.it/
www.fenixracingshop.com
Giorgio is offline   Reply With Quote
Old 12-01-2010, 05:53 PM   #1443
Originally Posted by RedBullFiXX View Post
Different tires for all types of surfaces, what are you running on.
Do you have the RIDE A or B compound ?
Before the rug at our track had a good groove in it the RIDE A was perfect, now they oversteer, I heard some of the 103 clan were using Tamiya A with RIDE A front.
Problem is, Tamiya A type rubber for the 103 is no longer in production as far as I know.
A compound front and rear. The last run I put on them seemed to hook up a bit better. On carpet.
Yeah I think I need to condition them overnight in some WD40 or sauce, then just put more runs on them. THey are starting to come around.
PaintVagrant is offline   Reply With Quote
Old 12-03-2010, 08:58 AM   #1444
Trader Rating: 56 (100%+)
Default F103 QUestions
Ok, so I got this beautiful F103 15th off another memeber here and started to put things together. I love it, it's like a simpler version of my WGT. A few questions for the 103 experts:
1) WHat is the reccomended ride height on carpet? On WGT, I run 5mm, but this sucker is pretty low.
2) I am used to riding my WGT foams almost down to the rim, but this isn't possible with 103's, at what diameter do foams become unusable? What is the optimal tire diameter?
3) Are undercarrage splitters/diffuers useful or just a cosmetic touch? I figure I can regain 1mm in clearance by removing mine.
4) What is a good rollout to shoot for if I am running a 21.5 on a medium grip carpet track?
FInally, anyone have a set of ride height adjusters they can sell me? I have 2out of the three, but I am missing the low/high setting ones. Also looking for the servo saver insert of KO servos...have a kimborough on mine now, but would like to retain the factory geometry. PM me, thanks!
dynamic_e is offline   Reply With Quote
Old 12-03-2010, 09:04 AM   #1445
I just started running mine with a 21.5, no timing advance on the motor or speed control, and Im running around a 2.8 (not including wheel diameter, just gearing). I think I could probably go down to something around 2.5 before motor temp becomes a real issue.
I swapped my car to the tamiya 64 pitch gears, and Im running a 93/33 combo.
Im sure this has been covered in this thread before, but I run a bunch of negative expo on my throttle with this motor/gearing combo, its extremely punchy out of corners and was difficult for me to control. I dont know if this is typical for f1 drivers, but it was the only way to rein in this beast
Old 12-03-2010, 09:22 AM   #1446
F N CUDA's Avatar
Trader Rating: 30 (100%+)
I'm running 36/82 with my 21.5 on carpet and it runs about 150 degrees.I have my ride height at 3mm front and rear with rubber tires.
You can get more ride height in the front if you shave off 1 to 2mm from the bottom of the spindle/uprights and if you run the spring on top of the upright just add shims to the top to keep the spring tension the same.
That's what I have.
I have also modified the rear axle adjusters and their "holes" in the side plates to further lower the axle.
I dremeled the bottom of the side plates and then added setscrews to the top of the adjusters to take up the extra slack/
I last ran 1/12 scale foams on F103 rims front and rear with a ride height of 2mm.
Gotta watch the "droop" in the T plate tho, ran the shock spring pretty stiff to keep it from draggin.
Extreme but it worked so yes, you can run your foams down pretty tiny if you really want to.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 12-03-2010, 11:45 AM   #1447
Wow, thats significantly taller gearing than Ive tried. I might have to give it a shot and see what happens
Old 12-03-2010, 04:33 PM   #1448
robk's Avatar
Trader Rating: 22 (100%+)
1- I usually shoot for 4mm. 3mm is fine, but then you start running the fronts down to where you only get a couple runs out of them. You can get some ride height back by shaving the bottom of the knuckle, and then using a spacer on top, lowering the steering knuckle.
2-This plays into the front ride height. If I remember right, 53.4 mm fronts give a 4mm front ride height. It may actually be a bit smaller, but you can always cut the tires more if I'm wrong The rears you can run really small, like 50 or 51mm, but the cars actually run down the straight better with like 56 or 57mm tires if you run silver can. The same roll out and everything. It sounds ridiculous, but I have tried it back to back, and it just seems to roll better. This becomes huge if you run on a big track, like 90+ feet.
Old 12-06-2010, 08:12 PM   #1449
Default Whoa
Whoa, spent an hour or two fooling with this f103 on carpet and it's on rails. Ran it with Zen Premounts and Sticky Fingers sauce. Still need to dial in the speed control and get my spur gear adaptor so i can run true 64p gears, instead of my tamiya/kimboro mishmash. Still need to work on ride height, but realized the previous owner put on f104 rear pods. I remember reading that you lose a mm of ride height from using them, so gonna drop the stock setup back on. Looks pretty though.
It feels like a slightly scaled down version of my World GT, but it looks so much cooler.
Old 12-06-2010, 10:08 PM   #1450
Foxxrocket's Avatar
I would say that the F103 is almost idiot proof. It was my first introduction to pan cars and I knew nothing about them, I just followed the instructions. Then with a little tweak, the car was on rails.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 12-06-2010, 10:25 PM   #1451
robk's Avatar
I would much rather see F1 at big races vs. WGT
Old 12-06-2010, 10:25 PM   #1452
madjack's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to madjack
You could also remove the rear difuser and gain more rear ride height. Glad to hear that a good car found a good home... so to speak
madjack is offline   Reply With Quote
Old 12-07-2010, 01:46 AM   #1453
gashuffer's Avatar
Trader Rating: 48 (100%+)
+1
T-Sal
gashuffer is offline   Reply With Quote
Old 12-07-2010, 03:33 PM   #1454
GasGod's Avatar
Any opinions on shock placement-some kits have a post mount and others have the bridge mount.Some have both--I see the 15th aniv,kit has a post mount and a bridge.What does this do?I know the post inclines the shock more but how does this effect the car? Thanx in advance for your input.
F! Metal Militia,VTA NATION--Team SloMoFo
losi 8t,mbx5t,rc8
rc8,Kyosho rb5,SCR
ft4 MT wallet
cyclone;xxx-s;x-rayT2;crc gen xl;bmi 12rrl
GasGod is offline   Reply With Quote
Old 12-07-2010, 04:33 PM   #1455
robk's Avatar
bridge mount = more on power steering
FS: Tamiya F103 mild seven Australia For Sale/Trade 4 08-19-2008 11:19 PM
Tamiya F103 GT izzyracer R/C Items: For Sale/Trade 2 03-01-2007 03:51 PM
Tamiya F103 NIB Jspecrcr R/C Items: For Sale/Trade 7 11-07-2006 01:30 PM
WTB: Tamiya buggy & Tamiya f103 stuff rays_tt Australia Wanted to Buy 2 04-20-2006 06:10 AM
Tamiya F103 or F103 Parts MM-F1 R/C Items: Wanted to Buy 4 04-24-2004 03:14 PM
