Like Tree6Likes
Old 07-06-2010, 11:53 AM   #1351
Originally Posted by kneedeeppow View Post
are the tamiya range of foam wheels ok or are there better options out there? i plan to run hard-mediums on the front and medium-softs on the rear. we have a fairly low grip surface to race on and rubber tires arent up to it.
All you can do is try them...on our asphalt track the foam tires have no grip at all no matter what you do to them. The rubber works but only just barely. Often times on low grip asphalt the rubber will work better but not always.
Old 07-06-2010, 12:06 PM   #1352
Foxxrocket's Avatar
We spray a mixture of syrup and soda on our track, and the tire grip is crazy good.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 07-06-2010, 01:58 PM   #1353
That's cool fox...I used to do that too at my race. However the person who originally asked the question is running at a track with low grip.
Old 07-06-2010, 11:27 PM   #1354
HeliYogi's Avatar
Trader Rating: 16 (100%+)
Default A small tribute for a great friend...
Please a minute of silence
More F-1 RC action? RCTECH Formula-1-RC-Northwest & FB @WhatBrakes
HeliYogi is offline   Reply With Quote
Old 07-09-2010, 08:48 AM   #1355
Trader Rating: 19 (100%+)
What stuff are you guys using to glue the foam tires? I have a hard time using the Tamiya two way tape to work. I've also tried CA and that did not work out good either.
Any tips?
zake540 is offline   Reply With Quote
Old 07-09-2010, 09:00 AM   #1356
F N CUDA's Avatar
Trader Rating: 31 (100%+)
Any tips?
Use the tape and wet it a little before sliding the foam on, it'll dry and stick fine.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 07-09-2010, 09:28 AM   #1357
Foxxrocket's Avatar
Go with the tape. Then when the tire goes bad, you can tare it off and put a new one on without having to buy the tire and rim.
Old 07-09-2010, 10:54 AM   #1358
gtfour93's Avatar
Trader Rating: 22 (100%+)
Any tips?
Use a little bit of liquid dishwashing soap on the wheel, after removing the clear film on the tape, while already applied on the wheel. This way, you can easily move the foam tire in place. Then let it dry overnight, until it's cured.
www.activrc.com
gtfour93 is offline   Reply With Quote
Old 07-09-2010, 12:28 PM   #1359
Thank guys, I'll try the tape again with your suggestions.
Just a thought has anyone tried using shoe goo to mount the foam?
Old 07-09-2010, 01:27 PM   #1360
gtfour93's Avatar
I haven't tried Shoe Goo before, but you might have problems with tire wobble when it dries. These are more ideal for reparing lexan bodies and mounting servos and switches on FRP or carbon chassis.
www.activrc.com
Old 07-09-2010, 10:38 PM   #1361
kneedeeppow's Avatar
our local track is low grip.i tried some rubber tires and they were terrible,the fronts wouldnt turn in very well and the rears i couldnt get enough heat in them. went to foams and the difference was remarkable.i dont know what brand of foams they were but they were awesome. we arent allowed to use additives etc so its just plain ole foamies for me. was unsure about the tamiya foams as their touring car tires were crap compared to sorex etc
https://www.facebook.com/Fresh10drift/
Eagle Racing GRT FRD. Tamiya F103GT. Tamiya Blackfoot............ORIGINAL
kneedeeppow is offline   Reply With Quote
Old 07-10-2010, 01:30 AM   #1362
Yeah our asphalt here is made poorly so we get the opposite results...foams work better for us when the asphalt hasn't been sealed but once it is they get 0 traction.
Old 07-11-2010, 08:23 AM   #1363
prhess's Avatar
Any tips?
I use TRG tire tape and windex method. Tape the rim, peel the tape, cover the tape and the inside of the tire in a generous coat of windex and slide together. Let dry and it works awsome.
Pete
prhess is offline   Reply With Quote
Old 07-13-2010, 11:25 PM   #1364
AwesomeGuy's Avatar
Default Benetton B195 decals
Hi guys,
I'm hoping someone on here can help me.
I picked up a Benetton B195 body the other week (now I have to buy another bloody F103 to put it on), but the box didn't have the instrcutions.
I can work out decal placement no problem, but as for a default body colour?
Does anyone have the instructions they can scan and email me?
Thanks.
AwesomeGuy is offline   Reply With Quote
Old 07-13-2010, 11:54 PM   #1365
Default 201-103
anyone know if a f201 body would fit on a f103?
FS: Tamiya F103 mild seven Australia For Sale/Trade 4 08-19-2008 11:19 PM
Tamiya F103 GT izzyracer R/C Items: For Sale/Trade 2 03-01-2007 03:51 PM
Tamiya F103 NIB Jspecrcr R/C Items: For Sale/Trade 7 11-07-2006 01:30 PM
WTB: Tamiya buggy & Tamiya f103 stuff rays_tt Australia Wanted to Buy 2 04-20-2006 06:10 AM
Tamiya F103 or F103 Parts MM-F1 R/C Items: Wanted to Buy 4 04-24-2004 03:14 PM
