Old 04-07-2010, 05:23 PM   #1141
robk's Avatar
Trader Rating: 22 (100%+)
Originally Posted by jakeg1999 View Post
I agree....I ordered a new soft T-plate....I took most the whole car apart this morning including the front springs....Everything looks nice and even, but all be darn if I can't get it to go straight. If I just tap the throttle it spins left, and opposite for braking. I even tried messing with some weights on both sides just to see if I was off, and no change......I am starting to think, or hope that even thought the T-bar looks flat on a flat surface, it may be stressed under acceleration and decelerration......Hopefully I will figure this out....thanks for your help so far....
If you can find someone that knows the F103, or even a good 1/12 guy, they should be able to look at your car and help you.
Old 04-07-2010, 05:52 PM   #1142
It is possible your rear axle is too tight. Because the diff is not between the bearings if the axle is too tight in the pod it will cause drag on that side of the diff. There needs to be a little play in the rear axle to make sure the car will track straight. When you put on the left side hub slip a piece of paper between the axle spacer and the bearing and tighten down the hub. Then when you remove the paper you will have just a slight bit of play in the rear axle to keep it from binding the bearings.
Also check your thrust bearing assembly to make sure it is working properly. The car does strange things sometimes when the spring washers weaken.
Old 04-07-2010, 08:11 PM   #1143
GasGod's Avatar
I have to agree- prob something in the axle/diff area,or pod isn't square with chassis.
F! Metal Militia,VTA NATION--Team SloMoFo
losi 8t,mbx5t,rc8
rc8,Kyosho rb5,SCR
ft4 MT wallet
cyclone;xxx-s;x-rayT2;crc gen xl;bmi 12rrl
GasGod is offline   Reply With Quote
Old 04-07-2010, 08:21 PM   #1144
Trader Rating: 47 (100%+)
Ok, I will definately try that. I actually tried to make sure there was no play in the axle by holding a bit of pressure on both sides while tightening. While it feels free to me, it may be a bit too snug....I will give it a shot....
jakeg1999 is offline   Reply With Quote
Old 04-07-2010, 09:48 PM   #1145
Yeah that will actually cause problems. I used to do the same thing and kept wondering why I could never get my car to track straight.
Old 04-07-2010, 11:25 PM   #1146
i was shown a very quick and easy way of checking for tweek on pan cars and F1's
i use the Quarter trick
place 2 quarter coins on the front wheels just off the top top point of the tyres , hen find the middle point of the cars nose and lift slowly with a 1.5mm Allen key till the coins fall ,
if they both fall at the same time the car isnt tweeked , if one falls before the other you have tweek
this is quick to check maybe the 1st thing to check
sidecarphil1 is offline   Reply With Quote
Old 04-08-2010, 08:55 AM   #1147
I used to use this method to check for tweak in 12th scale( Iam cheap I used nickels). On a 12th scale there were two set screws on the T-bar that could be adjusted to get things set properly . If there was some tweak in a F-103 how could it be adjusted? Thanks
TheOtherBill is offline   Reply With Quote
Old 04-08-2010, 09:37 AM   #1148
j.d.roost's Avatar
Trader Rating: 27 (100%+)
I had some luck un-tweaking my 103 by doing the old top plate hold and turn.
Pop the wheels off,loosen the top deck nuts/screws, and have a bud hold the chassis on a FLAT surface while tightening the nuts.
Also check the "squarness" of the rear pod cage. I usually will take off the t-bar and do the steps above to the motor pod.
Don't count out front springs either. I had a real bad hooking problem and it turned out to be a bad front spring. I switched EVERYTHING on the car but the front springs (they "looked" good) and could not make it go away.A bud was watching my touring car hook during practice and suggested I try a stiffer front setup (thanks Mr.Cali).. So the bell went off in my head... put in a set of stiffer springs and the f1 car was hooked up .
j.d.roost is offline   Reply With Quote
Old 04-08-2010, 11:09 AM   #1149
Thanks jd, I had forgetten about that method to line things up.
Old 04-08-2010, 02:24 PM   #1150
GasGod's Avatar
Just be sure both front tires are the same dia.-or you will get a false tweek.
hell I'm even cheaper- I use pennies
losi 8t,mbx5t,rc8
rc8,Kyosho rb5,SCR
ft4 MT wallet
Old 04-08-2010, 02:30 PM   #1151
Manny's Avatar
Default Wolf f-1?
Looks like they're re releasing this car, presumably on an f103 chassis.
1/10 R/C Wolf WR1 (Limited Edition) (Tentative)
I'd like to see the Lotus 79, Williams Fw07 or Brabham Bt50 re-released for the f103 too!
Manny is offline   Reply With Quote
Old 04-08-2010, 05:45 PM   #1152
Hello all,
I'm looking for some front aluminum uprights that allow ride height adjustment. anyone know who makes them and what the part # is?
Cheerz
Obsidian is offline   Reply With Quote
Old 04-09-2010, 07:07 PM   #1153
downtempo's Avatar
Send a message via AIM to downtempo
I was told the Tamiya T body is a Yamaha replica, is this true?
If so, any suggestions on paint/team schemes?
downtempo is offline   Reply With Quote
Old 04-09-2010, 07:11 PM   #1154
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Looks good in white.
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 04-09-2010, 07:17 PM   #1155
downtempo's Avatar
^ I already did that w/ the Lotus and you're rocking the fast white car to boot.
What Yamaha powered teams can I scope out?
FS: Tamiya F103 mild seven Australia For Sale/Trade 4 08-20-2008 12:19 AM
Tamiya F103 GT izzyracer R/C Items: For Sale/Trade 2 03-01-2007 04:51 PM
Tamiya F103 NIB Jspecrcr R/C Items: For Sale/Trade 7 11-07-2006 02:30 PM
WTB: Tamiya buggy & Tamiya f103 stuff rays_tt Australia Wanted to Buy 2 04-20-2006 07:10 AM
Tamiya F103 or F103 Parts MM-F1 R/C Items: Wanted to Buy 4 04-24-2004 04:14 PM
SEO by vBSEO 3.5.0
