Like Tree6Likes
Old 04-05-2010, 01:51 PM   #1126
Foxxrocket's Avatar
Originally Posted by winnppl View Post
whare is the best place to buy a f-103/104 at?
Ebay
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 04-05-2010, 02:40 PM   #1127
robk's Avatar
Trader Rating: 22 (100%+)
Originally Posted by jakeg1999 View Post
I did get it used, and it was stated to be and appears barely used. Other than the tires havin a couple small chunks out of the sides, the cars looks close to brand new.
Don't go on looks
Get a new t bar as you have planned, and check those springs, and I will bet you will be good to go
Old 04-05-2010, 11:54 PM   #1128
Blueman Austria's Avatar
Default F104 Front supension in a F103
Hy there!
Wich parts are needed to build a F104 Front suspension in a F103?
My car has already the long topdeck, and the double side servo holders installed.
51380 D-Parts (Servo/Battery Holder)
51381 F-Parts (Front Suspension)
Are these two parts enough, or is anything else required ?
Greetz Blueman
_______________________________________________________________________
TT01, F104, TRF415MSXXMRE07, TB Evo5 Exoten, TB Evo6, TRF417v7, TRF 418........
Blueman Austria is offline   Reply With Quote
Old 04-06-2010, 05:57 AM   #1129
j.d.roost's Avatar
Trader Rating: 28 (100%+)
Well, with the outdoor season coming and my track running a rubber tire only rule I have yet to find a suitable rear f103 tire.
I ordered in the available trg super soft tires but they are WAY too soft.
I would guess they will only last a weekend (if that)..
Everything else (ride,cross) is either on backorder or discontinued...
I have a big race the 24th and can't ride out (no pun intended) a backorder.
Need some help here guys..any ideas?
Not getting forced into a 104 if I don't have to.
Jim
j.d.roost is offline   Reply With Quote
Old 04-06-2010, 06:12 AM   #1130
bakaguyjean's Avatar
Originally Posted by Blueman Austria View Post
Hy there!
Greetz Blueman
You also need the F104 king pins as they are longer than the F103 and the F103GT.
Not to be a jerk but why would you want to put an F104 front on your F103? It will just make you car handle like junk.
My body projects blog http://rcbodyproject.wordpress.com/
bakaguyjean is offline   Reply With Quote
Old 04-06-2010, 06:19 AM   #1131
j.d.roost's Avatar
Maybe he can't find f103 rubber tires...
It would make up for the offset problem but give away the
only advantage we have left over the newer cars (width).
Old 04-06-2010, 06:25 AM   #1132
Jim
i got these (top 2 on the list)
not tried them just yet but will do soon
http://rcmarket.com.hk/index.php?man...ef056kr80rgmk4
EDIT !!!! i see they are out of stock
sidecarphil1 is offline   Reply With Quote
Old 04-06-2010, 06:26 AM   #1133
Hy there!
Greetz Blueman
If you want, only need F parts. You can cut your existing servo mount to fit.
Obviusly, buy¡ng D-parts, it's easier.
You will need too 19808241 3x33.4mm King pin (std it's 27mm long)
prorace is offline   Reply With Quote
Old 04-06-2010, 06:38 AM   #1134
Jim
TRG Superion or super soft, are intended for qualifying.
Try rcmarket.com.hk for TRG medium rears.
Also, you can fit 104 wheels on your 103 with a little modding.
You will need a 2-3mm spacer between the motor mount and the T-Bar, found on F103Gt T Parts 51229 "part 2"
For the front you'll need to shave 2 mm in the upper portion of the uprigth to allow it to mount up.
Also, you'll need 104 front wheel bearings, because are bigger than 103's
Old 04-06-2010, 06:41 AM   #1135
j.d.roost's Avatar
There is a huge offset problem when using the 104 rear tires. (front wide rear narrow)
Old 04-06-2010, 06:42 AM   #1136
j.d.roost's Avatar
Yep out of stock.
Hit them up already.
Thanks though.
Old 04-06-2010, 09:00 AM   #1137
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
winnppl - you have a PM
madjack is offline   Reply With Quote
Old 04-06-2010, 10:08 PM   #1138
THX for the info!
Yes we realy thought about to use the F104 rubbers, but in that case we stay with our foamys!
Greetz Blueman.
BTW. have trimmed an 3racing F109 Body on my F103m and i have to cut the front section about 15mm shorter that it looks halfway good.
But the rear wing looks also good with my lod school Ferrari Body on....
Hope i can do painting soon...
Greetz Blueman
Old 04-07-2010, 04:49 AM   #1139
j.d.roost's Avatar
THX for the info!
Greetz Blueman.
Attachment 577165;Attachment 577166
Attachment 577167
Greetz Blueman
Not too shabby Blueman.
Give us a full pic when its all done (wheels on).
Is that the 3 racing 109 front wing?
Old 04-07-2010, 10:25 AM   #1140
Trader Rating: 47 (100%+)
Originally Posted by robk View Post
Don't go on looks
I agree....I ordered a new soft T-plate....I took most the whole car apart this morning including the front springs....Everything looks nice and even, but all be darn if I can't get it to go straight. If I just tap the throttle it spins left, and opposite for braking. I even tried messing with some weights on both sides just to see if I was off, and no change......I am starting to think, or hope that even thought the T-bar looks flat on a flat surface, it may be stressed under acceleration and decelerration......Hopefully I will figure this out....thanks for your help so far....
jakeg1999 is offline   Reply With Quote
FS: Tamiya F103 mild seven Australia For Sale/Trade 4 08-19-2008 11:19 PM
Tamiya F103 GT izzyracer R/C Items: For Sale/Trade 2 03-01-2007 03:51 PM
Tamiya F103 NIB Jspecrcr R/C Items: For Sale/Trade 7 11-07-2006 01:30 PM
WTB: Tamiya buggy & Tamiya f103 stuff rays_tt Australia Wanted to Buy 2 04-20-2006 06:10 AM
Tamiya F103 or F103 Parts MM-F1 R/C Items: Wanted to Buy 4 04-24-2004 03:14 PM
