Like Tree6Likes
Old 03-24-2010, 02:34 PM   #1081
Trader Rating: 47 (100%+)
Ok, thanks....Would there be any benefit to runnung the f104 diff??
jakeg1999 is offline   Reply With Quote
Old 03-24-2010, 02:48 PM   #1082
yeah you can remove the wheels without loosening the Diff off
sidecarphil1 is offline   Reply With Quote
Old 03-24-2010, 09:14 PM   #1083
bakaguyjean's Avatar
A little help here, unfortunately while getting my F103 ready for it's first run, I managed to snap the screw on the left hand sid wheel stopper. The bolt that holds the wheel on...Yes I tightend to the wheel nut just a little too much. I am having a hard time finding the part, but have found the F104 dif set on Tower. I am actually about to place an order with them anyway, and was wondering if this set: http://www3.towerhobbies.com/cgi-bin...?&I=LXXRA4&P=Z is a direct fit and an upgrade? Or should I keep looking for the part I brok which is: 53248
The F104 diff will work on your F103 and it is a better diff as it doesnt use a thrust bearing,but you need a shorter axle. Either cut yours down or order the F104 axle.The uses three bearings instead of the two in the F103 diff making it smoother, Also you can take the wheel off without looseing the diff.
But you still need the left wheel stopper so the diff doesnt do you any good.
My body projects blog http://rcbodyproject.wordpress.com/
bakaguyjean is offline   Reply With Quote
Old 03-25-2010, 03:05 AM   #1084
chinaman's Avatar
Originally Posted by pejota View Post
... i'm having issues finding tires, wheels and websites where i can buy wheels and tires for my F103.
Can someone provide me with part numbers of foam tires/wheels i can use outdoors on asphalt/concrete in Florida (think crazy hot track temps) ...
I have an LM, which has the same rear axel as a RM or RS,
Zen tyres (F1-R35B) for a shore 35 foam rear tyre (tyre+rim). F1-F35B for a front tyre etcetera.
If you change your rear axel to a GT,
ZAC tyres (ZW-9121) for a shore 37 foam rear tyre (tyre+rim).
Track width is still maintained at 200mm as the rim has an offset, more for the rear.
Both available from RCChamp in Japan by special order.
http://tabata.jp/zac/products/zac_tire_10.html
Why would you change to a GT rear axel?
In the wet, I use touring car wet tyres : ) only down side is that your ride height is at best 9mm. I race my F103 in a GT class, or at least I try to as I am up against Associateds and CRC. ; )
I have been using tyres from the 2nd table down in the list, (shore 35-40) 30mm fronts and 40mm rears, and they are very good even for temps below 20C (unsure what it is in F) but I have not used them in, I presume hot temps in Florida, but they are rated for shore 42? Whatever that comes to ...
... wyrd bi ful rd ...
chinaman is offline   Reply With Quote
Old 03-25-2010, 12:50 PM   #1085
Ok, so I ordered the diff and rear axle last night, but now it sounds like I still need the left wheel stopper....Is this correct? I just want to double check before I buy one....
Old 03-25-2010, 01:17 PM   #1086
Foxxrocket's Avatar
Yes. The axle from left to right needs to be from the 104, or the 103. You can't inchange them.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 03-25-2010, 01:21 PM   #1087
Trader Rating: 16 (100%+)
hi can any1 tell me what parts are needed to convert F103rm to F103gt?
ronaldo-1234 is offline   Reply With Quote
Old 03-25-2010, 01:33 PM   #1088
Foxxrocket's Avatar
It would be easier simply to trade your F103 for a F103GT since F1 is getting bigger now.
Old 03-25-2010, 01:48 PM   #1089
so the conversion requires a lot of parts? Or isit a tedious task?
Old 03-25-2010, 02:02 PM   #1090
Foxxrocket's Avatar
Parts that are either going to be hard to find, or discontinued. You'll have better luck getting a whole one than looking in a lot of places for parts. It'll be cheaper too.
Old 03-25-2010, 02:03 PM   #1091
you need loads of parts
i wanted to change my F103GT to a F1 car
it was cheaper to order an F103 15th Anniverasy and sell the F103gt
chassis , front suspension , hubs , rear drive . . . . . . these are all differant
Old 03-25-2010, 02:16 PM   #1092
TFR
TFR's Avatar
I have a F103GT for sale if you are interested,
http://www.rctech.net/forum/r-c-item...-part-2-a.html
Muchmore l AHRP l Xenon l Futaba
TFR is offline   Reply With Quote
Old 03-25-2010, 02:48 PM   #1093
chinaman's Avatar
Now that is a neat and tidy chassis ...
Old 03-25-2010, 03:12 PM   #1094
chinaman's Avatar
It is not a tedius task ...
You need GT front knuckles and axel, the 2 bearings that you have currently in your front RM wheels can still be used in the GT knuckles. It will be in the knuckles instead of the rim. And a pair of 12mm hex wheel adaptor with the pin.
For the rear, left side,
You will need a GT left wheel mount adaptor. You will still need to use your existing 16mm spacer.
For the right rear,
You will need a GT diff joint, diff housing A & B, part no R3 from the GT (58367) manual and GT right wheel mount adaptor. The 3 1280 bearings in your RM will still need to be used. I still use my thrust bearings. You will also need to use the 2 spring washers and some spacer and an extra wheel nut to tighten the thrust bearings. The wheel mount goes on top of that so the next time you change your rear wheels you do not need to undo the thrust bearings.
I am using a 3 Racing diff housing which uses 2 parts instead of the 4 that Tamiya uses ... and all aluminium as well.
Will get a picture of my LM converted rear to show you.
Then you can decide to run a TC shell with your TC tyres or get ZAC foam tyres and still use your F1 shell to run it as a F1 car (track width 200mm.
It will cost you more than if you were to get a second hand GT car.
If you are as pedantic as I am, I got all my parts after-market and the only original part on my LM is the chassis, bumper, friction plate and damper. The rest are either 3 Racing or Yeah Racing from RCMart in Hong Kong.
Old 03-25-2010, 07:54 PM   #1095
For the right rear,
Thank you for ur advice, waiting to see ur pic
What about the chassis? does it need to be changed (I am running F103RM).
FS: Tamiya F103 mild seven Australia For Sale/Trade 4 08-19-2008 11:19 PM
Tamiya F103 GT izzyracer R/C Items: For Sale/Trade 2 03-01-2007 03:51 PM
Tamiya F103 NIB Jspecrcr R/C Items: For Sale/Trade 7 11-07-2006 01:30 PM
WTB: Tamiya buggy & Tamiya f103 stuff rays_tt Australia Wanted to Buy 2 04-20-2006 06:10 AM
Tamiya F103 or F103 Parts MM-F1 R/C Items: Wanted to Buy 4 04-24-2004 03:14 PM
