Like Tree1Likes
Old 03-20-2010, 03:01 PM   #1066
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Originally Posted by jakeg1999 View Post
I would also like to know the part number for the soft t bar, as I bought one as recommended, and it only fits the F104.....so if someone needs one, I have one for a great price....
try this
part # 53169 - formula car flex t-bar set (F103 chassis)
I got mine on ebay from HK
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 03-20-2010, 03:07 PM   #1067
Trader Rating: 47 (100%+)
Cool thanks.....I think my car actually has that on it already. The one that's on there is not CF it's FG. Does it originally come with a CF one?
jakeg1999 is offline   Reply With Quote
Old 03-20-2010, 03:09 PM   #1068
k_bojar's Avatar
not that i know...i've never seen a t-plate/t-bar for any kind of car in carbon fiber..
both the t-bar's i have (original and 53169) are made from fiberglass
you want the flex that's in the fiberglass to help with traction...
Old 03-20-2010, 03:12 PM   #1069
Gotcha, so what's the difference betwen the one that comes with the car and the soft one? Is it thinner?
Old 03-21-2010, 06:22 PM   #1070
Greetings all,
Just wondering if everyone is greasing the Thrust bearing. The 15th anniv. doesn't say anything about doing this. If so What Grease is recommended?
Cheerz
Obsidian is offline   Reply With Quote
Old 03-21-2010, 07:12 PM   #1071
DRAG_ON's Avatar
Originally Posted by Obsidian View Post
Greetings all,
Cheerz
i use associated "stealth ball diff grease" on my thrust bearing --- it's works like a charm
Freq:29.945, car no:29, W.A.R.C.M.C.C, http://projectm-design.blogspot.com/
DRAG_ON is offline   Reply With Quote
Old 03-22-2010, 12:54 AM   #1072
Thanks to abe-racing.Awesome service got some f1 stickers in less than a week.My problem now is i use tamiya polycarb paint on the wings.Anyone know of a way of keeping the paint on the bumpers without chipping off.We used to spray thinners on car bumpers to help keep the paint on.Got some boddies from tower hobbies on a special order.
colin
colin storey is offline   Reply With Quote
Old 03-22-2010, 06:55 AM   #1073
chinaman's Avatar
Default Lowering the front for the F103
Does anyone know how I can lower the front for a F103?
I have an LM chassis but have recently changed the front knuckle arms to the GT type, which can take a 12mm hex wheel adaptor. But the 12mm hex foam wheels that I eventually got have a slightly larger diameter, hence raising the chassis. It is currently running at 9mm (0.354inch)
Why have I changed to 12mm hex adaptor/GT? Well I got some ZAC tyres from Japan which uses 12mm hex and fits the rear and front perfectly and the foam is excellant with plentiful rear end grip.
I guess I could just use the LM/RM front wheel axel as their diameter is smaller, but the foam is not so good as compared to the ZAC tyres.
My rear I am using a motor mount with spacers (LM/RM) for the axel and so I can change the height accordingly.
apologies if this has already been discussed before but i have not gone through the 1000+ posts ...
... wyrd bi ful rd ...
chinaman is offline   Reply With Quote
Old 03-22-2010, 10:05 PM   #1074
mailboxck's Avatar
Are you using the link type front suspension like the F103GT? If you are, you can put plastic spacers at the bottom of the knuckles to make the ride height lower. Check the F103GT manual from the Tamiya site.
mailboxck is offline   Reply With Quote
Old 03-24-2010, 02:28 AM   #1075
Suspended
RobsPics is offline   Reply With Quote
Old 03-24-2010, 03:15 AM   #1076
chinaman's Avatar
Originally Posted by mailboxck View Post
Are you using the link type front suspension like the F103GT? If you are, you can put plastic spacers at the bottom of the knuckles to make the ride height lower. ...
Cheers ... I already have a spacer below the knuckle ...
Old 03-24-2010, 06:56 AM   #1077
pejota's Avatar
Hate to be "that guy" but i'm having issues finding tires, wheels and websites where i can buy wheels and tires for my F103.
Can someone provide me with part numbers of foam tires/wheels i can use outdoors on asphalt/concrete in Florida (think crazy hot track temps).
I've been to a couple of websites and searched the forums but i'm having a heck of a time figuring out what i should get. If rubber tires would be better for my circumsances, that's fine as well.
I'm just trying to figure out which one of my F1 cars to keep and then hopefully promote at my club track.
Thanks!!!
pejota is offline   Reply With Quote
Old 03-24-2010, 07:58 AM   #1078
Foxxrocket's Avatar
Foam tires are the way to go. They grip so much better than rubber tires. You can go two ways with this. Get the pre-mounted tires, Tamiya (#54135) F103 Front Sponge Tires/ Tamiya (#54136) F103 Rear Sponge Tires. Or get the tires and wheels separate. This is cheaper, and you have more options in tire compound.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 03-24-2010, 12:19 PM   #1079
A little help here, unfortunately while getting my F103 ready for it's first run, I managed to snap the screw on the left hand sid wheel stopper. The bolt that holds the wheel on...Yes I tightend to the wheel nut just a little too much. I am having a hard time finding the part, but have found the F104 dif set on Tower. I am actually about to place an order with them anyway, and was wondering if this set: http://www3.towerhobbies.com/cgi-bin...?&I=LXXRA4&P=Z is a direct fit and an upgrade? Or should I keep looking for the part I brok which is: 53248
Old 03-24-2010, 12:36 PM   #1080
robk's Avatar
Trader Rating: 22 (100%+)
You need
http://www.tamiyausa.com/product/ite...uct-id=3455372
or
http://www.tamiyausa.com/product/ite...oduct-id=50507
FS: Tamiya F103 mild seven Australia For Sale/Trade 4 08-19-2008 11:19 PM
Tamiya F103 GT izzyracer R/C Items: For Sale/Trade 2 03-01-2007 03:51 PM
Tamiya F103 NIB Jspecrcr R/C Items: For Sale/Trade 7 11-07-2006 01:30 PM
WTB: Tamiya buggy & Tamiya f103 stuff rays_tt Australia Wanted to Buy 2 04-20-2006 06:10 AM
Tamiya F103 or F103 Parts MM-F1 R/C Items: Wanted to Buy 4 04-24-2004 03:14 PM
