Like Tree1Likes
Old 03-01-2010, 03:25 PM   #1021
GasGod's Avatar
my bad I thought he was popping endbells--
F! Metal Militia,VTA NATION--Team SloMoFo
losi 8t,mbx5t,rc8
rc8,Kyosho rb5,SCR
ft4 MT wallet
cyclone;xxx-s;x-rayT2;crc gen xl;bmi 12rrl
GasGod is offline   Reply With Quote
Old 03-01-2010, 03:36 PM   #1022
Originally Posted by gramm View Post
Just need some advice; does anyone know what might cause this?
These are all tamiya parts except for the spur (kimbrough + HPI spur spacer). Something is causing the thrust race to rub on one side of the diff joint. As you would imagine the diff feels horrible in that particular spot (feels much like a tight-spot). Where would a likely suspect point be in this setup? Thanks
Cheers
Daniel
I think Robk's right on this...looks like you have the wrong bearing or no bearing in the outside edge of the diff hub.
Old 03-01-2010, 03:50 PM   #1023
Originally Posted by GasGod View Post
Make sure you tap the endbell tabs tight into their slots b/4 installing motor,and keep an eye on them.they loosen up w/left side wallbanging.
with the speeds @ Horsham it will happen on 540's.
Back in "the day"we used to allow 2 screws thru the can to secure the endbell.
Greets everyone,
I've been wondering what everyone is doing to their 540J motors to squeeze every gram of performance out of them. Any suggestions would be nice.
Cheerz
Obsidian is offline   Reply With Quote
Old 03-01-2010, 05:34 PM   #1024
j.d.roost's Avatar
Trader Rating: 28 (100%+)
Originally Posted by robk View Post
You also have to watch the motor temps. I have seen the comm move when the motor gets overheated, even without the wall shot.
Hmm good to know.
j.d.roost is offline   Reply With Quote
Old 03-02-2010, 01:40 PM   #1025
j.d.roost's Avatar
Did Tamiya change the front knuckle pins to non e clip style?
Looks like you need to grub screw the knuckle to the pin now.
Does the spring get moved from under the arm (with e-clips) to in between the knuckle and the arm (inside)?
Hope that was a clear enough description.
Old 03-02-2010, 02:16 PM   #1026
robk's Avatar
Trader Rating: 22 (100%+)
There's a couple setups, RD kingpins, Super king pins, etc. The one from the 15th anniversary car has the e clips, and there is another that puts the spring on top of the knuckle and is shorter, but uses E clips. I think the RD king pin is the grub screw one, which is for those who live dangerously....
Old 03-03-2010, 11:04 AM   #1027
kuanseng1981's Avatar
Trader Rating: 15 (100%+)
Hi guys, I am looking for Tamiya Type B for my F103 anyone have a set can let me know or can let me know where can I get them.
Friends come and go,
who's your friend nobody knows,
till the time than it will show,
who is friend who is foe.
kuanseng1981 is offline   Reply With Quote
Old 03-03-2010, 02:06 PM   #1028
robk's Avatar
Type B what? Tires? Body?
Old 03-03-2010, 04:05 PM   #1029
Sorrry guys my bad. I looking for Tamiya Type B tires and rims set.
Old 03-07-2010, 10:06 AM   #1030
won my first race ever with the F103
i won by 4 laps per final
car was a F103 15th Anniversary
black front springs
Tamiya yellow rear spring
350 oil in the shock with 2 hole piston
medium grease on the middle plate
little toe out
ride height 3.0mm
Kit tyres
roll out of 35.5mm 104/22
10.5 SP v3.0 motor
EZrun speedo
full rear smear for 30mins and ľon the front for 20 mins with LRP carpet traction2
think that was it but if i have forgotten anything let me know and i will look
my fastest lap was a 15.049 the lap record for a Pro10 is only 14.5
sidecarphil1 is offline   Reply With Quote
Old 03-07-2010, 11:50 AM   #1031
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Way to go, Phil
those SP v3 motors are pretty sweet
what other chassis were you running against??
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 03-07-2010, 12:09 PM   #1032
Sauber F1's Avatar
Sauber C13 from 1995 using a C12 model
More pictures in the "F1 discussion" topic
1/10 R/C F1's...Pics, Discussions, Whatever...
Roland
Sauber F1 is offline   Reply With Quote
Old 03-07-2010, 12:32 PM   #1033
Originally Posted by k_bojar View Post
Way to go, Phil
there was 3 F103s and 1 F104
i was trying the F1-09 but the Tamiya 15th Anniversary chassis is the nicest of them all for me , want to try outdoors but dont want to scratch the chassis
Old 03-07-2010, 03:15 PM   #1034
j.d.roost's Avatar
Good win.
Thanks for posting your setup.
Old 03-09-2010, 12:30 AM   #1035
zpmhinojosa's Avatar
Send a message via AIM to zpmhinojosa
This F103 #11 Honda "Camel" gets down with this #4 Ferrari !!!
Enjoy.
+ YouTube Video
zpmhinojosa is offline   Reply With Quote
FS: Tamiya F103 mild seven Australia For Sale/Trade 4 08-19-2008 11:19 PM
Tamiya F103 GT izzyracer R/C Items: For Sale/Trade 2 03-01-2007 03:51 PM
Tamiya F103 NIB Jspecrcr R/C Items: For Sale/Trade 7 11-07-2006 01:30 PM
WTB: Tamiya buggy & Tamiya f103 stuff rays_tt Australia Wanted to Buy 2 04-20-2006 06:10 AM
Tamiya F103 or F103 Parts MM-F1 R/C Items: Wanted to Buy 4 04-24-2004 03:14 PM
