Old 02-21-2010, 05:52 AM   #1006
TFR
TFR's Avatar
This ride is for sale is any of you guys are interested.
* * * Out of hobby sale * * *
Muchmore l AHRP l Xenon l Futaba
TFR is offline   Reply With Quote
Old 02-21-2010, 01:09 PM   #1007
i broke my left side rear axle mount today
tapped by someone else into the barrier
GRRRR not available
sooo i ordered the one from TRG , the alloy one piece motor mount/axle mount
sidecarphil1 is offline   Reply With Quote
Old 02-21-2010, 01:30 PM   #1008
Hello all,
Is there a way to mount a servo on the F103 15th anniv. without cutting the servo ears off. I don't like the servo tape method that tamiya suggests. Perhaps there is a way to mount the servo flat. Any suggestions appreciated.
Cheerz
Obsidian is offline   Reply With Quote
Old 02-21-2010, 02:44 PM   #1009
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Originally Posted by Obsidian View Post
Hello all,
Cheerz
Not to my knowledge - the F103 bodies aren't wide enough to handle the servo laid down
if you're concerned about tape, try shoe-goo...that willhokd your servothru pretty much EVERYTHING!!!!
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 02-21-2010, 10:10 PM   #1010
F N CUDA's Avatar
Rough outing for me today at West Coast Raceway, lost the handle of the car and the driver. sorry
Hard to keep a grip when the car goes from great to junk.
Hurt a lot of parts these past couple days, found most but some are ridiculously hard to find.
TCS comin up this weekend and I'm lookin for help in finding an F103 gearbox, mainly just the cross piece to mount the friction plate.
Also need a front upright/spring post with 3 clip grooves.
Any tips would be much appreciated.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 02-22-2010, 12:35 AM   #1011
gramm's Avatar
Just need some advice; does anyone know what might cause this?
These are all tamiya parts except for the spur (kimbrough + HPI spur spacer). Something is causing the thrust race to rub on one side of the diff joint. As you would imagine the diff feels horrible in that particular spot (feels much like a tight-spot). Where would a likely suspect point be in this setup? Thanks
Cheers
Daniel
gramm is offline   Reply With Quote
Old 02-22-2010, 04:43 AM   #1012
k_bojar's Avatar
Cheers
Daniel
does your thrust bearing cleanly side onto that shaft? i know some times the tolerances are off just a smidge and you'll get marks like that..also could be that the thrust bearing is shot - sometimes the slightest touches kill them
I'd pull the thrust bearing out and check that first
Old 02-23-2010, 12:29 AM   #1013
Hello everyone,
Just curious if everyone is rounding the edges and gluing the chassis edges on their F103's.
Cheerz
Old 02-26-2010, 02:07 AM   #1014
Hello everyone,
Cheerz
i used a piece of sandpaper only on the edges of the bottom deck then superglued all the edges ,
how do you keep the battery in place on the 15th anniversary ??
i used some double sided tape to the top deck ???
Old 02-26-2010, 02:48 PM   #1015
robk's Avatar
Trader Rating: 22 (100%+)
Cheers
Daniel
Is the outer bearing the correct size? It looks like the ID is too big for the axle??
Old 02-26-2010, 03:36 PM   #1016
downtempo's Avatar
Send a message via AIM to downtempo
strapping tape
@obsidian - you would be wise to at least seal all edges w/ glue
downtempo is offline   Reply With Quote
Old 03-01-2010, 07:17 AM   #1017
j.d.roost's Avatar
Trader Rating: 27 (100%+)
Is anyone else having a problem with their 540j motors pushing the com back (effectively destroying the motor ) after a smack or two into the wall?
I don't know what is causing this to happen but I am on my 3rd motor that did this.
Thanks for the help.
j.d.roost is offline   Reply With Quote
Old 03-01-2010, 07:34 AM   #1018
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Fairly common occurrence, I've seen that happen to a few cars at our local track.
That motor is not built to take hard hits into walls.
BL 21.5 is what most of us are running around here now.
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 03-01-2010, 01:53 PM   #1019
GasGod's Avatar
Make sure you tap the endbell tabs tight into their slots b/4 installing motor,and keep an eye on them.they loosen up w/left side wallbanging.
with the speeds @ Horsham it will happen on 540's.
Back in "the day"we used to allow 2 screws thru the can to secure the endbell.
F! Metal Militia,VTA NATION--Team SloMoFo
losi 8t,mbx5t,rc8
rc8,Kyosho rb5,SCR
ft4 MT wallet
cyclone;xxx-s;x-rayT2;crc gen xl;bmi 12rrl
GasGod is offline   Reply With Quote
Old 03-01-2010, 03:45 PM   #1020
robk's Avatar
You also have to watch the motor temps. I have seen the comm move when the motor gets overheated, even without the wall shot.
FS: Tamiya F103 mild seven Australia For Sale/Trade 4 08-20-2008 12:19 AM
Tamiya F103 GT izzyracer R/C Items: For Sale/Trade 2 03-01-2007 04:51 PM
Tamiya F103 NIB Jspecrcr R/C Items: For Sale/Trade 7 11-07-2006 02:30 PM
WTB: Tamiya buggy & Tamiya f103 stuff rays_tt Australia Wanted to Buy 2 04-20-2006 07:10 AM
Tamiya F103 or F103 Parts MM-F1 R/C Items: Wanted to Buy 4 04-24-2004 04:14 PM
SEO by vBSEO 3.5.0
