Tamiya F103 Forum
#992
check out http://www.tamiyausa.com - and click on the TCS racing link at the top...the entire 2010 schedule is there
March 7, 2010
Race #151
Hobbytown USA
919C N. East Street
Frederick, MD 21701
(301) 694-7395
July 25, 2010
Race #156
Hobby Town USA
6714 Ritchie Hwy # D
Glen Burnie, MD 21061
(410) 590-4950
#993
i am having a nightmere with my F103 15th anniversary
it is grip rolling on the fast sweeper on our track
every where else is ok if i keep my spped down a little but if i try to push it then it wants to go over !!!
it is totally box standard with 400 oil in the shock and a red spring ,
any help would be appretiated
#994
About as good as you can get, looks like they are too much for your track?
Do you use sauce/traction additive?
Sauce the fronts? If so, tried without sauce on the front?
I never get away with saucing the fronts except for on carpet and even then it's only about 1/4 of the width that gets it.
If the tires aren't just right, setup won't usually fix it.
And if the tires are right, setup can be off a little and you can still drive it.
That's how I feel.
#995
Ride Height Fr, Rr ?
Tire sauce type, how much sauce, how long do you leave it on?
Damper disc lube, how tight are the plates, how much thread is open on top?
Kit silver can ?
Tire Diameter ?
#996
The 104 guys were traction rolling at our track (high grip carpet).
They put a bead of ca on the sidewall of the front tires and a small thin bead on the outer front edge of the tire (running surface). Worked like a champ.
#997
Just a reminder....
This Sunday 10 AM at WCRC will be F1 racing baby ....
http://www.charleslightfoot.com/WCRC%20F1/WCRC_F1.html
#998
So you guys run 540j's with 21 brushless?
What do you do about timing/boost?
Are the cars close in speed?
I would think a 21 brushless with a good esc would put the
smack down on a 540.
#999
* Brushed Silver can. This is a great place to start, available to everyone and can be very competitive.
* BL 21.5. With a gentleman's agreement to not use a timing advance curve on your ESC if you have the option. End bell advancement should also be set to zero.
* Batteries are restricted to two cell 8.44v LiPo or 6 cell Nimh/NiCd.
If you want to run other power plant options please do not expect to be placed in the A mains or receive points at the events.
http://www.rctech.net/forum/6939536-post638.html
#1000
i can smeer full rear for 20 mins and half front for 10 mins and it drives perfectly till the battery goes flat !!!!
i run a 13.5 motor in it with an EzRun speedo and a lipo and it is quick and stable
#1001
is there a replacement for the Tyres in the F103 15th Anniversary
i would like either a tamiya part number or another make that has the same compound
i am really enjoying driving the F103 now it handles well , so much so that i put a 10.5 in it today
#1002
Front TAM54135
Rear TAM54136
http://www.speedtechrc.com/store/ebp...?catmainid=794
#1003
Those are the Tamiya PreMounts
Front TAM54135
Rear TAM54136
Front TAM54135
Rear TAM54136
i like the grip with these but this is the only set that i have tried
#1004
Those are very high quality tires.
"Better" is more a matter of balance, what more do you want the car to do.
For carpet, I don't think there is a better tire on the 103.
Those tires also work at every track I have run at on all surfaces.
There are so many tires available for the F-103 one could get lost trying them all, a good problem to have, as we are so limited with the F-104 so far.
#1005
then in that case i will order a new set of those as the car is good on them
i have been given some new rubber tyres but not tried them just yet , and probably wont as it is soon time to got race outdoors and i wont use the F103 outdoors as i dont want to scratch the 15th Anniversary chassis plate
