Old 02-17-2010, 04:35 PM   #976
GasGod's Avatar
I think the hpi sealed 20t is about = to a good 27t stocker like a cobalt.
I ran a 19t checkpoint in a 103 and it was pretty silly in the twisties.
But this past weekend @ Horsham 1 guy had a 17.5/2s in our class of silvercans,and he wasn't that much faster on the infield-but on the 90' straight------he was ----- he swore he had his spx set on profile 1
plus he was a very good driver.We usually are only 1-1.5 sec a lap off of the 17.5 rubber TC class in lap times.Gotta love a $12 motor.
F! Metal Militia,VTA NATION--Team SloMoFo
losi 8t,mbx5t,rc8
rc8,Kyosho rb5,SCR
ft4 MT wallet
cyclone;xxx-s;x-rayT2;crc gen xl;bmi 12rrl
GasGod is offline   Reply With Quote
Old 02-17-2010, 06:25 PM   #977
clittle's Avatar
I know that feeling. We have a joke with one of the guys who runs with us. He's put the 17 turn Tamiya brushless in his car. Through the infield, no problems, but on the straight, the guys around him simply yell "TURBO!"...
Latest is a Tamiya TB04 Pro..... Love it!!!
Aussie in Japan!
clittle is offline   Reply With Quote
Old 02-17-2010, 08:55 PM   #978
Hallo everyone,
What are you guys doing to the silver cans to make them crazy fast?
Cheerz
Obsidian is offline   Reply With Quote
Old 02-17-2010, 09:32 PM   #979
F N CUDA's Avatar
Trader Rating: 30 (100%+)
Originally Posted by Obsidian View Post
Hallo everyone,
Cheerz
Oh no he just dih' int!
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 02-17-2010, 10:41 PM   #980
robk's Avatar
Trader Rating: 22 (100%+)
Step 1: buy neo magnets ............
Old 02-18-2010, 03:11 AM   #981
chinaman's Avatar
Originally Posted by InspGadgt View Post
... something wrong with the spring washers that put the pressure on the thrust washers. Over time these spring washers go flat and no longer work properly ...
Originally Posted by F N CUDA View Post
What method do you use to set your diff?
Will your diff stop slipping if you tighten it, are you trying to run it loose?
Put it on the track, punch it, if it slips tighten it, if it won't tighten you have something wrong. Put fresh spur gear, diff balls and rings $10 and fresh thrust bearing $5 more. Repeat adjustment process Newly freshened diff, PRICELESS ...
I try to tighten them up as much as possible without the car spinning out coming out of a turn.
Could be over geared as well. Am using pinion 18T with 63T spur. My 16T pinion is in the post. I have tried 14T as well and was a bit slow at the end of the staright.
My spring washers are a bit old they do somethimes flip the other way if i tighten them up too much which is why i try my best to tighten them up without 'flipping them'
I am going to order some from HK (i presume they are 5mm spring washers)???
... wyrd bi ful rd ...
chinaman is offline   Reply With Quote
Old 02-18-2010, 07:03 AM   #982
j.d.roost's Avatar
Trader Rating: 27 (100%+)
One very nice setup is the 104 alloy diff. You will need the diff.set and a 104 rear axle. No more wheel loaded thrust bearing!
It's so nice to be able to rotate my rear tires.
j.d.roost is offline   Reply With Quote
Old 02-18-2010, 07:08 AM   #983
j.d.roost's Avatar
BTW.. Is Tamiya for real that you cant use 104 parts on a 103 for a "Tamiya" event??
Alot of the 103 parts are no longer available or very hard to find (like the 103carbon axle). With 104 parts that bolt right up I don't see a problem.
I would think a bit of flexing of the rules are in need here.
Old 02-18-2010, 08:10 AM   #984
F N CUDA's Avatar
From what I understand, the F104 axle/diff is a hop up option offered for both the F104 AND F103 and is legal for TCS events whereas the gearbox is only an option for the F104.
Found it, QUOTE from Fred M. :
A. The F103 may use the F104 diff housing and carbon axle. It's a Hop Op for either car.
B. The F103 may only use the F103 aluminum or stock motor pd parts. The F104 one may not be used.
FM
Craig Hammon
Last edited by F N CUDA; 02-18-2010 at 08:28 AM. Reason: found ruling on 104 diff/axle
Old 02-18-2010, 08:19 AM   #985
F N CUDA's Avatar
Not sure why the spring washers would flip inside out.
That seems as tho it would take a lot of torque to do that.
I don't think the diff should slip at all when punching from a dead stop, correct?
If you use it as a slipper clutch it's only good for a couple seconds and it's toast.
A good diff is butter smooth and will stay that way a long time unless you let it slip.
My understanding is to keep it as loose as possible with 0 slippage.
If your car is spinning out after that, you have traction issues. No?
If you can't get the diff to keep from slipping there is definately a problem with parts of the diff assembly.
Anyone else have different views or added input on this?
Craig Hammon
Old 02-18-2010, 11:31 AM   #986
I've never seen a spring washer so worn out that it flips direction. That is super worn out and if it is that bad the thrust washers and bearing probably need replacing as well. I'd say it's time for a complete diff rebuild.
Old 02-18-2010, 12:33 PM   #987
j.d.roost's Avatar
Hallo everyone,
Cheerz
ez
Old 02-18-2010, 12:49 PM   #988
k_bojar's Avatar
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
ez
the ol' 'dunk the motor in water' trip
that's the simpliest and most well known trick
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 02-18-2010, 01:27 PM   #989
i ran mine in for 40 hrs on 2A
fastest M03 at the track
sidecarphil1 is offline   Reply With Quote
Old 02-18-2010, 01:35 PM   #990
k_bojar's Avatar
wow.....
FS: Tamiya F103 mild seven Australia For Sale/Trade 4 08-20-2008 12:19 AM
Tamiya F103 GT izzyracer R/C Items: For Sale/Trade 2 03-01-2007 04:51 PM
Tamiya F103 NIB Jspecrcr R/C Items: For Sale/Trade 7 11-07-2006 02:30 PM
WTB: Tamiya buggy & Tamiya f103 stuff rays_tt Australia Wanted to Buy 2 04-20-2006 07:10 AM
Tamiya F103 or F103 Parts MM-F1 R/C Items: Wanted to Buy 4 04-24-2004 04:14 PM
SEO by vBSEO 3.5.0
