Like Tree6Likes
Old 02-08-2010, 09:21 PM   #916
robk's Avatar
Trader Rating: 22 (100%+)
Originally Posted by RedBullFiXX View Post
Hey Rob.
Well to be honest I was having a bit of a laugh as one of my F-103's has been sitting on the shelf for a very long time
However, I don't really go thru T-bars that often, a little c.a on the countersink of the screw hole helps with durability, and I just use the std t-bar, not the soft.
I mount them up in the std format, 1 o-ring only, or occasionally with the pivot ball system.
The old 12L t-bars were very sensitive, and I did replace those monthly.
I think that is due to the more solid mounting system and tweak screws used in that application.
Carpet, asphalt, sticky, loose. I've run that car everywhere and generally tune with tires more than chassis.
My favorite setup on carpet was with the pivot ball bar, std front end, and Pre-mounts, tons of controllable steering, great roll thru the corners.
My t-bars may have somewhat less abuse than others, your mileage may vary
I figured something was up with the 15th anniversary t bar
Oddly enough, we're pretty close on carpet setup. I just like the o ring type setup better, since it seems to work better in the traction roll type conditions that come up around here.
Old 02-08-2010, 09:29 PM   #917
Might want to give the pivot ball suspension another try but this time add in a couple of tweak screws at the front pivot. This gives the pivot ball rear a tighter feel and allows you to adjust tweak too. There are already a couple of holes on either side of the pivot to use...they just need to be drilled a little larger to take a tweak screw.
Old 02-08-2010, 09:37 PM   #918
robk's Avatar
I actually started out that way last year when I first got into TCS/F1. Basically I found that the oring type setup produced the same result with 99% less work Having done quite a bit of 1/12 racing, I figured the tweak screws and pivot setup would be the only way to go. I literally tested it back to back, and it was virtually identical in lap time.
Old 02-08-2010, 09:43 PM   #919
True...but you'll get less t bar wear that way. For the track we used to run on the pivot ball suspension with the soft t bar and active front suspension was the way to go. If we had really nice high traction tracks I'm sure the setup would have been more like what everyone else was running with the standard front end.
Old 02-09-2010, 05:30 AM   #920
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
I asked this before, but didn't seem to get an answer
but how to the F104 rubber wheels/tires work on the F103? do the offsets work out ok?
trying to find a 'tamiya-only' alternative to the one's Lightfoot recommended
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 02-09-2010, 10:19 AM   #921
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
We mounted the F60 kit tires onto an F109, which is similar in dimensions to the F103, and it just made the rear track width narrower. The front rims are almost dead nuts equal, but the rears are definitely narrower. The rear hax adaptors / hubs are the same on all the 103/104 type cars, including the 3racing F109, so they bolt right up. The front rims are different between the 103 and 104 cars, in the bearing flange area. Papo didn't have any issues mounting the front rubber rims to his F109, so it looks like a straightforward swap.
Why don't we endurance race more often?
Greg Sharpe is offline   Reply With Quote
Old 02-09-2010, 12:27 PM   #922
j.d.roost's Avatar
Trader Rating: 28 (100%+)
With the 104 rears mounted on my 103 (foams).
The track was much wider in the front (eyeometer says about 1/4 or more on each side). I assume the rubber tire dimentions are the same. The front track on a 104 is narrower but the front wheel offset is "about" the same
(103/104). I would think this would cause all sorts of handling issues.
j.d.roost is offline   Reply With Quote
Old 02-09-2010, 01:02 PM   #923
k_bojar's Avatar
hmmmmmm
ever think about doing foams outside at jackson for F1?
Old 02-09-2010, 01:53 PM   #924
hmmmmmm
If both the rubber compounds are terrible, we'd certainly try foams. But so far none of the F104 owners want to run foam. Gotta cater to the masses.
Old 02-09-2010, 01:56 PM   #925
k_bojar's Avatar
that's cool...just figured i'd ask
so will it be open to ANY rubber tire or just Tamiya's rubber tires?
Old 02-09-2010, 02:37 PM   #926
Giorgio's Avatar
Does anyone knows were I could find an F103 blank setup sheet? Thanks!!!
https://www.facebook.com/FenixRacing.it/
www.fenixracingshop.com
Giorgio is offline   Reply With Quote
Old 02-09-2010, 04:02 PM   #927
j.d.roost's Avatar
hmmmmmm
Ride makes a good set of rubber tires but they are on intergalatic back order.
Look's like if we want to run f103 outside we are going to need a plan b.
I have a set of those $$$$ trg rears on the way,I will let you know if they are any good.
Old 02-09-2010, 04:04 PM   #928
k_bojar's Avatar
yup - saw that about the ride tires...
i was thinking about getting a set of the tamiya rubber rims and trying either the F201 tires i have sitting around or getting a set of the HPI optional tires and see that happens...
worse comes to worse, i'll get the F104 rims and tires and just use a few spacers to widen the rear
Old 02-09-2010, 07:24 PM   #929
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Ride tires for F-103 are in stock @ rcmarket as of now !
http://rcmarket.com.hk/index.php?cPa...a&filter_id=63
I heard Speedtechrc was going to have some as well ?
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 02-09-2010, 07:50 PM   #930
F N CUDA's Avatar
Trader Rating: 31 (100%+)
DUDE!
You just let the cat out of the bag!
I ordered my Rides on Sunday and they should be here as fast as the Hi Dollar mail option will get em here.
Craig Hammon
F N CUDA is offline   Reply With Quote
FS: Tamiya F103 mild seven Australia For Sale/Trade 4 08-20-2008 12:19 AM
Tamiya F103 GT izzyracer R/C Items: For Sale/Trade 2 03-01-2007 04:51 PM
Tamiya F103 NIB Jspecrcr R/C Items: For Sale/Trade 7 11-07-2006 02:30 PM
WTB: Tamiya buggy & Tamiya f103 stuff rays_tt Australia Wanted to Buy 2 04-20-2006 07:10 AM
Tamiya F103 or F103 Parts MM-F1 R/C Items: Wanted to Buy 4 04-24-2004 04:14 PM
