Like Tree6Likes
Old 02-04-2010, 01:31 PM   #886
F N CUDA's Avatar
Trader Rating: 31 (100%+)
Originally Posted by k_bojar View Post
so they bolt right up to the F103's t-plate?
does this effect the F103's rear axel and diff parts? or will that need to be swapped out as well?
and you just made my day
Yep, bolt right up.
I've been running mine for months. I have the aluminum set.
Now when you smack the wall with the rear wheel the side plates don't break.
It will kill your bearings, axle, wheels and will even pop the endbell off your silver can motor!
I run the steel axle now and those are the end results to my wall smacks since the carbon and aluminum axles are now long gone.
I don't mind, I just keep bearings handy since I can't stay off the wall, too inviting to pass it up.
I modified the axel adjuster/eccentrics to allow for more ride height by filing down the adjuster right down to the bearing which allows the axle to ride lower in the side frame. I take up the extra space by installing a set screw into the top of the plastic adjuster.
Works well, I can now run my foams til they scream for help.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 02-04-2010, 01:47 PM   #887
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Originally Posted by F N CUDA View Post
Yep, bolt right up.
i can live with the bearing issue
so do i need the COMPLETE F104 gear box, or can i just get the F104 aluminum side plates?
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 02-04-2010, 01:52 PM   #888
robk's Avatar
Trader Rating: 22 (100%+)
Depending on your purposes, you may not want the 104 gearbox. If you want to run any TCS races, the 104 gearbox is illegal for the 103. Otherwise go for it.
51243 F103GT Gear Case Set is what you need if you want to stick with 103 parts. The F103 metal motor mount will take the place of the plastic motor mount from this set.
Old 02-04-2010, 01:56 PM   #889
k_bojar's Avatar
good point, didn't even consider that - was just trying to find a way to get the better motor mount, then couldn't find the update gear box
thanks Rob
Old 02-04-2010, 02:10 PM   #890
F N CUDA's Avatar
I haven't heard of the left side F103 aluminum side plate to match the "heatsink" right side motor mount plate.
Is this a real deal from Tamiya?
I see the 51243 as the plastic set.
Aftermarket guys make em, I knew of them.
Also, Fred allowed the F104 plates on my F103 as well as others for the Nationals last year.
It was not considered a modification since it is stock Tamiya issue.
Does he still feel the same? Not sure but don't see why not.
I was sketchy on it til he ok'd it.
Craig Hammon
Old 02-04-2010, 09:47 PM   #891
F N CUDA's Avatar
I just saw that Fred posted that the F104 axle and diff assembly MAY be used on both the F104 and the F103 as it is a hop up option offered for both chassis.
The aluminum F104 motor pod MAY NOT be used on the F103, only the F103 parts may be used.
Now I'm really interested in finding out if there is an aluminum left side gearbox from Tamiya for the F103!
Anyone?
Craig Hammon
Old 02-04-2010, 10:08 PM   #892
downtempo's Avatar
Send a message via AIM to downtempo
Anyone?
lame, they know there is no alternative... board slaps on non-drive side = doom for TCS events (though to be fair, not an issue @ the AV track)
that 104 gearbox sure is purdy doe!
downtempo is offline   Reply With Quote
Old 02-05-2010, 01:19 PM   #893
k_bojar's Avatar
ok - another silly newbie question...
what's the 'c' body supposed to be similar to? i remember seeing something about how they handle compare to the 't' and 'm' bodies
just wondering since that seems to be the only one I can find
Old 02-05-2010, 01:50 PM   #894
robk's Avatar
As far as I know there is no left side metal 103 plate. I was talking about the motor side metal plate. The 51243 set is plastic, and is what he needs since I think he has the old non adjustable axle height plastic parts. The 51243 is adjustable.
I think it is the Sauber??? as Ithink the T was the Tyrell.
Old 02-05-2010, 03:49 PM   #895
GasGod's Avatar
I hear the Benetton body was the best-If ya can find one--True?
F! Metal Militia,VTA NATION--Team SloMoFo
losi 8t,mbx5t,rc8
rc8,Kyosho rb5,SCR
ft4 MT wallet
cyclone;xxx-s;x-rayT2;crc gen xl;bmi 12rrl
GasGod is offline   Reply With Quote
Old 02-05-2010, 03:50 PM   #896
RossoTorro's Avatar
C-Body is Lotus 107B
T-Body is Tyrrell 023
L-Body is Ligier JS41/Benetton B195
M-Body is McLaren MP4/13...
I hope some new will be released. And with proper decals.
Got 2x Tyrrell P34's now, one is built, just needing som paint on body.
RossoTorro is offline   Reply With Quote
Old 02-05-2010, 09:17 PM   #897
k_bojar's Avatar
what brand of rubber tires is everyone running on their F103?
anyone try the new F104 rubbers? how do they work/mount up on the F103?
i haven't raced mine competitively, so i'm not into all the different 'which works best' ideas so any help would be appreciated
this isn't for TCS racing, just some racing over the summer
Old 02-06-2010, 10:58 PM   #898
j.d.roost's Avatar
Trader Rating: 28 (100%+)
Default hooking
Had a big problem tonight. Out of the blue my 103 (foam carpet car) started hooking on off power left turns (turn in). It will get worse as the tire sauce wears off.
I found no tire problems and the diff.feels good. D.rate on the tx has been the same.I would guess the car got tweaked but could not see any issues.Where should I start looking?
j.d.roost is online now   Reply With Quote
Old 02-06-2010, 11:20 PM   #899
lightfoot's Avatar
Best tire I have found for the F103 is made by RIDE...
You can get it from RC Market... There is ALWAYS a 2 week back order, recently that turn around has been as much at 6+ weeks... yikes...
But there worth it...
RIDE 25001 F103 REAR WHEEL ( SILVER LUSTER LESS )
RIDE 25000 F103 FRONT WHEEL ( SILVER LUSTER LESS )
RIDE 24001 F103 REAR TIRE (TYPE-A)
RIDE 24000 F103 FRONT TIRE (TYPE-A)
a full set of rubber plus wheels including shipping is $50
Hope this helps....
Love and Peace...
lightfoot is offline   Reply With Quote
Old 02-07-2010, 09:33 AM   #900
BadSign's Avatar
Trader Rating: 15 (100%+)
1. There's probably too much weight on the right rear and not enough on the left. Tighten your left tweak screw and loosen the right until the weight is balanced
2. Check your right front suspension and make sure there hasn't been some massive failure- spring collapsed, whatever.
This is the day the Lord has made, I will rejoice and be glad in it- Psalms 118:24
World Champion Turn Marshall
BadSign is online now   Reply With Quote
FS: Tamiya F103 mild seven Australia For Sale/Trade 4 08-19-2008 11:19 PM
Tamiya F103 GT izzyracer R/C Items: For Sale/Trade 2 03-01-2007 03:51 PM
Tamiya F103 NIB Jspecrcr R/C Items: For Sale/Trade 7 11-07-2006 01:30 PM
WTB: Tamiya buggy & Tamiya f103 stuff rays_tt Australia Wanted to Buy 2 04-20-2006 06:10 AM
Tamiya F103 or F103 Parts MM-F1 R/C Items: Wanted to Buy 4 04-24-2004 03:14 PM
