Old 11-30-2009, 01:08 AM   #841
lightfoot's Avatar
Default Need Help...
My friend and I have both been having similar problems with our cars and we can't seem to find the solution... someone out there must know the answer
F103 and F103GT.... same problem... slower speeds, making a turn, as soon as I lift off the gas, the rear end of the car swings around... If I hold on the trigger slightly, it reduces the problem...
It's driving me nuts
I have a F103 that does not have this problem at all, so I know it can be fixed...
Please help...
Love and Peace...
lightfoot is offline   Reply With Quote
Old 11-30-2009, 03:54 AM   #842
DRAG_ON's Avatar
i have similar problem after i change the tires.................. lift up the acceleration car spin straight away even with very little steering.
Freq:29.945, car no:29, W.A.R.C.M.C.C, http://projectm-design.blogspot.com/
DRAG_ON is offline   Reply With Quote
Old 11-30-2009, 10:08 AM   #843
F N CUDA's Avatar
Trader Rating: 30 (100%+)
I had that goin on too.
Made sure no dragbrake, actually had it creepin forward when off the trigger and it still spun out.
Found my ride height just a tiny bit too low and the chassis would drag on the front of the T plate, right at the belly of the chassis when letting off and the weight transferred to the front.
I found this by putting a piece of tape on the chassis to see if it was dragging.
Made sure the center did not "hang" too low, corrected that and it was fine.
Either raise the ride height or add a little preload to the spring.
Something I always check now, not too much sag and not too low of a ride height.
May work for you?
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 11-30-2009, 01:20 PM   #844
lightfoot's Avatar
May work for you?
I have my throttle setting where the car slowly turns the wheels forward off throttle, and then I went back one click...
Ride height is 5mm rear and 4mm front...
The ESC I have a cheap model and can not be adjusted, has 0% drag break built in...
I'm running the center shock with no spring, so that is something I can try... I just set it up that way because my other F103 works the best at WCRC with that set up...
Love and Peace...
Old 11-30-2009, 01:46 PM   #845
Swamp Rat's Avatar
Please help...
you may have "drag brake"
in one profile i was running some problem everytime i lifted of for a corner she would spinout.
i found i was running a very little amount of drag.
dropped it to zero and presto no more spin.
Check your radio settings
The Rat
LCRCCC. inc. The Greatest Club in QLD.
Come see our great new layout.
Schumacher Mi6 x 2,MI5 EVO x 1, SP F1 x2,Serpent SF2 F1, MO5 mini, M03 Mini, Corally F1 on Rubber, Futaba 4PX (MIA),
Ax10, SCX10, JokerVisit : www.lcrccc.org.au
Swamp Rat is offline   Reply With Quote
Old 11-30-2009, 03:21 PM   #846
lightfoot's Avatar
The Rat
The ESC has no drag break, and when I hold the car in my hands and give it gas and suddenly let off, the tires keep spinning for about 2 seconds... drag break does sound like the obvious cause but unfortunately that's not it... I'm using a 4PK and can't find anything in the manual for setting drag brake...
Love and Peace...
Old 11-30-2009, 03:36 PM   #847
robk's Avatar
Trader Rating: 22 (100%+)
Please help...
If you are on a larger outdoor track, you may actually want enough "roll" in the radio that you'll have to hold the brake at the start of the race. I have had buddies who are A main national racers run up to +50 Forward on their radios in touring car with brushed stock motors. Just try a few setting to see what suits you.
Putting some heavy 1/8 diff oil on the front king pins can help as well. Start with 20,000 wt.
Old 11-30-2009, 03:59 PM   #848
racer x 1's Avatar
Trader Rating: 27 (100%+)
Please help...
if im correct i believe that you are getting way too much weight transfering to the front of the car off power so try slowing that down by using a stiffer center spring.
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 11-30-2009, 07:11 PM   #849
lightfoot's Avatar
Thanks Matt, I will try that as well... At least I have a few things to try next time out...
Love and Peace...
Old 11-30-2009, 07:20 PM   #850
racer x 1's Avatar
thats what im thinking lightfoot, i hope that it works for you. if im around next time i have a few other things that we could try to.
Matt Bell
Old 11-30-2009, 08:40 PM   #851
lightfoot's Avatar
Thanks dude... if you get your F1 by this Saturday and your not working swing by WCRC grand opening, were going to have a F1 class...
Love and Peace...
Old 11-30-2009, 09:48 PM   #852
racer x 1's Avatar
ima try!!!!!!!!!!!!
Matt Bell
Old 11-30-2009, 10:07 PM   #853
F N CUDA's Avatar
That's what I'm thinkin, if you have an F1 and have been wantin to run it, this is the perfect time to bring it out.
Shoot, bar b que, racin and even double racebux if you can pull off a win or 2!
Gonna be a blast!
Craig Hammon
Old 12-03-2009, 07:22 PM   #854
lightfoot's Avatar
Default WCRC F1 racing
Looks like we have a regular F1 race schedule at WCRC...
3rd Sunday of every month, starting with December 27th 2009
Check site for more details....
http://www.charleslightfoot.com/WCRC_F1.html
Love and Peace...
Last edited by lightfoot; 12-09-2009 at 10:34 AM. Reason: date of event changed from 4th to 3rd Sunday
Old 12-08-2009, 06:11 AM   #855
lemantoi's Avatar
Originally Posted by danny4r View Post
bak kata leman tungging dulu lerrrr.....
jgn guna ayat aku lah...
lemantoi is offline   Reply With Quote
FS: Tamiya F103 mild seven Australia For Sale/Trade 4 08-20-2008 12:19 AM
Tamiya F103 GT izzyracer R/C Items: For Sale/Trade 2 03-01-2007 04:51 PM
Tamiya F103 NIB Jspecrcr R/C Items: For Sale/Trade 7 11-07-2006 02:30 PM
WTB: Tamiya buggy & Tamiya f103 stuff rays_tt Australia Wanted to Buy 2 04-20-2006 07:10 AM
Tamiya F103 or F103 Parts MM-F1 R/C Items: Wanted to Buy 4 04-24-2004 04:14 PM
SEO by vBSEO 3.5.0
