Like Tree1Likes
Old 11-11-2009, 12:16 PM   #826
gtfour93's Avatar
Trader Rating: 22 (100%+)
Originally Posted by sidecarphil1 View Post
HELP
i have been painting my F103 body tonight and i come to remove the overspray cover from the outside AND . . . . . . there isnt one
now i have a M style body that is destroyed i think , is there any thing i can use to remove the paint ??
or is there 100% an overspray cover that i just cant get off ???
cheeRS Phil
It seems that you were excited about painting your new F1 body, that you forgot to read the instructions. You can still save the body, but it will be alot of work to clean, depending on how much overspray that has to be removed. I use TESTORS Enamel Thinner (1148) to clean up overspray. To regain that shine, try using a modeler's rubbing compound or shoe polish, as long as it's safe for lexan. You might want to try a sample of shoe polish on a piece of lexan first. Hope this helps.
www.activrc.com
gtfour93 is offline   Reply With Quote
Old 11-11-2009, 12:28 PM   #827
there was no instructions with the body set , allong with no drivers head or screws for the rear wing , the later is no problem because i am using the TRG item but the head is !!!
sidecarphil1 is offline   Reply With Quote
Old 11-11-2009, 12:31 PM   #828
gtfour93's Avatar
Got it! I had the impression that you had a TAMIYA F103 M Body.
www.activrc.com
Old 11-11-2009, 12:34 PM   #829
i have
Old 11-11-2009, 12:37 PM   #830
gtfour93's Avatar
i have
FYI, those bodies doesn't have any overspray film.
www.activrc.com
Old 11-11-2009, 12:41 PM   #831
yeah i know i was SOOOOOO shocked that there was none GRR
and no head for the driver WTF
i bought the most expensave F103 i could the 15th Anniversary kit and no front body mount !!!
i buy a body and no screws for the rear wing , no head and no instructions !!!
i am pissed with Tamiya now GRR
Old 11-11-2009, 01:02 PM   #832
gtfour93's Avatar
What you ended up buying is just the CLEAR body by itself. You should have bought this instead.
http://www.tamiyausa.com/product/ite...oduct-id=84024
www.activrc.com
Old 11-11-2009, 02:11 PM   #833
cheehtae's Avatar
Trader Rating: 15 (100%+)
is there a way to convert the f103gt to an F1 car? all the help is appreciated.
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 11-11-2009, 04:20 PM   #834
bakaguyjean's Avatar
HELP
cheeRS Phil
Carson in Germany makes a paint stripper,check that out.
My body projects blog http://rcbodyproject.wordpress.com/
bakaguyjean is offline   Reply With Quote
Old 11-12-2009, 06:47 AM   #835
i managed to save the body using soft nail polish remover
i tested on a small part of the nose cone first and it was ok
thanks for the replies guys
i have mailed RCmushroom about my complaints and i hope they will contact Tamiya for me and see if i get a reply from them !!!
just waiting for my Jordan F1 stickers to clear the Dutch customs system in about 6 months
Old 11-16-2009, 01:09 PM   #836
Been busy with the stickers and paint
i think it looks AWSOME
Old 11-16-2009, 04:24 PM   #837
414MPH's Avatar
Yes, but by the time you are done you could buy an F-103 kit with wheels, tires and body for less and end up with two complete cars.
Starting you need the chassis plate due to the way the front wing nests into the plate.
and these parts too:
front suspension
front bearings
front steering knuckles
king pins
left rear hub
right rear diff housing
wheel set
front tires
rear tires
rear body mounts
front body mount
body set including f & r wings
Marty (TAMIYA 414M's, F-1's and Vintage Trans-Am! Is there anything else?)
** Red Dot Motors** , thanks doc....
and I guess the TA-05 IFS-R is pretty good too.....
414MPH is offline   Reply With Quote
Old 11-16-2009, 07:45 PM   #838
badmotor's Avatar
looks fantastic, always loved that Jordan livery
WHY IS THERE BACON IN THE SOAP?!?!?!
badmotor is offline   Reply With Quote
Old 11-25-2009, 08:23 AM   #839
HeliYogi's Avatar
Trader Rating: 16 (100%+)
Default F1 Race Info. Sunday 11/29 at WCRC
Let's see thouse F103
UF1 Format changes for Sunday Nov. 29
We will be running the same Super Qual + 3 mains at WCRC on Sunday with the following changes:
Rubber and foam run together. The story is that this track will hook up with foam as well as rubber. Bring it. Race it. Prove it.
Chassis/Motor rules:
Direct rear wheel drive 1/10 scale open wheel car (F1 style)
540 sized motors silver can, black can, TCS 32 turn, or 21.5BL
SQ
Due to popular demand, qualifier will be open track instead of multiple 2 minute groups. Just put your car down and drive as fast as you can. We will limit the number of drivers on the track at any given time to 5 or less. After 4-5 minutes time will be called and drivers will pull aside for the next 5 drivers. Qualifying order will be randomly determined (but you can swap with anyone who is willing). If we have 15 or more drivers, the qualifying time will be extended beyond 15 minutes. Drivers might have an opportunity to make a second run at a fast lap if we have enough time and open slots.
Three things to think about for the SQ.
1) Time will be limited between the SQ and the first main to recharge batteries or cool you motor
2) Fast qualifier gets an extra point added to his/her score (yes, it does make a difference)
3) Grid order of first main will be based upon fast lap in the SQ
If we have a turnout of 14 or less drivers, we will run one group all together.
If we have 15 or more we will try something different for DNF and DNS drivers from the higher main groups. If you are in the A group and can not make the grid (DNS) or complete 8 laps (DNF) you will have an opportunity to run at the back of the B group. Although you will receive no score for that round, a good run with the B group can place you in the A group for the next round. If you are in the last group and DNF or DNS TL (tough luck).
OTHER THINGS TO CONSIDER:
Doors open at 10
Sign in closes and drivers meeting at 11
SQ at 11:30
Third round HAS to be done before 3:00 for off road, so this will be very fast paced if we end up with two race groups
Track will be open practice between rounds
SoCal UF1 scoring format (ask if you don't know where to find it)
More F-1 RC action? RCTECH Formula-1-RC-Northwest & FB @WhatBrakes
HeliYogi is offline   Reply With Quote
Old 11-25-2009, 12:47 PM   #840
BadSign's Avatar
Loved those cars. Gotta say I do miss Eddie Jordan's antics.
This is the day the Lord has made, I will rejoice and be glad in it- Psalms 118:24
World Champion Turn Marshall
BadSign is offline   Reply With Quote
FS: Tamiya F103 mild seven Australia For Sale/Trade 4 08-19-2008 11:19 PM
Tamiya F103 GT izzyracer R/C Items: For Sale/Trade 2 03-01-2007 03:51 PM
Tamiya F103 NIB Jspecrcr R/C Items: For Sale/Trade 7 11-07-2006 01:30 PM
WTB: Tamiya buggy & Tamiya f103 stuff rays_tt Australia Wanted to Buy 2 04-20-2006 06:10 AM
Tamiya F103 or F103 Parts MM-F1 R/C Items: Wanted to Buy 4 04-24-2004 03:14 PM
