Still searching for the 103 tires and compounds I need. Thanks Cuda for the info!! Found some 38 degree fronts and 30 degree rears in Hong Kong. Ordered a couple of sets to try. Going for the older 53128's for the front-- found some 53129's.
FYI
Tim
Allrighty then---found some wheels and tires at Gyro-- AND two packs of the Orion 4500mah lipos to run with!! These should get me enough run time to practice and qualify in that their running short qualifying sessions. I'm going to try and make the race this weekend--- just gotta hope one of my radios shows up!! AND I get time for working on this thing to clean it up and have it ready to run!!
Hope to CYA out there.
Tim
This Saturday practice and Sunday Racing at the Tamiya track Southern California... Ultimate F1 Series Day Race... Two classes... foam silver can Mabuchi 540 J motor ONLY, no RPM limit.... and rubber tire, 17.5 brushless ONLY...
Three Rounds of racing...
Each round will be a 2 min qualifying period, 5 cars max on the track, your looking for one fist lap to determine your grid order... 8 min race...
We will do this three times... points given to the top 8 finishers... the winner will be determined by points at the end of the day...
There are some high capacity lipos that fit with the pivot ball rear suspension. The Orion 4800's fit and I borrowed a 5000 at the TCS Finals that fit also, but I don't remeber the name on it, but it looked like the same case as the Orions..
Marty (TAMIYA 414M's, F-1's and Vintage Trans-Am! Is there anything else?)
what rollout is everying running on their F103's with foams and using a 540 silver can motor? I have a F109 coming from 3 racing and need to know how to gear it. But i am using 64 pitch gears
TEAM HIGH VELOCITY RACING
www.highvelocityracing.com
MLP Team Driver
NEXUS RACING
MLP Viper F1 Pro, Xray T2 '008 EU & '009 US SPEC, KYOSHO HOR, RC18B
Craig Hammon
F N CUDA CHASSIS BRACES FOR SC10 TRUCKS
Lately only runnin cars and trucks that look like cars and trucks.
SC10, F103, Trans Am 'cuda, M05 Mini, Saleen Mustang, Hyper10 SC 4x4
wow cant believe protoform came out with bodies...the high nose looks great
MLP Team Driver
NEXUS RACING
Chassis plate
Front steer knuckles (aka front spindles)
remove spacers from the link type front end
new king pins
wheels / tires
rear diff parts including right and left side haxle hubs
body set with wings and mounts
