Old 07-03-2009, 02:33 PM   #721
TonyK's Avatar
Rob is ride height adjustment not an option on these cars. Right now I'm having an issue where 1 tire is smaller than the other so when I turn to the side with the shorter tire the front wing is rubbing the ground. When I turn the other direction its fine.
Originally Posted by robk View Post
3 racing makes a front end with camber and caster adjustment.
http://3racing.hk/products.php?products_key=3398
A large part of their history is made up of blood and battle. This is not something to shrink away from as a fancier of the breed. Their history should be embraced, understood, and once we have a full understanding, we can control the future.
TonyK is offline   Reply With Quote
Old 07-03-2009, 04:15 PM   #722
robk's Avatar
Trader Rating: 22 (100%+)
Tony you have to rotate the tires side to side so they wear evenly. Usually the left front is the small tire.
You can also shave the bottoms of the steering knuckles slightly and get 1 or 2mm smaller on the tire. You have to use a spacer to get the spring back to the right preload, but this will help too.
I'm gonna try to be at the track Sunday, come by and i'll look at your ride.
Old 07-04-2009, 03:59 PM   #723
TonyK's Avatar
Thanks Rob, I don't know if I am able to race tomorrow but I might stop by to have you check it out. I made the trek up north today to pick up some front tires and I broke 1 of the steering knuckles. The car is back togeher.
Tony you have to rotate the rides side to side so they wear evenly. Usually the left front is the small tire.
Old 07-05-2009, 09:17 AM   #724
Trader Rating: 23 (100%+)
I am looking to purchase a F1 car and need some help from you guys. How does this kit compare to the F104? Is this car at a big disadvantage? Parts still available?
bmcallister is offline   Reply With Quote
Old 07-05-2009, 10:16 AM   #725
hey guys,
i just dug out my F103LM, yea its old but i was wondering what size tires i can go with in the back?? and if i could you 1/10 jaco wide foams in the rear?? there 49MM wide(the stocks are 37 mm i think) but the same Dia. could this work?? if not any ideas?
Hpi R40 Hara w/ .12JLR
Hpi R40-rolling frame
Tamyia F103 LM -Ole school
soon a 1/8th on road
Duratrax Maximum ST Pro
Hpimichael is offline   Reply With Quote
Old 07-05-2009, 02:14 PM   #726
hey guys , i really do need some help finding new tires for my F103, can any one point me in the right direction as to where i can get them from ?? foams or rubber...
Old 07-05-2009, 05:32 PM   #727
http://d-drivesportsenglish.com/
Old 07-05-2009, 08:31 PM   #728
wow thanks , thats a steller site and cheap tires too... awsome, thanks again, ima order and ton of stuff tonight ...hahahha
Old 07-30-2009, 07:52 PM   #729
TonyK's Avatar
I'm having problems with my F103. I am trying to change the motor mount to a ride height adjusting mount. I have it together but the axle seems to long for the rear. I have some pics I am going to post and hopes it helps. I am just wondering what I need to get it right.
Old 07-30-2009, 09:01 PM   #730
robk's Avatar
Tony there should be a sleeve like spacer for the left side of the car. That will give you the correct spacing.
Spacer 8x16mm it is part ma24 in the anniversary kit, ma26 in the f103rm kit.
Tamiya also lists this part: RC 8x16mm Spacer: 58431 Item #3450157
Old 07-30-2009, 10:47 PM   #731
downtempo's Avatar
Send a message via AIM to downtempo
Friction plate/pads looks to be adjusted super tight, is there a track surface that having it this locked down would be helpful? -
downtempo is offline   Reply With Quote
Old 08-01-2009, 06:06 PM   #732
lightfoot's Avatar
Default B195
So, I was under the impression that high nose F1 cars didn't handle as well as low nose bodies... but I have to tell you... I took a very high nose Tamiya Benetton Renault B195 out on the track today and it handled great... and this is with rubber tires and 17.5... I've used this same chassis setup with a low nose car and got very similar results... I would think that you would notice the biggest difference on a high speed sweeper... both bodies I had to let off the gas for a 1/2 sec entering the turn and slowly back on... very stable... So is the high nose thing just BS, or is the B195 just a good RC shape ?
Love and Peace...
lightfoot is offline   Reply With Quote
Old 08-03-2009, 09:18 PM   #733
TonyK's Avatar
Thanks Rob for the part numbers I guess I have some ordering to do.
Downtempo I am running on carpet. I find it helps a little with traction.
Old 08-05-2009, 11:57 PM   #734
RonF's Avatar
Originally Posted by 414MPH View Post
John,
I currently have 12 NIB Tamiya F-103 body sets in stock and tons of spare parts.
PM if you need something. The wife has placed her foot squarely on the floor and would like to see the overall inventory reduced....lol
If Momma ain't, ain't nobody happy!
What bodies and wings etc, do you have and are they still available? Also, any diffusers?
RonF is offline   Reply With Quote
Old 08-06-2009, 10:31 PM   #735
414MPH's Avatar
Vintage Tamiya F-1 Body sets in stock:
WILLIAMS FW 11B HONDA
TYRRELL 019 FORD
LOTUS 102B JUDD
SAUBER C12
FERRARI 412T1
WILLIAMS RENAULT FW18
PIAA NAKAJIMA REYNARD 97D
F-1 Body Set, type -M (McLearen MP4)
All are NIB and have correct wings, livery decals and driver helmet.
Asorted F-1 wings (mostly fronts) and F103L wings F&R.
I have a NIP Tamiay Diffusser also.
PM for pricing, please include your location.
Marty (TAMIYA 414M's, F-1's and Vintage Trans-Am! Is there anything else?)
** Red Dot Motors** , thanks doc....
and I guess the TA-05 IFS-R is pretty good too.....
414MPH is offline   Reply With Quote
FS: Tamiya F103 mild seven Australia For Sale/Trade 4 08-20-2008 12:19 AM
Tamiya F103 GT izzyracer R/C Items: For Sale/Trade 2 03-01-2007 04:51 PM
Tamiya F103 NIB Jspecrcr R/C Items: For Sale/Trade 7 11-07-2006 02:30 PM
WTB: Tamiya buggy & Tamiya f103 stuff rays_tt Australia Wanted to Buy 2 04-20-2006 07:10 AM
Tamiya F103 or F103 Parts MM-F1 R/C Items: Wanted to Buy 4 04-24-2004 04:14 PM
SEO by vBSEO 3.5.0
