Old 10-15-2008, 05:51 PM   #631
rccardr's Avatar
Pete- Yes that spur is 64 pitch compatible. Start with a 23 and depending on how tight the track is you may be able to go up to a 28 with newish rear tires (tall ones). Biggest issue will be motor temp. If it comes off the track higher than 180 at the comm, back it off a tooth or two.
I've never lost.
I've just been a little bit behind when time ran out...
RED DOT MOTORS- Fastest Titan 12T and silver can 540 motors in the known galaxy!
rccardr is offline   Reply With Quote
Old 10-15-2008, 06:35 PM   #632
subaru73's Avatar
Trader Rating: 41 (100%+)
Default f103
Did you see what tamiya has coming out
http://www.tamiyausa.com/product/ite...oduct-id=84056
Tamiya Ta07 Tamiya evo5 ms,Tamiya Ta05r Tamiya FF04 rm01 Tamiya Ff03R
Futaba 4Px radio lrp speed control
Cfx paint works Fantom Racing apex Rc tq hobbies acer racing Hebki design works
subaru73 is offline   Reply With Quote
Old 10-15-2008, 08:32 PM   #633
reenmachine's Avatar
Trader Rating: 26 (100%+)
Thanks Doc, that's exactly what I needed. I'm going to order 23, 25, and 27 for starters. There's one regular race weekend before the big race I'm preparing for so I'll get to try everything out, check temps, and adjust as needed.
Any other setup tips for this thing? I'm a bit out of my element with a pan chassis. I have the front spring kit on the way. I'm also going to try out the TRG rubber tires just for fun. Can I replace the friction damper with a regular plastic CVA shock that used to be on my TA05 before I upgraded? What spring/piston/oil?
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 10-16-2008, 03:15 AM   #634
RC MARKET's Avatar
New items
Tamiya F103 Forum-cr-cf01.jpg   Tamiya F103 Forum-cr-cf0108a.jpg   Tamiya F103 Forum-trg-5000.jpg   Tamiya F103 Forum-ze-z5002b.jpg   Tamiya F103 Forum-ze-z5002w.jpg
RC MARKET is offline   Reply With Quote
Old 10-16-2008, 04:20 AM   #635
rccardr's Avatar
The black springs may make it easier to drive, or at least less reactive, depending on the surface. You can also dribble a few drops of heavy shock oil (100+) on the kingpins to slow down the action if it's bouncy up front. Yes, you can use the shock off of your TA05, start with the yellow spring and preload so the t-bar is flat when the car is fullyloaded, viewed from the side. Oil somewhere in the middle range, 2-hole piston. You may find the biggest tuning changes come from SLIGHTLY altering the front and rear t-bar mounting screws (please note caps above). A little in or a little out can make a big difference.
I've never lost.
Old 11-03-2008, 12:17 PM   #636
lightfoot's Avatar
Hey guys... If your in the LA area I just found a big race next Sunday November 9th that will be having a F1 class... They will be handing out motors... silver cans I believe... So far we have 8 cars ! I just received my new/used F201 a few days ago and I can't wait to race it... It's called the Big Fat Turkey Race... It will be in Camarillo CA, Freedom Park... I hope Steve wont get pissed but if you have any questions please e-mail him at beach_lover91320@yahoo.com , he's in charge of the thing... It would be great to have F1 A and B main
lightfoot is offline   Reply With Quote
Old 11-03-2008, 12:21 PM   #637
All the info can be found on the last few pages of this thread:
http://www.rctech.net/forum/racing-f...unners-74.html
The handout motor for the F1 class is a pro-built 27T stock motor, and it is fast! Gear accordingly.
Pete Waydo
Old 11-03-2008, 09:18 PM   #638
MaxSp97's Avatar
This is from Steve B.
Just for clarification..... At the BFTR II, Mini Cooper, F1 and Vintage classes will be running stock silver can motors provided by the Roadrunners.
Cal,
MaxSp97 is offline   Reply With Quote
Old 11-03-2008, 10:36 PM   #639
Cal,
Yep, Steve got to me in another thread with that info. News to me (regarding F1), but he says Giti knows. Would have been nice to know before spending all that time figuring out the pink motor gearing and all. I take it by the you didn't know either...
Pete Waydo
Old 01-05-2009, 01:35 PM   #640
Giorgio's Avatar
I'm after this body.
Can someone help me in this search?
Thanka a lot!!!
Giorgio is offline   Reply With Quote
Old 01-26-2009, 06:20 PM   #641
SerpentCT4S's Avatar
Trader Rating: 94 (96%+)
Send a message via AIM to SerpentCT4S
I just built my F103GT Advan Courage. I have a few questions.
1. Is the kit supposed to come with a foam bumper?
2. How do I mount the Courage body? The rear body post setup is so weird. What posts do I use for the front?
Pictures would be great.
SerpentCT4S is offline   Reply With Quote
Old 01-28-2009, 10:43 PM   #642
lightfoot's Avatar
The kit does not come with a foam bumper... as far as I can remember it would not fit with the Courage body... Tamiya does make one I believe for other bodies... I'm looking at my chassis and the rear posts are mounted to the rear upper deck... hope this helps...
Old 02-15-2009, 08:58 PM   #643
lightfoot's Avatar
Default F1 series
For anyone in the Los Angeles area interested... BCR will be having a F1 series starting Saturday Feb 21st
http://www.charleslightfoot.com/BCR/f1.html
Old 02-15-2009, 10:19 PM   #644
mikel33's Avatar
Trader Rating: 2 (75%+)
Anyone in the Chicago / NE Illinois / SE Wisconsin area we're racing F1 on Sunday's @ The Track at Harbor Hobbies in Winthrop Harbor IL. The more the merrier.
Here's a link to the store, and there's an RC tech thread as well.
http://www.harbor-hobby.net
If you have any questions you can PM me or call Eric (track owner) at the store.
Michael Larson.
Village Idiot Racing
mikel33 is offline   Reply With Quote
Old 02-16-2009, 05:33 AM   #645
there is a paper manual separately from the big one, all you need to mount the body is included... the foam bumper is not for courage...you have to built one yourself or run without it /as i did/
TroubleRK is offline   Reply With Quote
FS: Tamiya F103 mild seven Australia For Sale/Trade 4 08-19-2008 11:19 PM
Tamiya F103 GT izzyracer R/C Items: For Sale/Trade 2 03-01-2007 03:51 PM
Tamiya F103 NIB Jspecrcr R/C Items: For Sale/Trade 7 11-07-2006 01:30 PM
WTB: Tamiya buggy & Tamiya f103 stuff rays_tt Australia Wanted to Buy 2 04-20-2006 06:10 AM
Tamiya F103 or F103 Parts MM-F1 R/C Items: Wanted to Buy 4 04-24-2004 03:14 PM
Currently Active Users Viewing This Thread: 7 (0 members and 7 guests)
