Tamiya F103 Forum
#619
Well if you have the older style F103 you can convert the axles to the F103GT axles which will let you use any rim that uses a standard hex. This would allow you to use TC rims and tires and also rims and tires for the F201.
1/10 pan car tires can work but you have to do some converting...you'll have to change out the rear axle to a standard sized axle and drill out the bearing holders to accept standard bearings instead of metric. For the front tires people who did the conversion would often still use a metric bearing close to the same size as the standard but put a piece of masking tape over the hole in the wheel before pressing the bearing in. That would take up any slop between the bearing and the wheel.
#621
If anyone is looking for an F103 car (or three) to refurbish to race or for a shelf queen, I;ve got a few for sale, plus a clear body, plus tires. Here's the link:
http://www.rctech.net/forum/showthread.php?t=208324
#623
Wow, great photos, nice job.
#625
Great photos!
#627
can someone tell me the difference between the f103 kits out there?
i'm looking to get into f1 but i don't know what's the best one.
or is it just a difference in the shells?
i know the f103r is coming out soon might hold out for that
#628
The L body kit coming out is also a low nose early 90s shell (lotus 107B) with a larger front wing than the T body and a rear wing sized between the M & T bodies.
The R looks to be a full hop-up kit w/o body. Given that only a few hop-ups really improve the car I would suggesting getting one of the std kits along with select upgrades.
For hop-up I would recommend the trf shock, aluminum motor mount, spur gear set, front spring set and either the graphite chassis or a long upper deck. The turnbuckle set is a nice convince but not necessary.
Mark
#629
thankyou thankyou
just the reply i wanted
#630
I need some gearing help and I'm not having any luck over on the F103RM thread...
I have an F103RM that I'm trying to set up for a spec race. We're going to run handout 27T 30° (high revving) motors with 6 cells on an outdoor asphalt track with decent grip.
I'm hoping to run this 93t spur:
http://www.tamiyausa.com/product/ite...oduct-id=53104
I believe it is compatible with standard 64p pinions. (is this correct?)
Any suggestions for pinion size?
