Old 12-02-2001, 03:57 PM   #481
stormperson's Avatar
Send a message via AIM to stormperson
i am runnig the old front end (solid arm's and the kingpin moves up and down) as for the rear end, i think its the old style, i cant adjust tweak, which isnt a good thing.
i want to get the tweak adjustable rear end plate thingie, alum motor mount, medium front tires, new style front end, and also a body to replicate the fw23 (not all items for performance though)
also anyone know which wing and body set would be the best for this?
stormperson is offline   Reply With Quote
Old 12-02-2001, 10:32 PM   #482
psycho's Avatar
stormperson
I find that it is really not necessary to adjust tweak on the F103. If you're running on asphalt, you might consider tightening down the two screws that make the pivot for the t-plate. Don't crank them down all the way, but enough to limit the t-plate's motion. I find that gives better rear traction in sweepers and it has the same effect as it you were to limit this motion with tweak screws on the pivot ball rearend.
As far as a wing set goes, I don't know of anyone that makes one in that color blue. The closest I've seen is the wing for a Kyosho Impress, but it's a lot lighter blue, the rear wing is the "cheater" wing, so you'll have to chop the top wing off to make it look right, and I have no idea where you'll even find a set. I think you'll have to take a wing set from something readily available and paint it. The current F-Type or M-Type wings should be pretty close in appearance.
psycho is offline   Reply With Quote
Old 12-03-2001, 04:52 AM   #483
ya, i figure i will probably end up having to paint the wing.
since i am running on carpet though, how much should i tighten it down, and the car is very tweaked, everyone who drove it mentioned that.
Old 12-03-2001, 07:52 AM   #484
Fangio's Avatar
Depends if it is lose than losen the back screw if it is tight do the opposite. the front screw I never change i have pretty tight but not fully locked down.
Fangio is offline   Reply With Quote
Old 12-03-2001, 11:12 AM   #485
psycho's Avatar
stormperson
What chassis configuration are you running? If you have the standard F103 FRP chassis plate, you should add the FRP, long, upper deck. It may be that the chassis is flexing and causing ill handling. If you have the stock chassis, the FRP upper deck (part# 53186) is a must have hop up. Also, check the the front kingpins are moving freely. It's possible that one or both is not and giving the appearance of tweak.
Old 12-03-2001, 01:33 PM   #486
i got it used, however it appears to have an upper deck and lower deck, and all of the flat plastic (t bar, top of the battery plate, and friction plate) made out of the frp stuff. i also just realized that i probably have a graphite axle seeing how its not metal, but dark grey.
Old 12-03-2001, 07:11 PM   #487
TRF-Powered's Avatar
Got a question for you all, if I want convert a F103LM TRF fit F1 body? Just a flat carbon chassis will do? or do i need to get different upper deck too???
TRF-Powered is offline   Reply With Quote
Old 12-03-2001, 09:12 PM   #488
Dragon Slayer's Avatar
Send a message via Yahoo to Dragon Slayer
From what i have seen, the people that use the Carbon chassis do not use the upper deck as the Carbon chassis is stiff enough!
Dragon Slayer is offline   Reply With Quote
Old 12-04-2001, 11:00 AM   #489
psycho's Avatar
If you run the Hard Carbon-Graphite chassis (part#53168) you do not need the FRP upper deck. It is plenty stiff without it. That's what I run on my TRF car. It's around $100, though If you can't find it, have Les order it for you. www.mdiracing.com Just send him an email.
Old 12-04-2001, 11:49 AM   #490
What I mean by upper deck... is that thing over the battery holder. I thought F1 has different "upper deck of battery".
Old 12-04-2001, 01:09 PM   #491
psycho's Avatar
OK, I'm with you. There are two top plate configurations. The graphite top plate that comes with the TRF car doesn't need the aluminum bar for the shock to attach to, since it's built in. The FRP upper decks require this. I guess it's because they flex too much. When I converted my TRF car from the LM type chassis to the F type chassis, I only replaced the chassis. I did not change the upper deck. I converted it to the side antenna mount, but that is not a requirement.
This is what the TRF car comes with
This is what the top deck that the F103RS/RX come with looks like. This is actually the CF version of the stock upper deck.
The long FRP upper deck looks like this.
The blue part in this picture is what you need to mount the shock on the long and short FRP decks and the CF version of the short upper deck. Of course, the stock piece is silver.
I hope that clears it up. I'll take some pictures of my car when I get home so you can see how mine is set up.
Old 12-04-2001, 01:23 PM   #492
TFR
TFR's Avatar
cool...i want to see it too...yeah...
TFR is offline   Reply With Quote
Old 12-04-2001, 02:04 PM   #493
ya, mine has that piece, and the long deck that goes to the front and mounts with the servo.
i cant seem to find the tweak adjusting rear pod, is there any way i can adjust tweak currently? also i have l30 oval car, that i never ran, can i steal that whole rear assembly?
Old 12-04-2001, 02:52 PM   #494
psycho's Avatar
stormperson
That bottom picture is the pivot ball rear end set. The pivot assembly has the option to add tweak screws, but does not include them. In the TRF instruction, it tells you how to do it. I can probably scan it and post it so you can see how it works.
BTW, those pictures are on Tamiya's Dutch site. www.tamiya.nl
Old 12-04-2001, 05:03 PM   #495
sorry, i didnt specify, i have that blue annodized shock mount. thus would that mean that i have the pivot rear end? thus allowing me to adjust tweak? how does it do it, i know my speedmerchant rev. 3 has screws, however how does one adjust it on the tamiya?
FS: Tamiya F103 mild seven Australia For Sale/Trade 4 08-20-2008 12:19 AM
Tamiya F103 GT izzyracer R/C Items: For Sale/Trade 2 03-01-2007 04:51 PM
Tamiya F103 NIB Jspecrcr R/C Items: For Sale/Trade 7 11-07-2006 02:30 PM
WTB: Tamiya buggy & Tamiya f103 stuff rays_tt Australia Wanted to Buy 2 04-20-2006 07:10 AM
Tamiya F103 or F103 Parts MM-F1 R/C Items: Wanted to Buy 4 04-24-2004 04:14 PM
SEO by vBSEO 3.5.0
