Old 10-25-2001, 07:20 PM   #361
any one is welcome to send photos of their cars for the photo gallery....as you notice we have them from all over the world.
TheNige is offline   Reply With Quote
Old 10-25-2001, 07:38 PM   #362
TFR
TFR's Avatar
OK, i will submit the picture with in this week....
Can i include a picture of the TS020 body also?
TFR is offline   Reply With Quote
Old 10-25-2001, 07:48 PM   #363
Have you looked at the photo gallery ever? There are plenty of GT1 cars there.....as long as the base is an F1 chassis...
Old 10-25-2001, 08:05 PM   #364
TFR
TFR's Avatar
Oh, no i havent been there before...
I just read about the news and articles...
Old 10-26-2001, 03:38 PM   #365
Regional Moderator
Darkseid's Avatar
HELP!!! I just ran the car and it was running well and everything was good, until......I decided to try my rubber tires so I changed the wheels on my F103 and now the damn diff won't act right.
I changed the wheels, moved the trust bearing assembly to the new wheel, and put it back together. Now the diff is slipping when I set the diff action at about medium. I'm not sure if I got the concave(cone)washers facing the wrong direction or if I did something wrong to the diff balls and rings.
SO I got two question that I think might be the problem:
1. Which direction should those three concave washers be facing. When I took it apart they were all facing the same way stacked ontop of each other. Is this how their supposed to be. If it is, which way should the dish be facing. In toward the wheel, or out toward the thrust bearing?
2. Also, are the diff rings and ball supposed to be greased or not. I thought I saw a small amount of grease on there when I took it apart, so I added some. Was this a bad thing?
Hit me with some answers as soon as possible guys. Remember this is my first Tamiya F1, so this whole trust bearing in the wheel thing is new to me.
Thanks for any help you can give.
TLR 22...Tamiya F104...
Old 10-26-2001, 03:51 PM   #366
the cone of the concave washers should be pointed towards eachother....this is what give the whole diff set-up tension so you can adjust it.......
Old 10-26-2001, 03:51 PM   #367
Regional Moderator
Darkseid's Avatar
Nevermind guys, I got it figured out! I just kept moving the cone washers around until everything was working normal again.
I still want to know about the diff rings and balls though. Do they need grease like normal diffs or what?
Old 10-26-2001, 03:52 PM   #368
Regional Moderator
Darkseid's Avatar
Thanks Nige, I got it figured out.
What about the grease?
Old 10-26-2001, 03:55 PM   #369
i always run a little.....just to keep it smooth....don't put too much or it will all fly out anyways at high speed.....also will atract a lot of dust if raced out side
Old 10-26-2001, 06:25 PM   #370
TFR
TFR's Avatar
I don't know if this is a tip or trick....but here it goes...
When I run carpet with my F103 LeMan style bodies, And when the car comes out of the corner it usually spins out...[still can't get the proper acceleration for both wheel at the same time coming out of the corner]
So what i tryed was to just take the 'balls' out, so I got the rear end as one unit [lock up diff]
Then when I hit the track, of course. No more spinning out.
But do you guys think during cornering, it will slow it down? since the inside wheel is the same as the outside wheel....?
Maybe you guys think the spin out part will be even worse...but it is actually better...
Old 10-26-2001, 06:32 PM   #371
that's interesting...have to try it. I just loosen my up and be sure to feather the throttle when coming out of the corner...
Old 10-27-2001, 12:36 PM   #372
Regional Moderator
Darkseid's Avatar
Thats pretty much a solid axle set up. Sounds like something they would run in 1/8 on-road. I say if it works for you keep it.
Old 10-28-2001, 06:52 PM   #373
Odie's Avatar
Default Benetton Decals
Does anyone know where I might be able to find some Benetton decals? I don't really care what year they are from, I just would like to do a colorful paint job on my new body.
Thanks,
Jody
Odie is offline   Reply With Quote
Old 10-29-2001, 08:10 AM   #374
Regional Moderator
Darkseid's Avatar
Odie: I don't know, but you are aware that the Benneton team is no more don't you. Now there is only Renault.
Old 10-29-2001, 09:05 AM   #375
psycho's Avatar
Default Re: Benetton Decals
Odie
Check Ebay. I have seen lot's of uncommon decal sheets there. Just search for "F1" or something like that and look through the million or so results that come back. You could always make them yourself if you have a color printer.
psycho is offline   Reply With Quote
FS: Tamiya F103 mild seven Australia For Sale/Trade 4 08-19-2008 11:19 PM
Tamiya F103 GT izzyracer R/C Items: For Sale/Trade 2 03-01-2007 03:51 PM
Tamiya F103 NIB Jspecrcr R/C Items: For Sale/Trade 7 11-07-2006 01:30 PM
WTB: Tamiya buggy & Tamiya f103 stuff rays_tt Australia Wanted to Buy 2 04-20-2006 06:10 AM
Tamiya F103 or F103 Parts MM-F1 R/C Items: Wanted to Buy 4 04-24-2004 03:14 PM
