Like Tree1Likes
Old 10-09-2001, 04:06 PM   #226
TFR
TFR's Avatar
I found out that Type A tires work pretty good in a Carpet Track...
TFR is offline   Reply With Quote
Old 10-09-2001, 04:22 PM   #227
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
What I like about rubber tires is that they do not wear like Foams, and the tire diameter do not change that much over the tires life. Overall the Foams do tend to work better though..
Our local track does not allow the foams, so it is a mute point for me.
Still waiting on my Cross....
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 10-09-2001, 04:24 PM   #228
Odie's Avatar
I have also heard good things about the A-type tire. My track may consider running a spec tire in order to keep it even, and the A tire is the front-runner.
BTW, I put both Kyosho Indy cars on ebay...opening bid $75 (a steal if ya ask me).
Lata on...
Jody
Odie is offline   Reply With Quote
Old 10-09-2001, 05:05 PM   #229
We use the B tires at our track. We allow any tires except Capped Foams in our race series.
TheNige is offline   Reply With Quote
Old 10-09-2001, 06:50 PM   #230
TFR
TFR's Avatar
Can anybody help me on a set up that is use for indoor carpet??
like what weight of springs, what hop ups i should need....what pinion and spur i should get(it kind of a tight track.)
any help is grealy appreciate.
Old 10-09-2001, 06:52 PM   #231
jcr
i say get ride of the 90wt oil!!!!
jcr is offline   Reply With Quote
Old 10-09-2001, 06:56 PM   #232
AE_Racer's Avatar
Send a message via AIM to AE_Racer
how much should I pay for a TRF used but in good condition?
AE_Racer is offline   Reply With Quote
Old 10-09-2001, 08:45 PM   #233
psycho's Avatar
TFR
I don't race on carpet, but consider this. You'll get a lot more traction on carpet than on asphalt. So, it is likely that you will need to make changes to reduce traction to avoid traction rolls and oversteer. The things that you can change to reduce traction are 1) use harder tires 2) use stiffer springs 3) if you use stiffer springs, you will likely need more dampening. Dunno if that helps you much, but hopefully it points you in the right direction. As far as gearing goes, I would start in the mid 5:1 (like 5.45:1) gear ratios and reduce your pinion one tooth at a time until you get the balance of acceleration and top end you are looking for. If the track is pretty tight, you'll probably want to run somewhere around 6.00:1. Good luck!
AE_Racer
I paid $175 for a brand new F103TRF a few months ago. Tamiya had a closeout special on them a while back. Obviously, it depends on what it comes with, but new, it came with a set of Type-A rubber tires, a black can Tamiya tuned 540 motor and no body. It has every hop-up already installed, so there really isn't much you could add to it. Figure that a Tamiya GTP body will run you ~$40 and the tires are ~$15 per front and ~$17 per rear set and a set of wheels cost ~$14. I hope that helps. It's good to see more people getting interested in these cool cars!
psycho is offline   Reply With Quote
Old 10-10-2001, 07:48 AM   #234
rc-zombies's Avatar
Carpet racers... try the Ribbed tires, type A from Ride along with the special foam inserts. They work great on carpet.
Old 10-10-2001, 11:21 AM   #235
Regional Moderator
Darkseid's Avatar
psycho: thanks for the answer about converting to regular gears. I'll do that as soon as I get the car. I used to run an old Kyosho F1 back in the day, and it used standard 48pitch gears so things were simple with it.
TLR 22...Tamiya F104...
Old 10-10-2001, 02:01 PM   #236
TFR
TFR's Avatar
Psycho, ok thanks i will try those set up...
Old 10-10-2001, 02:03 PM   #237
TFR
TFR's Avatar
oh ya, one more thing psycho.
isn't 5 something ratio is a bit high?
but this will help me with acceleration right?
so is like i will get the 100T and like 18, 19, or 20 Pinion so try it out?
Old 10-10-2001, 02:48 PM   #238
psycho's Avatar
TFR
It seems high, but you get the best performance out of a stock motor when you use higher gear ratios. I use either P2K Pro or Reedy MVP motors in my cars and they are much faster running in the 5.45:1 to 6.00:1 range than they are with 4.xx:1 range. I suppose, if you were going in a straight line, eventually, the lower ratio would make the car faster, but you generally need more acceleration than top speed on a road course. Your 18/100 combo is 5.56:1. Actually, you should download Easy-RC software. There are some useful tools on it like the gear ratio tool. www.easy-rc.com
Old 10-10-2001, 03:03 PM   #239
TFR
TFR's Avatar
Oh, ok thanx...
oh, you are using a P2K, that must be very fast...
i m still using 540RS sport tune because its a TCS race, so i dont know about the ratio just yet....
Old 10-10-2001, 04:03 PM   #240
psycho's Avatar
TFR
I race with a couple guys that are running the black can motor and it seems as though the same principles apply to the 540 as they do to stock motor like the P2K. They're not quite as fast, but they aren't slow either. You're going to have to use Tamiya gears in TCS, so don't change to 64 pitch. I would run as high a gear ratio as you can make with Tamiya gears, but have bigger pinions on hand in case you need more top end. Running a higher gear ratio also helps you in the runtime dept. too.
FS: Tamiya F103 mild seven Australia For Sale/Trade 4 08-19-2008 11:19 PM
Tamiya F103 GT izzyracer R/C Items: For Sale/Trade 2 03-01-2007 03:51 PM
Tamiya F103 NIB Jspecrcr R/C Items: For Sale/Trade 7 11-07-2006 01:30 PM
WTB: Tamiya buggy & Tamiya f103 stuff rays_tt Australia Wanted to Buy 2 04-20-2006 06:10 AM
Tamiya F103 or F103 Parts MM-F1 R/C Items: Wanted to Buy 4 04-24-2004 03:14 PM
