Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 10-04-2001, 04:06 PM   #211
psycho's Avatar
Odie
How much? PM me.
psycho is offline   Reply With Quote
Old 10-04-2001, 04:30 PM   #212
Odie's Avatar
you have mail!
Odie is offline   Reply With Quote
Old 10-04-2001, 04:59 PM   #213
Regional Moderator
Darkseid's Avatar
Well if you all recall, the laid down horizontal config. is how all the F1 chassis started out. But, then they decided that sacrificing center of gravity was worth it to get equal steering in both direction. Personally, I think the vertical is better, but thats just me.
Hey guys I was about to get a Tamiya F1 and I had a question. My question is what pitch gears do they use on the F1 cars. Do the use regular 48 pitch or what?
Tamiya M05pro - Tamiya TA05 IFS R - Tamiya TB-03 - TRR(Team Ruining Racing) - Futaba 4PK - Core Creations - Yu-Gi-OH! TCG - WOW player - iMac - iPhone 3G
Old 10-04-2001, 05:42 PM   #214
jcr
well the stock Tamiya gears uses Tamiya 0.6 module which is almost like 48-pitch but a little off.
jcr is offline   Reply With Quote
Old 10-04-2001, 05:58 PM   #215
Moderator
TimPotter's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to TimPotter
I just got the Kimbough conversion to 48 pitch for my 103.... best couple of bucks I have spent for the car... Thanks Psycho
Clean Title & Escrow |p3|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|
TimPotter is offline   Reply With Quote
Old 10-05-2001, 12:43 PM   #216
It's great to see so many people here interested in F1 racing. Check out or site for some more F1 information. http://www.formula1-rc.com
You guys that are talking about the F104 in the Dutch forums. Can you give us the link to an official site that states the F104 will be used next year?
TheNige is offline   Reply With Quote
Old 10-05-2001, 01:41 PM   #217
TFR
TFR's Avatar
Wow ....that site is awsome ....
so much valuable information...to learn from...
nice job...
TFR is offline   Reply With Quote
Old 10-05-2001, 01:44 PM   #218
Regional Moderator
Darkseid's Avatar
So how does Tamiya sell the pinions to go with there standard gears. I've never seen them.
Also, how would I convert the standard gears so that I could use regular 48pitch or 64 pitch pinions.
Old 10-05-2001, 02:02 PM   #219
jcr
Tamiya makes and sell their own pinions a little costly compare to Robinson gears but they have it
Old 10-05-2001, 02:27 PM   #220
psycho's Avatar
Darkside
What you have to do is replace the spurgear + ball bearings and the pinion gear. Kimbrough makes a 75T 48 pitch spurgear specifically made for direct drive cars. They are the same gears that ship with many electric sedans (like the TC3,) but the hole in the middle is larger for a bearing to fit into. If you switch the spur to 48 pitch, you can use any brand of 48 pitch pinions. It's a good way to go because you can get gear ratios in the 5:1 to 6:1 range very easily.
Old 10-05-2001, 02:36 PM   #221
we all run 64 pitch Kimbrough and Robinson gears here....even on our dirty asphalt.
Old 10-06-2001, 04:15 AM   #222
Default Rubber or foam tires
I run a F103 RS whit foam tires from Tamiya. I also have the Type A rubber tires from Tamiya, but i dont like them, ther are now inserts for these tires and i think the are to soft. A shop here in holland sell Ride tires for the F103. I like foam tires very much but rubber tires are very realistic.
Can you help me
rimaracing is offline   Reply With Quote
Old 10-06-2001, 04:25 AM   #223
Hey guys, HPI makes some 64 pitch gears with a bearing adapter. It comes with diff balls and costs about five bucks. You than can use thee adapter on any gear. HPI part #76694 is a 64p 94 tooth that works well on 103 and lm. JEFF
JCTC3 is offline   Reply With Quote
Old 10-06-2001, 09:35 AM   #224
psycho's Avatar
Default Re: Rubber or foam tires
rimaracing
I prefer foams. I run soft in the rear and medium up front. If I'm getting push, I'll switch to soft up front. I don't like the rubber tires.
Old 10-09-2001, 03:39 PM   #225
Fangio's Avatar
the rubber tiers in my oppinion are a better tire, but it all depends on what your car is set up for. there is certain parts that work with foam and certain parts that work better with rubber.
rimaracing you said the A's were to soft try a type b tire the bs are ment for warm weather the As are ment for colder weather. But like i said before a car with foam parts on will not work at all with rubber tires.
Fangio is offline   Reply With Quote
Forum Jump
FS: Tamiya F103 mild seven Australia For Sale/Trade 4 08-19-2008 11:19 PM
Tamiya F103 GT izzyracer R/C Items: For Sale/Trade 2 03-01-2007 03:51 PM
Tamiya F103 NIB Jspecrcr R/C Items: For Sale/Trade 7 11-07-2006 01:30 PM
WTB: Tamiya buggy & Tamiya f103 stuff rays_tt Australia Wanted to Buy 2 04-20-2006 06:10 AM
Tamiya F103 or F103 Parts MM-F1 R/C Items: Wanted to Buy 4 04-24-2004 03:14 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
