Like Tree6Likes
Old 08-15-2017, 09:21 PM   #2221
1/8 IC Fan's Avatar
Trader Rating: 46 (98%+)
Originally Posted by SpeedySST View Post
Stumbled on this thread but did not see any info on grease to use on the friction plates. Any info? Thanks. Im reviving an old friend.
Go to Lowes or Home Depot and get plumbers lube. its a silicone paste (clear) just like diff "grease" also you can get a teflon tape that is sticky in one side and slick on the other, Buds RC used to have it in the 80s-90s and put a piece on the bottom and the top of the FRP plates that the friction discs slide on / through. Trim the edges, and ut will make it smoother.
Lastely, Tamiya had Teflon (white) friction discs as an option. 53149
also the ball type rear mount will take out some tbar flex if you need it. Also you dont have to worry about tracking issues with the stock setup, where the screws holding the T-bar to the main chassis can elongate and wear the tbar holes out over time.
https://www.tamiyausa.com/product/it...oduct-id=53273
-if you can't get ahold of me I am probably working, and that's out in the ocean. So please have patience when trying to correspond. - Thank you.
-> Harvey happend, now we can get back up on our feet and carry on.
1/8 IC Fan is offline   Reply With Quote
Old 08-16-2017, 03:07 AM   #2222
SpeedySST's Avatar
Its getting to the point where it would cost less to buy a new car instead of the refurb!
Team Durango DETC410 / SpeedPassion / Fantom Racing / Aston Martin Racing
SpeedySST is offline   Reply With Quote
Old 08-16-2017, 11:31 AM   #2223
loosewheel's Avatar
Will that ball mount rear suspension kit work on the 104 car?
Jody
Greetings from sunny Northern California
Going fast and breaking plastic since 1998.
RELIC RACING
loosewheel is offline   Reply With Quote
Old 08-16-2017, 10:32 PM   #2224
1/8 IC Fan's Avatar
No it wont
Old 08-17-2017, 12:19 PM   #2225
loosewheel's Avatar
Default Wheels for rubber tires
What's a good choice for a rubber tire wheel for the f103? Other than stock.
Jody
RELIC RACING
Old 08-17-2017, 06:16 PM   #2226
I had some success with Ride Hard front and Soft rears on TRG rims, med traction track.
astgerma52sp is offline   Reply With Quote
Old 08-17-2017, 06:25 PM   #2227
Shimizu 545 & 541, I have not been able to get them to work. They were ok on low traction but terrible when the traction increased from medium to high.
Old 08-17-2017, 07:34 PM   #2228
SpeedySST's Avatar
Well it seems I either have to use the F104 front and rear or the F103 on both. Seems there is a big difference in width but I really like the F104 setup. Sigh...as soon as this project is ready to go Im going to try CRC tires on the black carpet. The traction is up yet but we'll see how she does.
Old 08-18-2017, 12:02 PM   #2229
mtveten's Avatar
Trader Rating: 27 (100%+)
When I last ran 103 rubber we used 545 rears with 547 fronts in warmer weather. I dont recall ever trying the then new hard rears but i would say the key is to use a medium front. Even on 104 rubber at our permanent outdoor track the soft fronts are unracable when it heats up.
1/8 IC Fan likes this.
mtveten is offline   Reply With Quote
Old 08-18-2017, 06:54 PM   #2230
SpeedySST's Avatar
What about on black carpet?
Old 08-28-2017, 11:48 AM   #2231
Send a message via AIM to Nerobro
Originally Posted by 1/8 IC Fan View Post
Yes it is narrower, unless its the wide f104 like the wolf, it has the f103 front end.
The wolf is on sale at Tamiya USA: https://www.tamiyausa.com/items/radi...wolf-wr1-84124
Well, I ordered one.
High points: builds fast.
Low points: body is very hard to build. Paint is rare. Battery installation method means the radio trays are movable, and flexible. Battery pocket will not acomadate rectangular packs if you don't build the car around the battery... Requires low profile plugs to use a LiPo pack.
It wasn't a hard build... But it was hard to get set up.
Nerobro is offline   Reply With Quote
Old 08-28-2017, 01:44 PM   #2232
F N CUDA's Avatar
Trader Rating: 31 (100%+)
since this is the F103 crowd I thought I'd offer this here:
F103GT new in box, Nissan
$100 + shipping ($15-$20?)
Please text for pix if interested
562-577-8481
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 08-28-2017, 05:27 PM   #2233
SpeedySST's Avatar
Ready to hit the track again after a LONG haitus!
texastc likes this.
Old 08-28-2017, 06:15 PM   #2234
You can use the F103 or F104 rear axle/diff assembly on either car. They are interchangeable. On the rear of those cars, the wheel determines the width of the car.
In fact, the base F104 kit comes with the F103 rear axle setup. But different motor mounts/rear pod.I have heard though that those are somewhat compatible on the t-plates.
texastc and scirocco14 like this.
viking44 is offline   Reply With Quote
Old 08-28-2017, 07:04 PM   #2235
SpeedySST's Avatar
Yeah I put the F104 rear axle assembly on since I like how it works. Also, I read about putting a 1mm spacer on the front arm between the arms and the wing but where do I find 1mm m4 spacers? I tried to use 5 .2mm spacers but it was a major PIA to get the wing on so I gave up.
FS: Tamiya F103 mild seven Australia For Sale/Trade 4 08-20-2008 12:19 AM
Tamiya F103 GT izzyracer R/C Items: For Sale/Trade 2 03-01-2007 04:51 PM
Tamiya F103 NIB Jspecrcr R/C Items: For Sale/Trade 7 11-07-2006 02:30 PM
WTB: Tamiya buggy & Tamiya f103 stuff rays_tt Australia Wanted to Buy 2 04-20-2006 07:10 AM
Tamiya F103 or F103 Parts MM-F1 R/C Items: Wanted to Buy 4 04-24-2004 04:14 PM
