Like Tree6Likes
Old 03-25-2014, 05:46 PM   #1996
Originally Posted by ic-racer View Post
As far as I know those tires don't fit on the Tamiya f103 front rims. Am I wrong?
All of these tyres are made for F103 wheels
http://www.rcmart.com/advanced_searc...103+front+tire
terry.sc is offline   Reply With Quote
Old 03-26-2014, 07:42 PM   #1997
Maybe I'm calling the wheels the wrong name. Technically the rims are F104W Tamiya Front rims for rubber tires from the 1979 Lotus F1. Since the front end is F103, I figured they are f103 front rims but don't know this for sure. They are NOT F103 Foam rims. No listing on the Tamiya site for replacement tires for this car (that I can find). I don't have any problem just getting a new set of rims for the tires available. I'll probably have to scour e-bay for a set of original tires for the original rims and use them for display only. I'll also try Tamiya customer service. They amazingly provided a replacement set of tires for a Ferrari 312B 1/12 plastic kit I built in 1975!
ic-racer is offline   Reply With Quote
Old 03-26-2014, 08:21 PM   #1998
Answering my own question here, I found these for sale but pretty expensive:
Tamiya 53138 Integrated Slick Tires/Tyres Hard F-1 Front 3630 (1 Pair) F102/F103
Old 04-27-2014, 02:05 AM   #1999
Hi are any of you F103 guys interested in this shell I picked up? Tamiya R8C
nibnobsam is offline   Reply With Quote
Old 04-28-2014, 01:05 AM   #2000
JAM Racing's Avatar
Originally Posted by reg View Post
Thank you guys that's very help full,
What do the carbon arms do to the handling over the std ones?
Do you have a part number for the front AE springs?
Regards
now if your intrested try these
http://www.walterrchobby.com.au/inde...tic-parts.html
the castor block will split so you buy the upgrade alluminium
Walters Hobbies for all your racing needs
Serpent 411/ERYX
ORCA BATTERIES
Castle Hill Raceway
The Best in the West
JAM Racing is offline   Reply With Quote
Old 04-28-2014, 08:58 AM   #2001
firefoxussr's Avatar
Yes, I want that one. PM me please.
Parking lot heroes: M06, TA05sw, XV01, XRay T1, SC10B
Partially disassembled: HPI Cup Racer, FGX, M04, TA02, TA05 IFS
Newest acquisitions: A210SS Exige, HPI MX-5, Tamiya F40
firefoxussr is offline   Reply With Quote
Old 09-18-2014, 11:23 AM   #2002
loosewheel's Avatar
Smile
Anyone have any tips on fitting F104 front suspension to a F103? It seems pretty straightforward.
Thanks in advance!
Jody
Greetings from sunny Northern California
Going fast and breaking plastic since 1998.
RELIC RACING
loosewheel is offline   Reply With Quote
Old 09-19-2014, 03:15 PM   #2003
loosewheel's Avatar
No one willing to help?
Jody
RELIC RACING
Old 09-19-2014, 03:35 PM   #2004
Vyger's Avatar
Well off the top of my head, I would use an F104 chassis as a template and bolt the two chassis together at the front. I’d use the two large screws that hold the F103 beam front end to the chassis. This seems to be the common area between the two cars. The drill out any additional holes that you would need, like the servo mounting holes and the two rear holes of the F104 front end.
After writing the above, I took a look at the two cars I have here at work. From eyeballing the screw patterns, it looks like the 104 front end will mount directly to it. Keep in mind I haven’t actually measured them, but it looks pretty straight forward. I’m not sure what else you would need to look for.
If somebody else would like to share some insight, please do.
Tamiya Road Wizard, F101s, F102s, F103s, F103RSs, F103LM, F103RXs, F103RMs, F201's, TRF-F103R, F104 PRO's, F104 F-60 & MP4-24, F104X1's F104 V2's, a TRF101 and a TRF101w...The King of Queens
Vyger is offline   Reply With Quote
Old 09-19-2014, 03:43 PM   #2005
Pro10noob's Avatar
You can use a f103 front end on a F104 so why wouldn't it work the other way around?
Maybe you have to drill a hole or 2 but nothing serious.
Regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 09-19-2014, 05:40 PM   #2006
The front ends are interchangeable as Tamiya use exactly the same chassis mounting holes. There are quite a few parts needed though, the only parts you can use from the F103 are the steering arms and springs. Here is the F104 Pro manual http://www.tamiya.com/japan/download...al/f104pro.pdf and you can work out what's needed from it. You will need to get the D parts as you need the F104 servo mounts from it as they are part of the suspension mounts.
Old 09-19-2014, 09:35 PM   #2007
How does this car compare to a F104 with the F104 front suspension fitted? Down here in New Zealand the F103 is still one of the best cars to have and to be honest, there has been no reason for me to buy a later model car. We use 200mm + foams are allowed. I believe the F103 has the correct dimensions and battery placement to be hard to beat on an outdoor tracks.
Mike
ixlr8nz is offline   Reply With Quote
Old 09-19-2014, 10:09 PM   #2008
F N CUDA's Avatar
Trader Rating: 31 (100%+)
Mike
I was wondering the same thing.
Why make a skinny 103?
Now a wide 104 series car or even 101W, I'm guessing will be hard to beat where the 200mm car is legal.
I hope these 200mm cars come back in style here soon, says the proud owner of a new TRF 101W.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 09-20-2014, 12:03 AM   #2009
Pro10noob's Avatar
Never stopped running a Tamiya 200MM car
Always converted the f104 i owned to 200MM
Now running a 104WGP.
Regards Roy
l===/o\===l
Old 09-20-2014, 04:13 AM   #2010
I made mine because we no longer run 200mm/foams at national level, and considering I have plenty of spare F103 cars it was cheaper to fit an F104 front end on it to go narrow instead of buying a whole car for a handful of races.
It took a bit of tuning to get the balance right but once sorted it goes just like you would expect a short wheelbase pan car, changes direction nicely but isn't as stable as a normal wheelbase modern chassis.
FS: Tamiya F103 mild seven Australia For Sale/Trade 4 08-19-2008 11:19 PM
Tamiya F103 GT izzyracer R/C Items: For Sale/Trade 2 03-01-2007 03:51 PM
Tamiya F103 NIB Jspecrcr R/C Items: For Sale/Trade 7 11-07-2006 01:30 PM
WTB: Tamiya buggy & Tamiya f103 stuff rays_tt Australia Wanted to Buy 2 04-20-2006 06:10 AM
Tamiya F103 or F103 Parts MM-F1 R/C Items: Wanted to Buy 4 04-24-2004 03:14 PM
