Like Tree1Likes
Old 01-28-2014, 02:19 PM   #1966
NutDriver's Avatar
Trader Rating: 14 (100%+)
The screws that hold the front suspension to the chassis are the same ones that hold the front wing in place. If I remember correctly, the only rear wings for F1 that won't fit on an F103/104 is the WRC F180 and the 3Racing FGX.
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 01-28-2014, 03:38 PM   #1967
I bought the high downforce set. Not the fgx. So im good
dragonracing is offline   Reply With Quote
Old 01-30-2014, 05:14 AM   #1968
reg
Originally Posted by reg View Post
Hi,
Iv bought my self an original f103
It was a restoration project by the seller,it's far from setup,ie no rubber O rings,the friction pad pin all wrong,original tires lol,
Could someone give me a setup for the whole car for med/low carpet please,plus and little tips and tricks,
I threw it down last week and was surprised how it went,hoping setup properly it will go even better
Kind regards,
Mark
Anyone
reg is offline   Reply With Quote
Old 01-30-2014, 05:49 AM   #1969
Anyone
Have a look at this excellent resource: http://rcf1blog.blogspot.com/
This blog has tons of info to get the most out of many F1 cars including the classic F103. Just look for the F103 articles.
racer robert is offline   Reply With Quote
Old 01-30-2014, 05:49 AM   #1970
whitrzac's Avatar
Trader Rating: 94 (100%+)
Setup:
Preferred front springs
preferred silicone goo on the damper plate
Is there anything I'm missing?
whitrzac is offline   Reply With Quote
Old 01-30-2014, 06:25 AM   #1971
Pro10noob's Avatar
Yeah you miss something
Ride hight, tires, what battery holder, t-bar
Regards Roy
Originally Posted by whitrzac View Post
Setup:
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 01-30-2014, 06:37 AM   #1972
whitrzac's Avatar
Tires are whatever the fast guy is running.
There's more than 1 battery holder?
Tplate, snug screws so it doesn't flop around.
ride height 2-5mm, whatever doesn't drag and matches the front.. Higher if it's the 15th av ed. You don't want to scratch it.
If you want to get really technical you could try running washers instead of Orings in the T bar...
It's an f103, it will handle 90% the same no matter what you do to the car...
Old 01-30-2014, 07:06 AM   #1973
Pro10noob's Avatar
I have found the combo stock/ ball t-bar suspension mount doing very good.
So stock up front and the ball type at the rear.
Flex t-bar.
Ride height between 3-5 mm, front a bit lower then rear.
If you use the stock front suspension, dremel a bit off the middle section so you can play with washers between top en bottum section for some camber settings
Use the lowest height steering blocks so you can play more with ride height.
Just to do something on handling.
regards Roy
l===/o\===l
Old 01-30-2014, 07:54 AM   #1974
reg
Thanks chaps,lots to be getting on with then
Old 01-30-2014, 10:28 AM   #1975
reg
Flex t-bar.
regards Roy
Could you explain how to do the mod for camber settings please,
Old 01-30-2014, 10:34 AM   #1976
Pro10noob's Avatar
Take the front end of and split then in to top half and bottum half.
Now dremel from the top half the bottum side(the pipes) down about 3MM.
Now you can alter camber by adding spacers or not(between top and bottum parts).
If you want to go simple(and allowed), then use the 3racing F109 front suspension.
It has a turnbuckle setup.
With this front suspension you can also alter ride height.
Regards Roy
Could you explain how to do the mid for camber gain please,
l===/o\===l
Old 01-30-2014, 11:54 AM   #1977
NutDriver's Avatar
+1 on the 3Racing front end. Some folks complain that the plastic is soft, but for about $20 you can have a complete front end with the camber adjustment built-in.
Scott
USVTA member #111
Old 01-30-2014, 02:16 PM   #1978
reg
Regards Roy
Thanks Roy,
Do I just take the 3mm off the outer posts next to the hubs,or the centre ones the screws go through that bolt the front to the chassis?
Old 01-30-2014, 02:48 PM   #1979
Pro10noob's Avatar
Only the centre where the bolts go true for the chassis mounting
Regards Roy
Thanks Roy,
l===/o\===l
Old 01-30-2014, 02:52 PM   #1980
reg
Regards Roy
Thanks for your time Roy,
Busy day tomorrow
FS: Tamiya F103 mild seven Australia For Sale/Trade 4 08-19-2008 11:19 PM
Tamiya F103 GT izzyracer R/C Items: For Sale/Trade 2 03-01-2007 03:51 PM
Tamiya F103 NIB Jspecrcr R/C Items: For Sale/Trade 7 11-07-2006 01:30 PM
WTB: Tamiya buggy & Tamiya f103 stuff rays_tt Australia Wanted to Buy 2 04-20-2006 06:10 AM
Tamiya F103 or F103 Parts MM-F1 R/C Items: Wanted to Buy 4 04-24-2004 03:14 PM
