Like Tree1Likes
Old 08-03-2013, 07:57 PM   #1951
malcnz's Avatar
Originally Posted by colin storey View Post
I was looking for F1 decals and d-drive website has disappeared. F1 paintlab is pretty awesome was just wondering where else people were buying them.
Colin
Colin,
I have brought off these guys http://www.ebay.com/itm/1-10-2013-F1...item3cd41b92bd and only 20usd including shipping and prity good stickers..not quite tamiya quality as a bit thicker but not bad.
SCHUMACHER MI5 EVO/TEAM POWERS/SANWA/DX4R PRO.
SERPENT F110/TEAMPOWERS 21.5.
LOSI 22 2.0/TEAM POWERS 8.5
malcnz is offline   Reply With Quote
Old 08-04-2013, 04:31 AM   #1952
Colin
D-Drive is no longer shipping internationally, and AMS are no longer making decals. Your current choice is F1paintlab, Tamiya or Pattos Place. Pattos Place stickers are scaled up versions of slot car stickers though, they haven't been designed to fit a Tamiya body, nor do their decals have the protective coating r/c stickers have.
terry.sc is offline   Reply With Quote
Old 09-02-2013, 09:23 PM   #1953
badboy's Avatar
Trader Rating: 14 (100%+)
Hi.
Would like to ask the following:
1) Can you fit the F104 Alumnimun motor mount to the F103 15th Anniversary Kit?
2) What does the ball link suspension do to the car's handling compared to the stock? Which is better?
3) For the friction pads, what's the difference when using soft to hard grease.
Thanks.
slow is fast . . .
badboy is offline   Reply With Quote
Old 09-02-2013, 11:16 PM   #1954
HeliYogi's Avatar
Trader Rating: 16 (100%+)
Originally Posted by badboy View Post
Hi.
Hello IMHO...
1) Can you fit the F104 Alumnimun motor mount to the F103 15th Anniversary Kit? Yes they fit
2) What does the ball link suspension do to the car's handling compared to the stock? Which is better? The o ring T-Bar works better.
3) For the friction pads, what's the difference when using soft to hard grease. Don't use the hard stuff, only the soft and on high traction circunstances (such as carpet), on asfalt keep the disk clean and the rear loose vs tight, the car likes it loose.
Thanks.
I hope it helps
More F-1 RC action? RCTECH Formula-1-RC-Northwest & FB @WhatBrakes
HeliYogi is offline   Reply With Quote
Old 09-03-2013, 03:48 AM   #1955
badboy's Avatar
Originally Posted by HeliYogi View Post
I hope it helps
Thanks.
Will try these out this coming weekend.
slow is fast . . .
Old 09-03-2013, 03:20 PM   #1956
Yes, but if running F103 tyres it will lower the rear end of the car. The ride height spacers used in their lower settings will lift it up to F103 settings.
It lets the rear end roll easier, and doesn't have the natural springing that the o-ring setup has to return it to centre. The ball pivots give you more rear grip and makes it feel lazy on the track. With the standard front end the ball pivot rear end is really too soft, unless you are running in very low grip conditions you will get a better chassis balance with the o-ring rear end.
Thicker grease gives you more overall steering, slows chassis reaction into corners but can reduce steering in fast sweepers as it stabilises the chassis. Thinner grease gives you less steering but faster chassis reaction into corners and through chicanes.
Old 12-08-2013, 10:49 PM   #1957
fresnojay's Avatar
Want to chime back in that I am back in the F1 game again. Yes again with a F103 as one was offered to me at a steal of a price. This one however was much nicer than my last one. So I applied what you all had helped me with on the last one to this one and it went from almost impossible to drive to almost keeping up with the TC's I was practicing with today. Also on a silver can and brushed esc (came with the car) again . Feels much better than my last one even on the crappy tires that came with it. Some proper tires, front end conversion, and oil shock to follow.
Jason
P.S. This 103 sports the Yellow Lotus body set. Much better to look at than the last one.
Tamiya TB-02, Tamiya M-05 V2 Pro, Tamiya TA-05, Tamiya F103,
fresnojay is offline   Reply With Quote
Old 01-21-2014, 05:28 PM   #1958
Send a message via Yahoo to KrackerG
^^^ nice I just bought the same car F103 lotus honda 99t, have not touched it yet. I also got a set of the Camel decals to model the original senna car!
What wheels
/tires?
Are those from the f104? I did not know if they fit
HPI CHALLENGE East Coast: '01 E-town, NJ, '02 spring Valley, NY, '03 Home Depot, NJ, '05 Delaware, '08 Cherry Hill, NJ and 301 Raceway in MD. - RTR Box Stock Nitro - Nitro Vintage TA - 1/10 Nitro Truck - Super Nitro
KrackerG is offline   Reply With Quote
Old 01-21-2014, 11:40 PM   #1959
fresnojay's Avatar
The tires&wheels are F104 Tamiya other than that no clue. They came with the car and work well. Only thing is you need different bearings in the F104 front wheels than the F103 ones. The 104 ones are bigger. That and the front ends up being wider than the rear since the 103 is a 200mm car and the 104 is a 180mm one. The 103 rear wheels/tires are way wider. Does take some getting used to driving wise but is just fine once there.
Jason
Old 01-22-2014, 07:02 AM   #1960
madjack's Avatar
Trader Rating: 19 (100%+)
Send a message via Yahoo to madjack
Hi.
Thanks.
I have a narrow 103.5 that I've run on occasion when the rules allow.
It's an F103 pivot ball based chassis with a F104x side damper replacing the friction plates. The car works quiet well on more technical tracks given the short wheel base. I found it to be an interesting diversion from the standard Tamiya F1 chassis's.
http://www.rctech.net/forum/members/...4-chassis.html
madjack is offline   Reply With Quote
Old 01-22-2014, 07:08 AM   #1961
Pro10noob's Avatar
Use the front of the Original battery holder and the rear from the ball suspension.
Then you have the benefits of both.
It returns to neutral point and is very smooth so more rear grip.
Regards Roy
Hi.
thanks.
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 01-28-2014, 12:55 PM   #1962
reg
Hi,
Iv bought my self an original f103
It was a restoration project by the seller,it's far from setup,ie no rubber O rings,the friction pad pin all wrong,original tires lol,
Could someone give me a setup for the whole car for med/low carpet please,plus and little tips and tricks,
I threw it down last week and was surprised how it went,hoping setup properly it will go even better
Kind regards,
Mark
reg is offline   Reply With Quote
Old 01-28-2014, 12:59 PM   #1963
quick question. the front 103 wing fit the 104? i bought the 3 racing high downforce set and im hoping the front fits with minimal mod.
dragonracing is offline   Reply With Quote
Old 01-28-2014, 01:54 PM   #1964
NutDriver's Avatar
@dragon,
It is a direct fit.
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 01-28-2014, 02:11 PM   #1965
thanks, i wasnt sure since nobody post a decent pic of the mounting points when they sell them. just say its for an f103.
FS: Tamiya F103 mild seven Australia For Sale/Trade 4 08-19-2008 11:19 PM
Tamiya F103 GT izzyracer R/C Items: For Sale/Trade 2 03-01-2007 03:51 PM
Tamiya F103 NIB Jspecrcr R/C Items: For Sale/Trade 7 11-07-2006 01:30 PM
WTB: Tamiya buggy & Tamiya f103 stuff rays_tt Australia Wanted to Buy 2 04-20-2006 06:10 AM
Tamiya F103 or F103 Parts MM-F1 R/C Items: Wanted to Buy 4 04-24-2004 03:14 PM
