Old 01-27-2013, 05:17 PM   #1876
Originally Posted by liljohn1064 View Post
I might have to get the 3Racing battery mount set, but not sure if when mounted they provide enough space for a lipo. Any one have any experience with that part?
If that's the 3Racing ball pivot mounts then it's unlikely to have enough clearance around the pivots.
If you are using a full size lipo in there you will find the battery holders won't fit on the ends. A standard lipo just goes through the standard battery mounts and is wedged in pretty tight. For mine, one strip of fibreglass tape to stop it sliding out does the job of holding it in place.
terry.sc is offline   Reply With Quote
Old 01-27-2013, 06:55 PM   #1877
liljohn1064's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to liljohn1064 Send a message via MSN to liljohn1064 Send a message via Yahoo to liljohn1064
I give. Pulling out the pivot set and putting in the o-ring set.
John Higgins
liljohn1064 is offline   Reply With Quote
Old 01-27-2013, 10:23 PM   #1878
Pro10noob's Avatar
Said it before, use the O-ring at the front and the pivot ball at the rear and a shorty lipo will slip in.
Secure it with fiber tape and your good to go
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 01-28-2013, 07:20 AM   #1879
As the car is no longer TCS compliant, I did some sanding on the base of the battery mount. I took off just enough material to make the O-ring base flat with the rest of the mount. No more battery fitment problem. I should be able to put the pivot mount back on the rear side with little or no sanding to try it. The M body with the F104 front wing lines up exactly with no extra or elongated holes.
John Higgins
Old 01-28-2013, 09:08 AM   #1880
whitrzac's Avatar
Trader Rating: 93 (100%+)
Is there a way to get the f104 width wheels to fit?
whitrzac is offline   Reply With Quote
Old 01-28-2013, 09:42 AM   #1881
F104 wheels bolt straight on, there's no problem with wheel fitment.
The problem is the rear wheels are narrower than F103 wheels. To bring the wheels into line again you need to fit the F104 front end on the F103. If you also have the old style rear pod with fixed ride height, you also want to swap out the pod for an F104 one as well as the tyres are a bit larger. I have seen F103s with F104 tyres and no chassis changes and they still run fine, just a different chassis balance and looks a little odd.
Unless you have to use specific F104 tyres like the TCS ones there are F103 size alternatives readily available.
Old 01-28-2013, 09:47 AM   #1882
F104 wheels do fit the F103, but the front width would be 200mm and the rear width would be 185mm.
I'm using F104 front wheels on my F104ver.II converted to a wide version, i'm doing this because you can use the wheels much longer then F103 wheels/tires.
The F104 front wheels are bigger then F103 front wheels, meaning you are able to use the front wheels with about 3mm foam tire on it and still have plenty of ride height.
Hope this info helps.
addicted2blue is offline   Reply With Quote
Old 01-28-2013, 11:50 AM   #1883
Use F104 bearings.
John Higgins
Old 01-28-2013, 11:51 AM   #1884
whitrzac's Avatar
It's a f103 15th anniversary. so it has an adjustable pod/etc.
do you still put the thrust bearing in the wheel with f104 wheels?
Old 01-28-2013, 11:55 AM   #1885
Yes sir, they still stack in the same order. Get the 3Racing rear pod and you'll be very happy with it.
John Higgins
Old 01-30-2013, 06:07 PM   #1886
whitrzac's Avatar
How much would a set of f103 foam wheels/tires be worth?
I have 1 pair of rears and 3 pairs of fronts...
Old 02-01-2013, 09:55 PM   #1887
fresnojay's Avatar
Well I have my new to me bargain F103. Can any of you guys point out any parts I should put on the immediate buy list, besides tires lol. Ok so I can't post pics from my phone but can post them in my profile albums. Do there is a body on and body off pick in my profile albums. So if any of you would mind taking a look and let me know I would gladly appreciate it.
Thanks in advance,
Jason
Tamiya TB-02, Tamiya M-05 V2 Pro, Tamiya TA-05, Tamiya F103,
fresnojay is offline   Reply With Quote
Old 02-02-2013, 08:31 AM   #1888
Thanks in advance,
Jason
Depends on what you want to do with it. As long as it has bearings then there's nothing that's a must buy for it. An alloy motor mount will stop the motor moving in an accident if the motor is getting hot enough to soften the plastic mount, unlikely to be a problem with the kit motor, but that's it. A touring car shock instead of the spring holder and spring will give more control on bumpy surfaces, but also makes it easier to get the setup wrong.
The car you have is an F103L, the long wheelbase Indycar chassis. This means other f1 bodies won't fit on the car, but it can be converted to a standard F103 by replacing just the chassis plate and removing the front upper deck. The wheels were unique to this car and no longer available, but normal F103 wheels and tyres will fit straight on, it looks like it's already fitted with standard F103 size wheels.
Old 02-02-2013, 10:02 AM   #1889
fresnojay's Avatar
Thanks Terry for the info. That answers the question i had as to which 103 I had. I will probably pick up the new chassis plate down the road. Already had a 3 racing shock on order for it too. That is awesome to hear that it is good to go. Less $ put into an already bargain car. It had rear bearings in it already and I added the fronts from some M05 bearings I had laying around.
Jason
Old 02-02-2013, 12:45 PM   #1890
whitrzac's Avatar
I'm interested in the wheels/tires if you plan on upgrading...
I've never seen F1 tires with tread...
FS: Tamiya F103 mild seven Australia For Sale/Trade 4 08-20-2008 12:19 AM
Tamiya F103 GT izzyracer R/C Items: For Sale/Trade 2 03-01-2007 04:51 PM
Tamiya F103 NIB Jspecrcr R/C Items: For Sale/Trade 7 11-07-2006 02:30 PM
WTB: Tamiya buggy & Tamiya f103 stuff rays_tt Australia Wanted to Buy 2 04-20-2006 07:10 AM
Tamiya F103 or F103 Parts MM-F1 R/C Items: Wanted to Buy 4 04-24-2004 04:14 PM
SEO by vBSEO 3.5.0
