Like Tree6Likes
Old 09-08-2012, 08:48 PM   #1846
BadSign's Avatar
Trader Rating: 15 (100%+)
You should just put an ice cube on the motor and let it melt while your batteries are charging.
This is the day the Lord has made, I will rejoice and be glad in it- Psalms 118:24
World Champion Turn Marshall
BadSign is offline   Reply With Quote
Old 09-09-2012, 02:01 AM   #1847
NiMo's Avatar
Originally Posted by davidwp View Post
In about 1995 a friend found a deal ($89) on the Tamiya F103 Ferrari 412T1 kit, so we each got two. I built one as Berger's 1994 car and he did Alesi. We raced and bashed for several years and kept the extra cars for spares. Then I moved and the car sat till the grandkids came along. Even their bashing didn't require many spare parts, so they lobbied for me to build the second car:
Now the 7-yr-old and 8-yr-old each have a car to run:
The one part that I have had some trouble with is the plastic motor mount, so I ordered a 3racing aluminum one with a fan (the motors - stock 27 turn - get very hot with continual kid bashing). My question is:
Where should I attach the fan wires? Even more important, where should I NOT attach the fan wires? I assume they should be attached to the leads from the battery to the ESC (I use old style - and cheap - 7.2v 1800 mah NiCad stick packs).
Here is the chassis:
Thanks for your help.
Are the fan motors 5v or 7v ?
If 7v then you can wire direct to the battery leads, but .....
If 5v then this would burn out the motor (either soon or later).
Option for 5v:
Wire via a receiver channel.
Use a small LiFe pack for the fan.
Wire to the motor wires (this will have the fan speed change with the motor speed, more power more speed)
NiMo is offline   Reply With Quote
Old 09-09-2012, 08:24 AM   #1848
davidwp's Avatar
7v, I'll hook it up to the battery leads.
Thanks,
David Palmeter
Started in 1968, back at it w/grandkids
- two Tamiya F103 Ferrari 412T1 Berger /Jimmy Murphy (Sorta)
- Radio Shack/Verdikt Conversion
http://palmeter.com/rcmodels001/
davidwp is offline   Reply With Quote
Old 09-13-2012, 02:37 PM   #1849
hey guys,
im bringing my F103LM back to life how ever after the added brushless motor system i have no grip, doing some research and found that the F104 tires fit in the rear and the front need new bearings. my question is for the bearings do i just get the f104 front end system or just the bearings.
i dont want to pay $30 per tire set, the f104 is half that so this is my reasoning., if i can find just the tires will they fit on the f103 rims??
Hpi R40 Hara w/ .12JLR
Hpi R40-rolling frame
Tamyia F103 LM -Ole school
soon a 1/8th on road
Duratrax Maximum ST Pro
Hpimichael is offline   Reply With Quote
Old 09-21-2012, 06:56 AM   #1850
You can put the F104 tires directly, just swapping front bearings, but the car will be 20 mm narrower at the rear. I tried this, and works well but looks weird.
to put a F104 front end, you will need also the servo support and kingpins.
prorace is offline   Reply With Quote
Old 09-24-2012, 01:47 PM   #1851
BadSign's Avatar
Originally Posted by Hpimichael View Post
hey guys,
If you have the old wheels and can get the foams off of them, you could try these
Old 09-25-2012, 01:09 PM   #1852
Would anyone be able to tell me what the best options are for titanium screw sets? I would prefer that they have hex heads on them.
slowmotion36 is offline   Reply With Quote
Old 09-26-2012, 11:21 AM   #1853
I got a set from TRG they are perfect but if you got a 15th Anniversary then you need some more for the Alloy parts
sidecarphil1 is offline   Reply With Quote
Old 10-14-2012, 04:27 AM   #1854
lol!! Mine doesn't stick to the ground not even with a Tamiya Sport Tuned (black can)!!
I took it out to the track today but this car is behaving... useless to say the best. It spins every 5 meters: on throttle, of throttle, half throttle.. it doesn't really matter, it only goes straight.. on straights!
I thought it was the diff at first, so i spent a full night on it. Sanded the plates, used the appropriate oil, took a look at the right position of the conic washers (common mistake from what I've heard) at in the end i got it perfect. It's so extremely smooth it feels better than a gear one. And still no grip..
I tried all the tires combination... still no grip.
I built it scratch from parts and i think i got all the right stuff:
  • 3racing graphite gt chassis
  • standart GT from suspension (The best. I had the 3racing adjustable, but those turnbuckle top arms don't like crashes)
  • 3racing graphite long top deck
  • 3racing graphite t-bar
  • 3racing f103 shock
  • stock front t-bar mount
  • pillow ball rear t-bar mount
I think using the pillow ball on the rear mount helps a lot, it makes the side movement smoother and more spring like. It's only rear compression that seems a little too hard with the graphite t-bar. When on acceleration the car should squat a little and it really doesn't, witch might be a indication.. So, my thoughts now are:
  • Softer tamiya t-bar (maybe will be softer on suspension compression?)
  • Change the motor to silver can
Any opinions? The reason I'm totally lost here it's that my M-04 (also rear wheel drive) drives perfectly in the same track. I mean i could drive circles arround the f103 with it!!
CondeAfonso is offline   Reply With Quote
Old 10-17-2012, 09:10 AM   #1855
howardcano's Avatar
Trader Rating: 35 (100%+)
Any opinions?
The pillow ball rear T-bar mount adds considerably to the rear bump stiffness since the pivot is not on the neutral axis of the T-bar. (Most T-bar cars have the pivot ball located in the center of the T-bar's thickness, or Z dimension. On the F103 the pivot ball is above the T-bar. This also raises the roll center as compared to the stock T-bar mount, which reduces rear grip while cornering.) The combination of this and the graphite T-bar means you probably have a spring rate on bump that's way too big, which can make the rear end hop.
Try the fiberglass T-bar, preferably the thinnest (softest) you can find, and the lightest spring you can get for the shock (or no spring at all, if there is sufficient ride height).
I'll assume you are properly doping the rear tires, also.
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 10-17-2012, 10:34 AM   #1856
Done. I just changed to the O-ring rear mount to se how it will handle. Will test it sunday monday
Old 10-17-2012, 02:06 PM   #1857
For me, it's about tires and weights. Assuming correct tires, time to add tons of weights until handling is ok. There was a time I added 300 grams to the rear pod just to prevent it from spinning out as track grip was non existent.
But nowadays, 70 grams and steel axle in rear pod works most of the time for me. Plus correct tires and traction compound.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 10-21-2012, 12:49 AM   #1858
Ready for Sunday practice. Taking all kinds of tires with me to see what works.
  • back o-ring mount
  • no spring on shock
  • silver can motor
Lets hope i can drive it now
Old 10-21-2012, 01:09 AM   #1859
Pro10noob's Avatar
Try this
Hard front springs, flex T-bar with normall batterymount at the front and ballsuspentionmount at the rear,steel axle, 300 oil in shock, red Tamiya spring, shorty lipo and if you are running on foam, 25 or 30 rear and 40 to 45 front.
For tire liquid try TC5 at the rear and warm the tires so it gets really in there.
Front start with just a thirth of tire liquid and work your way from there
regards Roy
  • back o-ring mount
  • silver can motor
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 10-21-2012, 05:22 AM   #1860
Originally Posted by Pro10noob View Post
Try this
regards Roy
Well actually it perfomed amazing! It had so much grip now that it understeered. I only managed to spin-it on braking and with lots of steering.
It was a fun morning finally
FS: Tamiya F103 mild seven Australia For Sale/Trade 4 08-19-2008 11:19 PM
Tamiya F103 GT izzyracer R/C Items: For Sale/Trade 2 03-01-2007 03:51 PM
Tamiya F103 NIB Jspecrcr R/C Items: For Sale/Trade 7 11-07-2006 01:30 PM
WTB: Tamiya buggy & Tamiya f103 stuff rays_tt Australia Wanted to Buy 2 04-20-2006 06:10 AM
Tamiya F103 or F103 Parts MM-F1 R/C Items: Wanted to Buy 4 04-24-2004 03:14 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
