Old 08-04-2012, 01:52 PM   #1831
davidwp's Avatar
Originally Posted by Kevin CBR View Post
You can also mount the F103 Shimizu tires on the Ride rear rims if you are using an F104 diff. That is what I ran on my F103 as an F1 and a LeMans car.
I don't understand. Is this what you are saying:
F103 Diff - Ride Tires - Ride Rims - okay
F103 Diff - Shimizu Tires - Ride Rims - NOT okay
F104 Diff - Shimizu Tires - Ride Rims - okay
Thanks,
David Palmeter
Started in 1968, back at it w/grandkids
- two Tamiya F103 Ferrari 412T1 Berger /Jimmy Murphy (Sorta)
- Radio Shack/Verdikt Conversion
http://palmeter.com/rcmodels001/
davidwp is offline   Reply With Quote
Old 08-04-2012, 02:19 PM   #1832
I have no idae but gives there a con. kit. for take 103 to a 103GT ? ...when not then witch part must i buy....???
single cab is offline   Reply With Quote
Old 08-05-2012, 06:54 AM   #1833
The Tamiya parts listed DO NOT include the rear wing plastic mount. If you are replacing on a current F104W, the kit came with that wing mount. If you are buying to put on an F103, you will have nothing to mount the rear wing to the car. And no, Tamiya does not sell that mount separately.
Panda
The Lotus 99T body came on an F103 chassis so it is guaranteed to fit an F103, but might be a bit short for an F104. The wing mount are the K parts, part number 19114019. The parts listed above included the body, front and rear wings and the rear wing mount. It did not include the sticker set which is part number 19498069.
If you can't get the Tamiya wing mount, there is also the TRG rear wing stay set.
terry.sc is offline   Reply With Quote
Old 08-05-2012, 06:59 AM   #1834
Thanks,
The diff is irrelevant, externally the F103 and F104 diffs are identical, with identical widths and identical wheel fitment. The McLaren and Ferrari F104 cars even come with the F103 diff fitted.
If you want to run F103 Ride tyres, they are made to fit Ride rims.
If you want to run F103 Shimizu tyres, they are made to fit F103 normal foam wheels.
Both wheels fit F103 and F104 diffs and if you try to stretch a Shimizu tyre on to an F103 wheel whether it is on an F103 or f104 axle will make no difference as the axle can't change the wheel shape.
Now you can fit the Ride tyre on to an F103 foam wheel, but they are designed to fit into a rubber tyre wheel not sit on a flat surface like the foam wheel. So the tyre sidewall isn't supported unless you make up some rings to go into the step in the tyre.
Old 08-05-2012, 07:04 AM   #1835
To convert to an F103GT means replacing the front arms, front uprights, front axles, front bumper, chassis, rear diff parts, body mounts and spacers under the rear pod and front suspension. If you download the manual here http://www.tamiya.com/japan/download/rcmanual/58367.pdf you can see what parts need to be changed and it will give you all the part numbers.
Old 08-06-2012, 04:16 PM   #1836
davidwp's Avatar
Excellent info and very clear; couldn't imagine how the diff mattered.
Thanks,
David Palmeter
Old 08-10-2012, 09:04 AM   #1837
GasGod's Avatar
Default long top deck
Does adding a long top deck add or decrease steering?
running foam on tarmac med grip. thanks
F! Metal Militia,VTA NATION--Team SloMoFo
losi 8t,mbx5t,rc8
rc8,Kyosho rb5,SCR
ft4 MT wallet
cyclone;xxx-s;x-rayT2;crc gen xl;bmi 12rrl
GasGod is offline   Reply With Quote
Old 08-10-2012, 02:50 PM   #1838
Thatīs my F103 Roche Rapide, I have to change the electronics position but want to try this way by the moment.
By rokosam at 2012-08-10
T.O.P Photon EX-RCDevil PC10H3X-Xray X1
rokosam is offline   Reply With Quote
Old 08-19-2012, 12:04 PM   #1839
Does anybody know the difference between the 53169 t bar and the 50505 t bar? I see both advertised but don't know the technical difference between the two different part numbers.
slowmotion36 is offline   Reply With Quote
Old 08-19-2012, 12:10 PM   #1840
Pro10noob's Avatar
50505 is stock T-bar and the 53169 is the soft optional T-bar.
53169 gives more rear grip.
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 08-19-2012, 12:28 PM   #1841
OK, Thanks for the quick reply
Old 08-21-2012, 10:47 PM   #1842
cocojam's Avatar
Trader Rating: 47 (100%+)
Default Ride Tires
Aside from Ride 103 rims/wheels, what other brand of rims will fit Ride 103 grooved rubber tires (type A) for the front and rear? TIA.
SJF01 - F103RM - F104Pro - 3rF109 - TB EvoV
Wild Willy 1 - Road Wizard - Can-Am Lola
Dynamic 1500 - Wilga 2000 - Zephyr V70 - FMS FW190 - TWM Skylink
TWM Katana - Zeta Horten BV38 - Freewing Pandora
cocojam is offline   Reply With Quote
Old 08-22-2012, 01:52 AM   #1843
oldnwise's Avatar
TRG2203 for rear. TRG2105 for front, TRG rims are better quality than ride.
oldnwise is offline   Reply With Quote
Old 08-22-2012, 08:28 PM   #1844
cocojam's Avatar
Thanks Oldnwise!
Old 09-08-2012, 07:08 PM   #1845
davidwp's Avatar
In about 1995 a friend found a deal ($89) on the Tamiya F103 Ferrari 412T1 kit, so we each got two. I built one as Berger's 1994 car and he did Alesi. We raced and bashed for several years and kept the extra cars for spares. Then I moved and the car sat till the grandkids came along. Even their bashing didn't require many spare parts, so they lobbied for me to build the second car:
Now the 7-yr-old and 8-yr-old each have a car to run:
The one part that I have had some trouble with is the plastic motor mount, so I ordered a 3racing aluminum one with a fan (the motors - stock 27 turn - get very hot with continual kid bashing). My question is:
Where should I attach the fan wires? Even more important, where should I NOT attach the fan wires? I assume they should be attached to the leads from the battery to the ESC (I use old style - and cheap - 7.2v 1800 mah NiCad stick packs).
Here is the chassis:
Thanks for your help.
David Palmeter
FS: Tamiya F103 mild seven Australia For Sale/Trade 4 08-20-2008 12:19 AM
Tamiya F103 GT izzyracer R/C Items: For Sale/Trade 2 03-01-2007 04:51 PM
Tamiya F103 NIB Jspecrcr R/C Items: For Sale/Trade 7 11-07-2006 02:30 PM
WTB: Tamiya buggy & Tamiya f103 stuff rays_tt Australia Wanted to Buy 2 04-20-2006 07:10 AM
Tamiya F103 or F103 Parts MM-F1 R/C Items: Wanted to Buy 4 04-24-2004 04:14 PM
SEO by vBSEO 3.5.0
