Old 07-11-2012, 11:13 PM   #1786
ShadowAu's Avatar
Originally Posted by PDR View Post
Maybe I'm confused, this is the F104Pro diff assembly. Where would the thrust bearing go?
Build the F104Pro diff as per the instructions... works heaps better
My car may look like it goes bad to you, but its actually far worse that you think it is...
I have only one more RC thing on my bucket list and I will keep racing (and probably coming last) till its done.
ShadowAu is offline   Reply With Quote
Old 07-12-2012, 01:07 AM   #1787
Pro10noob's Avatar
Replace BA17 with the 1 piece trustbearing and mount the springwashers BA20 like this---> )(
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 07-12-2012, 02:58 AM   #1788
Thanks for all the replies, but would I use the thrust bearing in the wheel along with the thrust bearing in the 104 diff or would I only use the one in the diff and take the thrust bearing out of my F103 wheel.
slowmotion36 is offline   Reply With Quote
Old 07-12-2012, 04:00 AM   #1789
Pro10noob's Avatar
@Slowmo.....Noo need to put another trustbearing in the wheel like the F103.
Only in the F104Pro diff is enough.
Then put the wheel on there (F103 or F104) and go have some fun
regards Roy
l===/o\===l
Old 07-12-2012, 08:39 AM   #1790
Thanks Roy I appreciate the reply, and also thankyou to everybody else who replied. Do I have to be careful about the amount of torque I apply to the carbon shaft when I tighten the grub screws down. Is it possible to damage the shaft this way?
Old 07-12-2012, 09:13 AM   #1791
Pro10noob's Avatar
As always over tightening is dangerous
You could apply some CA cement to the spot where you use the screw and then carefully sand it down when you have some marks(spilled glue) on the axle.
regards Roy
l===/o\===l
Old 07-12-2012, 04:32 PM   #1792
Yokojojo's Avatar
Default width
Hi Guys
Been racing an FGX for a while and have now gone back to the F103 , i bought a mint 103GT because of my stockpile of hex type wheels/tyres ......now whats the easiest way of getting the car close to 200mm width ?? would 8/9 mm wheel hexes be an option or is there a hex style wheel that i could put my Pits and HPI tyres on .....?
thanks Mark M
Serpent 411 TE * Orion R10 Pro * Pro Amps * Dualsky * AE B4/B44 *
Associated TC6 now like a shark * Reedy * ProAmps * Hobbywong * Thunderpower
McKune Design FGX * F201 carbon * F103GT Jaguar XJS14 niiice * T.O.P F1 coming soon
Yokojojo is offline   Reply With Quote
Old 07-12-2012, 04:47 PM   #1793
macavant's Avatar
Trader Rating: 58 (100%+)
Along with + offset wheels - you can get the widening kit from 3Racing: +2 offset hubs
likes the oldskool RC action...
F103.F201.F103GT.F1R3☆F104WGP.F1Ultra☆M01.M05.YR4MSe.TA05.XV-01Pro.ABC_Genetic(Exotek)☆microRS4-Motek☆TA02SW☆WR02.CC-01☆TRF201☆TRF417X.TRF101.TRF101W
macavant is offline   Reply With Quote
Old 07-12-2012, 04:49 PM   #1794
Yokojojo's Avatar
Default awesome
Thankyou
Old 07-17-2012, 06:55 AM   #1795
Default What speed controls fit
I ordered a new Tamiya F103 2 days ago, went with the Lotus 99T. I have wanted a Tamiya F1 RC since I was about 12, and now at 30 I finally got around to buying one. Anyways I have a spektrum dx2 radio and sr300 receiver so that is covered, I have a servo on the way with the car, and couple of 1800mAh NiMH batteries (don't want to spend the cash on LiPO batteries just yet and I have a really nice NiMH charger already) All I need now is a speed control and this is where I am stuck.
I know the difference between brushless and brushed, but I think brushless is a bit out of range for what I want to spend right now, but if I could get the right price on a brushless ESC I would go for it and then shop around for a decent motor (seems to be easier to find good deals on motors than ESCs) If I go with a brushed system I will probably buy a better motor but not sure yet what turn count I will go with.
So my question is, what ESC brushed or brushless will fit my car without having to cut my chassis or body? What is the max WxLxH (Width x Length x Height) that will fit my 99T F103? I would just measure myself but the car is not here yet, so if anyone has the dimensions handy I would really appreciate it if you would list them.
TwoLaneBlackTop is offline   Reply With Quote
Old 07-17-2012, 10:51 AM   #1796
For the F103, there is plenty of room, so just about any ESC will fit. Even 10 year old ESCs and Receivers will fit side by side in front of the battery tray without interference from the body. Most modern electrics will fit in-line between the servo and the battery tray to keep the weight centralised.
Some ESCs may need to have the fan removed to fit properly. You don't really need the fan as it is a very light car, 1100-1200g, direct-drive, and is plenty fast with the stock Mabuchi/Johnson silver-can motor.
I can vouch for US locations only, but the most popular race series, UF1, Tamiya and ROAR will only allow the stock silver-can motor if using a brushed system, or a 21.5/non-timing motor/esc combo if going brushless. When properly broken-in, the silver-can motor can keep up and even be faster than the brushless systems, though at the expense of efficiency and longevity. In my testing, you will probably get about 16-20 good runs (6-10 minute heats), until you have to either water-dip/polish the commutator on the silver-can to clean it or throw it away and spend another $10 on a new one. After the second 16 run cycle, performance just rapidly drops--I don't know if it's from heat soak on the magnets or just the commutator slowly being burned (when it's bluish-purple, it is beyond worn). That's the reason why people go with the brushless in that your performance is more consistent as there is no contact/wear parts other than the bearings.
TwoWheel is offline   Reply With Quote
Old 07-17-2012, 12:30 PM   #1797
I have the same 103 that you just ordered. I use a Castle Sidewinder SV2 in mine and it works great. This control works either brushed or brushless so you can use the silver can now and always switch over to a brushless motor later if you choose. Just remember to go through the settings and set it to run in brushed mode or it won't run correctly.
Old 07-17-2012, 02:07 PM   #1798
Thanks for the replies TwoWheel, and slowmotion36. I checked out the Sidewinder and liked what I saw, so I found a good deal on a new Sidewinder and placed an order.
Old 07-28-2012, 02:51 PM   #1799
davidwp's Avatar
Default Motor Mount
The F103 that I try to keep running for the grandkids just had the left rear axle mounting point smashed out of the motor mount 'cage'. What is the most durable replacement for an F103 motor mount just used for 'bashing' (in every sense of the word)?
Thanks,
David
davidwp is offline   Reply With Quote
Old 07-28-2012, 07:35 PM   #1800
davidwp's Avatar
Default Motor Mount
Has anyone tried this motor mount for an original F103?
GPM ALLOY ALUMINUM REAR MOTOR MOUNT SILVER TAMIYA F103 F103RM F103GT
Thanks,
David
FS: Tamiya F103 mild seven Australia For Sale/Trade 4 08-20-2008 12:19 AM
Tamiya F103 GT izzyracer R/C Items: For Sale/Trade 2 03-01-2007 04:51 PM
Tamiya F103 NIB Jspecrcr R/C Items: For Sale/Trade 7 11-07-2006 02:30 PM
WTB: Tamiya buggy & Tamiya f103 stuff rays_tt Australia Wanted to Buy 2 04-20-2006 07:10 AM
Tamiya F103 or F103 Parts MM-F1 R/C Items: Wanted to Buy 4 04-24-2004 04:14 PM
SEO by vBSEO 3.5.0
