Like Tree1Likes
Old 02-27-2012, 08:06 AM   #1711
e-guy1980's Avatar
Will battery with dimensions of 133x44x16mm fit the stock battery location? I searched and googled but can't find the dimensions
*Team Holy Rollers*
Twitter: @mugen_james
That Guy R/C Screws- thatguyracing@gmail.com; KalGard; Steel MX Optics;
Six Feet Deep Clothing:www.sfdclothing.com; EPIC Cameras; Eken Power Bands
e-guy1980 is offline   Reply With Quote
Old 02-27-2012, 08:22 AM   #1712
Pro10noob's Avatar
If your looking for new batteries, why not go for the shorty 2S lipo's??
They fit perfectly and also are just as wide as the top deck.
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 02-27-2012, 10:04 AM   #1713
NiMo's Avatar
Shorties are going in to my P34 when it gets rebuilt.
(was built for bumpy outdoor, but now being rebuilt for carpet indoor)
NiMo is offline   Reply With Quote
Old 02-27-2012, 12:04 PM   #1714
e-guy1980's Avatar
I'm just trying to figure out before my car arrives if a battery I already have will fit
*Team Holy Rollers*
Old 02-27-2012, 01:06 PM   #1715
gtfour93's Avatar
Trader Rating: 22 (100%+)
I've used this before and it fits perfectly. The dimensions listed are 135x45x22mm.
gtfour93 is offline   Reply With Quote
Old 02-27-2012, 02:45 PM   #1716
e-guy1980's Avatar
Cool thanks
*Team Holy Rollers*
Old 02-28-2012, 03:03 PM   #1717
e-guy1980's Avatar
Ok, another newb question because this type of stuff is all new for me, what are some baseline settings for the 103 on a large, flowing prepped asphalt track running rubber?
*Team Holy Rollers*
Old 02-28-2012, 06:03 PM   #1718
Trader Rating: 43 (100%+)
thinking of running traxxas xl5 esc with tamiya silver can, will that esc be enough for that motor or should i get another one. i found a xl5 laying around thats why i'm asking.
aceinthesky is offline   Reply With Quote
Old 02-28-2012, 11:24 PM   #1719
Pro10noob's Avatar
Basis settings of car are:
Black springs front and lube the kingpins with some 10.000 oil.
Ridehight front 5MM.
Rear flex t-bar,red spring and 400 oil in shock.
Rideheight rear 5.5 to 6MM
Don't know what battery holder you are using?
The one with the rubber rings or the pivotball?
regards Roy
l===/o\===l
Old 02-29-2012, 07:16 AM   #1720
e-guy1980's Avatar
regards Roy
Wow thanks! I'm using the stock o-ring battery holder for now because that's what came with it and I don't know what I need to add. Red spring I'm assuming you mean a Tamiya red spring, correct? And "flex t-bar", I assume that's an option part, correct? Also, is there anything special to do for the friction pad, specific setting or grease/oil? Again, sorry for the dumb questions, I'm an off road guy, have no clue about this stuff yet.
*Team Holy Rollers*
Old 02-29-2012, 07:56 AM   #1721
Pro10noob's Avatar
There are no dumb questions only dumb answers
Here is how i have setup my F103.
Remember tho this is a foam setup or a Pits tire setup for rain.
Front springs Tamiya black,10.000 oil on the kingpins(some use AW grease).
I dremeled about 2MM in totall of the steeringbloks(top and bottum) to have me setup the rideheight a bit(safes on truing the tires).
Front is 5MM rideheight.
Front tires and this differs on track, 40 or 45SH foam or Pits PS-0543 for rain.
Rear i have 25or 30SH foam depending on grip(we got a track that generates a lot of front grip) and Pits PS-0545 for rain.
When having a really grippy track go for 36SH rears)
Centre shock 400 Tamiya oil and red Tamiya spring,Tamiya flex T-bar(the one with the S in it) and rideheight 5.5 to 6MM.
The T-bar is mounted at the front battery holder with the old type like you have but without the rubber O-ring but a spacer ring.
The rear battery holder is the pivot ball type.
This will give you a really soft rear setup and it won't wear out the holes on the T-bar.
I use the normall type front suspension arms but at the centre i cut off some material to get a bit of play with camber settings.
It isn't much but i can help to stop the uneven wear on your front tires.
Diff setup is from the F104 Pro but loose the ballbearing in it and use instead the 1 piece trust bearing(and offcourse ceramic balls).
Remember to put the spring washers like this----> )( and not like it states in the F104Pro manual.
It gives you a super smooth working diff that i didn't have to rebuild the whole season.
I use to run this setup with Tamiya A slicks rear and B up front and did have a well balanced car with normall temps.
When hotter i lost a bit of rear grip(tires getting to soft)
Hope you can use this setup where your driving.
Regards Roy
Ps i drive mostly on unprepaired nitro tarmac tracks
PS ps i also use shorty lipo's the get the weight more centred
l===/o\===l
Old 03-04-2012, 04:08 PM   #1722
Trader Rating: 70 (100%+)
Looking for suggestions on F103 rims and tips on gluing the tires.
Krafcik is offline   Reply With Quote
Old 03-04-2012, 09:53 PM   #1723
Pro10noob's Avatar
Foam or rubber?
regards Roy
l===/o\===l
Old 03-07-2012, 11:20 AM   #1724
What parts are needed to swap an F103 to F104 rear axle/diff assembely
thanks Phil
And has anyone used this car on Asphalt with Ride rubbers ????
looking for a basic set up ;-)
sidecarphil1 is offline   Reply With Quote
Old 03-08-2012, 11:54 AM   #1725
e-guy1980's Avatar
thanks Phil
You have to get the 104 diff assembly and, if you use the stock 103 axle, shorten the axle a bit. Just got mine today and fixing to try and figure it out. Guy I race with is running the same setup on asphalt with rubber and it is great. Mine will be the same setup
*Team Holy Rollers*
FS: Tamiya F103 mild seven Australia For Sale/Trade 4 08-19-2008 11:19 PM
Tamiya F103 GT izzyracer R/C Items: For Sale/Trade 2 03-01-2007 03:51 PM
Tamiya F103 NIB Jspecrcr R/C Items: For Sale/Trade 7 11-07-2006 01:30 PM
WTB: Tamiya buggy & Tamiya f103 stuff rays_tt Australia Wanted to Buy 2 04-20-2006 06:10 AM
Tamiya F103 or F103 Parts MM-F1 R/C Items: Wanted to Buy 4 04-24-2004 03:14 PM
