Like Tree1Likes
Old 01-05-2012, 08:47 AM   #1681
lightfoot's Avatar
Default UF1 Series
Round 4 of the UF1 Winter Series this Saturday at TQ Chino California...
Doors open at 10AM...
Qualifying starts at Noon...
Johnny will be announcing...
http://uf1series.com/
Love and Peace...
lightfoot is offline   Reply With Quote
Old 01-14-2012, 04:27 AM   #1682
Rod M's Avatar
I will be running my oldskool F103 at TITC next month, (wish me luck )
http://www.titc.in.th/titc/
most other guys are running F104 and FGX's so I thought I will see what the old girl can do, (plus the F103 still seems to kick the F104/FGX on local tracks anyway)
as this has a 20min final which requires one pitstop and tyre change the standard F103 Diff will not be very suitable (it may fall apart and need to be re-tightened correctly etc etc)
I heard the F104 diff may be the solution, can I get this verified as well as what partnumbers would be needed to swap them over,
I am guessing just the diff housing set? or is there anything else?
54158 F104 Aluminum Diff Housing Set
TOPRACING.NET.AU Australian Importer of:
T.O.P. Tokyo Hobbies Optional Parts,
Team Trinity , BL Motors and Tyre compound
Team Tekin , ESC's, motors,
Elangears, Chargers,
Rod M is offline   Reply With Quote
Old 01-14-2012, 05:09 AM   #1683
Pro10noob's Avatar
Use the complete rear axle from the F104PRO.
Swap the ballbearing in the diffhousing for your F103 trustbearing and mount the springwashers like this )(
It will result in a very smooth diff(if you have ceramic balls in it and sanded the diffrings down offcourse )
I use that also on my F103.
Have run the car for a whole season without maintenance and still runs smooth.
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 01-14-2012, 05:43 AM   #1684
Rod M's Avatar
Thanks for the response Roy.
so I would need to get both the "54158 F104 Aluminum Diff Housing Set" and "54162 F104 Carbon Rear Shaft" ?
Old 01-14-2012, 06:14 AM   #1685
Pro10noob's Avatar
Yes and yes.
Loose the ballbearing tho and use the one piece trustbearing what is in your rear wheel of the F103 Tamiya 53136
regards Roy
l===/o\===l
Old 01-29-2012, 09:44 PM   #1686
slide i's Avatar
Send a message via MSN to slide i Send a message via Yahoo to slide i
will be running F103 there too, see ya mate...
slide i is offline   Reply With Quote
Old 01-29-2012, 10:56 PM   #1687
Can we use the standard aluminim shaft too?
stocker is offline   Reply With Quote
Old 01-29-2012, 11:24 PM   #1688
Pro10noob's Avatar
What aluminum shaft?
regards Roy
l===/o\===l
Old 01-30-2012, 12:25 AM   #1689
regards Roy
The p/n: 84173?
Old 01-30-2012, 01:13 AM   #1690
JamesHealey's Avatar
Gotta love the f103! 15+ year old car with old t-plate and damper disc setup and she's still the queen of f1!
More 103's should be seen racing!
Serpent 977 Evo | Novarossi Engines | Racing Experience Fuel | Xpert-RC Servos | Xtreme Tyres | Bitty Design Body Shells |
http://answer-rc.com/en/ - Answer RC supported driver.
JamesHealey is offline   Reply With Quote
Old 01-30-2012, 01:18 AM   #1691
Pro10noob's Avatar
Why not?
You need the F104 axle to use the F104 pro dif parts.
You can use the steel,alloy and carbon axle.
As long as it is from the F104
If you want to use the F103 axle, you need to shorten it.
regards Roy
The p/n: 84173?
l===/o\===l
Old 01-30-2012, 01:22 AM   #1692
Pro10noob's Avatar
Problem is that more and more official races are dominated by rules using the 180MM cars.
You can try to convert the F103 to 180MM but that would take out it's charm and handling.
They need to do so as in the states.
Run a 180MM and 200MM F1 class.
This will sort all rules out so everybody has fun.
I still drive the F103 with great plessure and also converted a F104Pro to 200MM.
The F104 is a lot more fun at 200MM
regards Roy
l===/o\===l
Old 01-30-2012, 04:25 AM   #1693
RossoTorro's Avatar
I did it to mine, but decided i wanted to use the steel shaft since carbon is easy to crack. Cut down the orginal one to size and works perfect. So you only need 54158.
RossoTorro is offline   Reply With Quote
Old 02-02-2012, 01:05 AM   #1694
Rod M's Avatar
I understand that we have to run F104 tyres/Rims, have you any experience with this?
Old 02-02-2012, 08:24 AM   #1695
lightfoot's Avatar
Default UF1 Series
6th race of the 2012 UF1 Winter series will be this Saturday February 4th at TQ raceway in Chino California...
Doors open at 10 AM and qualifying starts at noon....
http://uf1series.com/index.html
Love and Peace...
FS: Tamiya F103 mild seven Australia For Sale/Trade 4 08-19-2008 11:19 PM
Tamiya F103 GT izzyracer R/C Items: For Sale/Trade 2 03-01-2007 03:51 PM
Tamiya F103 NIB Jspecrcr R/C Items: For Sale/Trade 7 11-07-2006 01:30 PM
WTB: Tamiya buggy & Tamiya f103 stuff rays_tt Australia Wanted to Buy 2 04-20-2006 06:10 AM
Tamiya F103 or F103 Parts MM-F1 R/C Items: Wanted to Buy 4 04-24-2004 03:14 PM
